[PATCH rtems-tools v1 01/10] CoverageWriter: Convert to C++
Ryan Long
ryan.long at oarcorp.com
Wed Sep 8 16:44:31 UTC 2021
tester/covoar/CoverageWriterBase.h | 4 +++-
tester/covoar/CoverageWriterRTEMS.cc | 26 +++++++++++++++-----------
tester/covoar/CoverageWriterRTEMS.h | 4 +++-
tester/covoar/CoverageWriterSkyeye.cc | 33 ++++++++++++++++++---------------
tester/covoar/CoverageWriterSkyeye.h | 4 +++-
tester/covoar/CoverageWriterTSIM.cc | 23 +++++++++++------------
tester/covoar/CoverageWriterTSIM.h | 4 +++-
7 files changed, 56 insertions(+), 42 deletions(-)
diff --git a/tester/covoar/CoverageWriterBase.h b/tester/covoar/CoverageWriterBase.h
index e43a45b..fca501a 100644
--- a/tester/covoar/CoverageWriterBase.h
+++ b/tester/covoar/CoverageWriterBase.h
@@ -9,6 +9,8 @@
#include <stdint.h>
+#include <string>
#include "CoverageMapBase.h"
namespace Coverage {
@@ -46,7 +48,7 @@ namespace Coverage {
* @return Returns TRUE if the method succeeded and FALSE if it failed.
virtual void writeFile(
- const char* const file,
+ const std::string& file,
CoverageMapBase* coverage,
uint32_t lowAddress,
uint32_t highAddress
diff --git a/tester/covoar/CoverageWriterRTEMS.cc b/tester/covoar/CoverageWriterRTEMS.cc
index 48e8fd1..3332cd4 100644
--- a/tester/covoar/CoverageWriterRTEMS.cc
+++ b/tester/covoar/CoverageWriterRTEMS.cc
@@ -10,6 +10,7 @@
#include <iostream>
+#include <fstream>
#include <iomanip>
#include <rld.h>
@@ -28,23 +29,23 @@ namespace Coverage {
void CoverageWriterRTEMS::writeFile(
- FILE* coverageFile;
+ std::ofstream coverageFile;
uint32_t a;
- int status;
uint8_t cover;
rtems_coverage_map_header_t header;
+ long int bytes_before;
* read the file and update the coverage map passed in
- coverageFile = ::fopen( file, "w" );
- if ( !coverageFile ) {
+ coverageFile.open( file );
+ if ( !coverageFile.is_open() ) {
std::ostringstream what;
what << "Unable to open " << file;
throw rld::error( what, "CoverageWriterRTEMS::writeFile" );
@@ -58,9 +59,10 @@ namespace Coverage {
header.end = highAddress;
strcpy( header.desc, "RTEMS Coverage Data" );
- status = ::fwrite(&header, 1, sizeof(header), coverageFile);
- if (status != sizeof(header)) {
- ::fclose( coverageFile );
+ bytes_before = coverageFile.tellp();
+ coverageFile.write( (char *) &header, sizeof( header ) );
+ if ( coverageFile.tellp() - bytes_before != sizeof( header ) ) {
what << "Unable to write header to " << file;
@@ -68,8 +70,11 @@ namespace Coverage {
for ( a=lowAddress ; a < highAddress ; a++ ) {
cover = ((coverage->wasExecuted( a )) ? 0x01 : 0);
- status = fwrite(&cover, 1, sizeof(cover), coverageFile);
- if (status != sizeof(cover)) {
+ coverageFile.write( (char *) &cover, sizeof( cover ) );
+ if ( coverageFile.tellp() - bytes_before != sizeof( cover ) ) {
std::cerr << "CoverageWriterRTEMS::writeFile - write to "
<< file
<< " at address 0x%"
@@ -81,6 +86,5 @@ namespace Coverage {
diff --git a/tester/covoar/CoverageWriterRTEMS.h b/tester/covoar/CoverageWriterRTEMS.h
index b66d2fa..c760936 100644
