[PATCH rtems-tools v1 01/10] CoverageWriter: Convert to C++
Chris Johns
chrisj at rtems.org
Wed Sep 8 22:44:14 UTC 2021
On 9/9/21 2:44 am, Ryan Long wrote:
> tester/covoar/CoverageWriterBase.h | 4 +++-
> tester/covoar/CoverageWriterRTEMS.cc | 26 +++++++++++++++-----------
> tester/covoar/CoverageWriterRTEMS.h | 4 +++-
> tester/covoar/CoverageWriterSkyeye.cc | 33 ++++++++++++++++++---------------
> tester/covoar/CoverageWriterSkyeye.h | 4 +++-
> tester/covoar/CoverageWriterTSIM.cc | 23 +++++++++++------------
> tester/covoar/CoverageWriterTSIM.h | 4 +++-
> 7 files changed, 56 insertions(+), 42 deletions(-)
> diff --git a/tester/covoar/CoverageWriterBase.h b/tester/covoar/CoverageWriterBase.h
> index e43a45b..fca501a 100644
> --- a/tester/covoar/CoverageWriterBase.h
> +++ b/tester/covoar/CoverageWriterBase.h
> @@ -9,6 +9,8 @@
> #include <stdint.h>
> +#include <string>
> #include "CoverageMapBase.h"
> namespace Coverage {
> @@ -46,7 +48,7 @@ namespace Coverage {
> * @return Returns TRUE if the method succeeded and FALSE if it failed.
> virtual void writeFile(
> - const char* const file,
> + const std::string& file,
> CoverageMapBase* coverage,
> uint32_t lowAddress,
> uint32_t highAddress
> diff --git a/tester/covoar/CoverageWriterRTEMS.cc b/tester/covoar/CoverageWriterRTEMS.cc
> index 48e8fd1..3332cd4 100644
> --- a/tester/covoar/CoverageWriterRTEMS.cc
> +++ b/tester/covoar/CoverageWriterRTEMS.cc
> @@ -10,6 +10,7 @@
> #include <string.h>
> #include <iostream>
> +#include <fstream>
> #include <iomanip>
> #include <rld.h>
> @@ -28,23 +29,23 @@ namespace Coverage {
> void CoverageWriterRTEMS::writeFile(
> - FILE* coverageFile;
> + std::ofstream coverageFile;
> uint32_t a;
> - int status;
> uint8_t cover;
> rtems_coverage_map_header_t header;
> + long int bytes_before;
This need to change. Please review the fixes I added for the places this happened.
Building this on MacOS and FreeBSD should show the error.
> * read the file and update the coverage map passed in
> - coverageFile = ::fopen( file, "w" );
> - if ( !coverageFile ) {
> + coverageFile.open( file );
> + if ( !coverageFile.is_open() ) {
> std::ostringstream what;
> what << "Unable to open " << file;
> throw rld::error( what, "CoverageWriterRTEMS::writeFile" );
> @@ -58,9 +59,10 @@ namespace Coverage {
> header.end = highAddress;
> strcpy( header.desc, "RTEMS Coverage Data" );
> - status = ::fwrite(&header, 1, sizeof(header), coverageFile);
> - if (status != sizeof(header)) {
> - ::fclose( coverageFile );
> + bytes_before = coverageFile.tellp();
> + coverageFile.write( (char *) &header, sizeof( header ) );
> + if ( coverageFile.tellp() - bytes_before != sizeof( header ) ) {
clang does not like this line
> what << "Unable to write header to " << file;
> @@ -68,8 +70,11 @@ namespace Coverage {
> for ( a=lowAddress ; a < highAddress ; a++ ) {
> cover = ((coverage->wasExecuted( a )) ? 0x01 : 0);
> - status = fwrite(&cover, 1, sizeof(cover), coverageFile);
> - if (status != sizeof(cover)) {
> + coverageFile.write( (char *) &cover, sizeof( cover ) );
> + if ( coverageFile.tellp() - bytes_before != sizeof( cover ) ) {
> std::cerr << "CoverageWriterRTEMS::writeFile - write to "
> << file
> << " at address 0x%"
> @@ -81,6 +86,5 @@ namespace Coverage {
> diff --git a/tester/covoar/CoverageWriterRTEMS.h b/tester/covoar/CoverageWriterRTEMS.h
