[PATCH v2 2/5] misc/tftprpoxy: Correctly scale the protocol timeout
Kinsey Moore
kinsey.moore at oarcorp.com
Wed Sep 8 13:03:38 UTC 2021
Looks good to me.
On 9/6/2021 23:31, chrisj at rtems.org wrote:
> From: Chris Johns <chrisj at rtems.org>
> - Fix data decoding
> - Fix get MAC call
> misc/tools/tftpproxy.py | 13 +++++++------
> 1 file changed, 7 insertions(+), 6 deletions(-)
> diff --git a/misc/tools/tftpproxy.py b/misc/tools/tftpproxy.py
> index c0aebb0..a388912 100644
> --- a/misc/tools/tftpproxy.py
> +++ b/misc/tools/tftpproxy.py
> @@ -113,10 +113,11 @@ class tftp_session(object):
> block = (data[2] << 8) | data[3]
> s += ' ' + self.opcodes[opcode] + ', '
> s += '#' + str(block) + ', '
> - if dlen > 4:
> + if dlen > 8:
> s += '%02x%02x..%02x%02x' % (data[4], data[5], data[-2], data[-1])
> else:
> - s += '%02x%02x%02x%02x' % (data[4], data[5], data[6], data[6])
> + for i in range(4, dlen):
> + s += '%02x' % (data[i])
> s += ',' + str(dlen - 4)
> elif opcode == 4:
> @@ -162,8 +163,8 @@ class tftp_session(object):
> return None
> def get_timeout(self, default_timeout, timeout_guard):
> - if self.timeout == 0:
> - return self.timeout + timeout_guard
> + if self.timeout != 0:
> + return self.timeout * timeout_guard
> return default_timeout
> def get_block_size(self):
> @@ -178,7 +179,7 @@ class udp_handler(socketserver.BaseRequestHandler):
> session = tftp_session()
> finished = session.data(client_ip, client_port, self.request[0])
> if not finished:
> - timeout = session.get_timeout(self.server.proxy.session_timeout, 1)
> + timeout = session.get_timeout(self.server.proxy.session_timeout, 4)
> host = self.server.proxy.get_host(client_ip)
> if host is not None:
> session_count = self.server.proxy.get_session_count()
> @@ -325,7 +326,7 @@ class proxy_server(object):
> if client in self.clients:
> host = self.clients[client]
> else:
> - mac = getmac.get_mac_address(ip = client)
> + mac = misc.tools.getmac.get_mac_address(ip = client)
> if mac in self.clients:
> host = self.clients[mac]
> finally:
