[PATCH rtems-tools v1 05/10] CoverageWriterRTEMS.cc: Fix formatting
Ryan Long
ryan.long at oarcorp.com
Wed Sep 8 16:44:35 UTC 2021
tester/covoar/CoverageWriterRTEMS.cc | 23 +++++++++++------------
1 file changed, 11 insertions(+), 12 deletions(-)
diff --git a/tester/covoar/CoverageWriterRTEMS.cc b/tester/covoar/CoverageWriterRTEMS.cc
index 3332cd4..d6c6ca3 100644
--- a/tester/covoar/CoverageWriterRTEMS.cc
+++ b/tester/covoar/CoverageWriterRTEMS.cc
@@ -30,9 +30,9 @@ namespace Coverage {
void CoverageWriterRTEMS::writeFile(
const std::string& file,
- CoverageMapBase* coverage,
- uint32_t lowAddress,
- uint32_t highAddress
+ CoverageMapBase* coverage,
+ uint32_t lowAddress,
+ uint32_t highAddress
std::ofstream coverageFile;
@@ -52,9 +52,9 @@ namespace Coverage {
/* clear out the header and fill it in */
- memset( &header, 0, sizeof(header) );
+ memset( &header, 0, sizeof( header ) );
header.ver = 0x1;
- header.header_length = sizeof(header);
+ header.header_length = sizeof( header );
header.start = lowAddress;
header.end = highAddress;
strcpy( header.desc, "RTEMS Coverage Data" );
@@ -68,8 +68,8 @@ namespace Coverage {
throw rld::error( what, "CoverageWriterRTEMS::writeFile" );
- for ( a=lowAddress ; a < highAddress ; a++ ) {
- cover = ((coverage->wasExecuted( a )) ? 0x01 : 0);
+ for ( a = lowAddress; a < highAddress; a++ ) {
+ cover = ( ( coverage->wasExecuted( a ) ) ? 0x01 : 0 );
bytes_before = coverageFile.tellp();
@@ -78,11 +78,10 @@ namespace Coverage {
std::cerr << "CoverageWriterRTEMS::writeFile - write to "
<< file
<< " at address 0x%"
- << std::hex << std::setfill('0')
- << std::setw(8) << a
- << std::setfill(' ') << std::dec
- << " failed"
- << std::endl;
+ << std::hex << std::setfill( '0' )
+ << std::setw( 8 ) << a
+ << std::setfill( ' ' ) << std::dec
+ << " failed\n";
1.8.3.1