> index b66d2fa..c760936 100644
> --- a/tester/covoar/CoverageWriterRTEMS.h
> +++ b/tester/covoar/CoverageWriterRTEMS.h
> @@ -7,6 +7,8 @@
> #ifndef __COVERAGE_WRITER_RTEMS_H__
> #define __COVERAGE_WRITER_RTEMS_H__
> +#include <string>
> #include "CoverageWriterBase.h"
> @@ -33,7 +35,7 @@ namespace Coverage {
> /* Inherit documentation from base class. */
> void writeFile(
> diff --git a/tester/covoar/CoverageWriterSkyeye.cc b/tester/covoar/CoverageWriterSkyeye.cc
> index 7f78644..5225406 100644
> --- a/tester/covoar/CoverageWriterSkyeye.cc
> +++ b/tester/covoar/CoverageWriterSkyeye.cc
> @@ -12,6 +12,7 @@
> #include <string.h>
> #include <iostream>
> +#include <fstream>
> #include <iomanip>
> #include <rld.h>
> @@ -30,23 +31,23 @@ namespace Coverage {
> void CoverageWriterSkyeye::writeFile(
> - CoverageMapBase* coverage,
> - uint32_t lowAddress,
> - uint32_t highAddress
> + CoverageMapBase* coverage,
> + uint32_t lowAddress,
> + uint32_t highAddress
> uint32_t a;
> uint8_t cover;
> prof_header_t header;
> - int status;
Again here
> throw rld::error( what, "CoverageWriterSkyeye::writeFile" );
> @@ -60,9 +61,10 @@ namespace Coverage {
> header.prof_end = highAddress;
> strcpy( header.desc, "Skyeye Coverage Data" );
> @@ -71,9 +73,11 @@ namespace Coverage {
> for ( a = lowAddress; a < highAddress; a += 8 ) {
> cover |= ((coverage->wasExecuted( a + 4 )) ? 0x10 : 0);
> what << "write to " << file
> << " at address 0x"
> @@ -85,6 +89,5 @@ namespace Coverage {
> diff --git a/tester/covoar/CoverageWriterSkyeye.h b/tester/covoar/CoverageWriterSkyeye.h
> index 8a74f55..8f11959 100644
> --- a/tester/covoar/CoverageWriterSkyeye.h
> +++ b/tester/covoar/CoverageWriterSkyeye.h
> @@ -7,6 +7,8 @@
> #ifndef __COVERAGE_WRITER_Skyeye_H__
> #define __COVERAGE_WRITER_Skyeye_H__
> +#include <string>
> void writeFile(
> diff --git a/tester/covoar/CoverageWriterTSIM.cc b/tester/covoar/CoverageWriterTSIM.cc
> index 62a1f7d..bd15c9d 100644
> --- a/tester/covoar/CoverageWriterTSIM.cc
> +++ b/tester/covoar/CoverageWriterTSIM.cc
> @@ -9,6 +9,7 @@
> #include <stdlib.h>
> #include <iostream>
> +#include <fstream>
> #include <iomanip>
> #include <rld.h>
> @@ -27,7 +28,7 @@ namespace Coverage {
> void CoverageWriterTSIM::writeFile(
> @@ -35,30 +36,29 @@ namespace Coverage {
> uint32_t a;
> int cover;
> int i;
> - int status;
> throw rld::error( what, "CoverageWriterTSIM::writeFile" );
> for ( a = lowAddress; a < highAddress; a += 0x80 ) {
> - status = fprintf( coverageFile, "%x : ", a );
> - if ( status == EOF || status == 0 ) {
> + coverageFile << std::hex << a << " : " << std::dec;
> + if ( coverageFile.fail() ) {
> break;
> for ( i = 0; i < 0x80; i += 4 ) {
> cover = ((coverage->wasExecuted( a + i )) ? 1 : 0);
> - status = ::fprintf( coverageFile, "%d ", cover );
> + coverageFile << cover << " ";
> << " at address 0x"
> @@ -69,9 +69,8 @@ namespace Coverage {
> - ::fprintf( coverageFile, "\n" );
> + coverageFile << "\n";
Should this be std::endl ?
> diff --git a/tester/covoar/CoverageWriterTSIM.h b/tester/covoar/CoverageWriterTSIM.h
> index b43e1c6..5ae57f8 100644
> --- a/tester/covoar/CoverageWriterTSIM.h
> +++ b/tester/covoar/CoverageWriterTSIM.h
> @@ -7,6 +7,8 @@
> #ifndef __COVERAGE_WRITER_TSIM_H__
> #define __COVERAGE_WRITER_TSIM_H__
> +#include <string>
> void writeFile(