--- a/tester/covoar/CoverageWriterRTEMS.h
+++ b/tester/covoar/CoverageWriterRTEMS.h
@@ -7,6 +7,8 @@
#ifndef __COVERAGE_WRITER_RTEMS_H__
#define __COVERAGE_WRITER_RTEMS_H__
+#include <string>
#include "CoverageWriterBase.h"
@@ -33,7 +35,7 @@ namespace Coverage {
/* Inherit documentation from base class. */
void writeFile(
diff --git a/tester/covoar/CoverageWriterSkyeye.cc b/tester/covoar/CoverageWriterSkyeye.cc
index 7f78644..5225406 100644
--- a/tester/covoar/CoverageWriterSkyeye.cc
+++ b/tester/covoar/CoverageWriterSkyeye.cc
@@ -12,6 +12,7 @@
#include <iostream>
+#include <fstream>
#include <iomanip>
#include <rld.h>
@@ -30,23 +31,23 @@ namespace Coverage {
void CoverageWriterSkyeye::writeFile(
- CoverageMapBase* coverage,
- uint32_t lowAddress,
- uint32_t highAddress
+ CoverageMapBase* coverage,
+ uint32_t lowAddress,
+ uint32_t highAddress
uint32_t a;
uint8_t cover;
prof_header_t header;
- int status;
throw rld::error( what, "CoverageWriterSkyeye::writeFile" );
@@ -60,9 +61,10 @@ namespace Coverage {
header.prof_end = highAddress;
strcpy( header.desc, "Skyeye Coverage Data" );
@@ -71,9 +73,11 @@ namespace Coverage {
for ( a = lowAddress; a < highAddress; a += 8 ) {
cover |= ((coverage->wasExecuted( a + 4 )) ? 0x10 : 0);
what << "write to " << file
<< " at address 0x"
@@ -85,6 +89,5 @@ namespace Coverage {
diff --git a/tester/covoar/CoverageWriterSkyeye.h b/tester/covoar/CoverageWriterSkyeye.h
index 8a74f55..8f11959 100644
--- a/tester/covoar/CoverageWriterSkyeye.h
+++ b/tester/covoar/CoverageWriterSkyeye.h
@@ -7,6 +7,8 @@
#ifndef __COVERAGE_WRITER_Skyeye_H__
#define __COVERAGE_WRITER_Skyeye_H__
+#include <string>
void writeFile(
diff --git a/tester/covoar/CoverageWriterTSIM.cc b/tester/covoar/CoverageWriterTSIM.cc
index 62a1f7d..bd15c9d 100644
--- a/tester/covoar/CoverageWriterTSIM.cc
+++ b/tester/covoar/CoverageWriterTSIM.cc
@@ -9,6 +9,7 @@
#include <iostream>
+#include <fstream>
#include <iomanip>
#include <rld.h>
@@ -27,7 +28,7 @@ namespace Coverage {
void CoverageWriterTSIM::writeFile(
@@ -35,30 +36,29 @@ namespace Coverage {
uint32_t a;
int cover;
int i;
- int status;
throw rld::error( what, "CoverageWriterTSIM::writeFile" );
for ( a = lowAddress; a < highAddress; a += 0x80 ) {
- status = fprintf( coverageFile, "%x : ", a );
- if ( status == EOF || status == 0 ) {
+ coverageFile << std::hex << a << " : " << std::dec;
+ if ( coverageFile.fail() ) {
break;
for ( i = 0; i < 0x80; i += 4 ) {
cover = ((coverage->wasExecuted( a + i )) ? 1 : 0);
- status = ::fprintf( coverageFile, "%d ", cover );
+ coverageFile << cover << " ";
<< " at address 0x"
@@ -69,9 +69,8 @@ namespace Coverage {
- ::fprintf( coverageFile, "\n" );
+ coverageFile << "\n";
diff --git a/tester/covoar/CoverageWriterTSIM.h b/tester/covoar/CoverageWriterTSIM.h
index b43e1c6..5ae57f8 100644
--- a/tester/covoar/CoverageWriterTSIM.h
+++ b/tester/covoar/CoverageWriterTSIM.h
@@ -7,6 +7,8 @@
#ifndef __COVERAGE_WRITER_TSIM_H__
#define __COVERAGE_WRITER_TSIM_H__
+#include <string>
void writeFile(
1.8.3.1
