[PATCH v2 3/5] tester/telnet: Only reopen once a second
Kinsey Moore
kinsey.moore at oarcorp.com
Wed Sep 8 13:04:56 UTC 2021
Looks good to me.
On 9/6/2021 23:31, chrisj at rtems.org wrote:
> From: Chris Johns <chrisj at rtems.org>
> - Limit the reopen to once a second
> - Make sure the socket is closed when reopening
> tester/rt/telnet.py | 10 +++++++++-
> 1 file changed, 9 insertions(+), 1 deletion(-)
> diff --git a/tester/rt/telnet.py b/tester/rt/telnet.py
> index 4e5e84a..919aa86 100644
> --- a/tester/rt/telnet.py
> +++ b/tester/rt/telnet.py
> @@ -36,6 +36,7 @@ import errno
> import os
> import sys
> import telnetlib
> +import time
> from rtemstoolkit import error
> from rtemstoolkit import host
> @@ -71,13 +72,20 @@ class tty:
> return s
> def _reopen(self):
> + if self.conn:
> + self.conn.close()
> + time.sleep(1)
> try:
> self.conn.open(self.host, self.port, self.timeout)
> except IOError as ioe:
> + if self.conn:
> + self.conn.close()
> raise error.general('opening telnet: %s:%d: %s' % (self.host,
> self.port,
> ioe))
> except:
> + if self.conn:
> + self.conn.close()
> raise error.general('opening telnet: %s:%d: unknown' % (self.host,
> self.port))
> @@ -98,7 +106,7 @@ class tty:
> if ioe.errno == errno.ECONNREFUSED:
> reopen = True
> data = ''
> - except EOFError:
> + except EOFError as ose:
> reopen = True
> data = ''
> if reopen:
