[PATCH rtems-tools v1 05/10] CoverageWriterRTEMS.cc: Fix formatting
Chris Johns
chrisj at rtems.org
Wed Sep 8 22:53:30 UTC 2021
On 9/9/21 2:44 am, Ryan Long wrote:
> tester/covoar/CoverageWriterRTEMS.cc | 23 +++++++++++------------
> 1 file changed, 11 insertions(+), 12 deletions(-)
> diff --git a/tester/covoar/CoverageWriterRTEMS.cc b/tester/covoar/CoverageWriterRTEMS.cc
> index 3332cd4..d6c6ca3 100644
> --- a/tester/covoar/CoverageWriterRTEMS.cc
> +++ b/tester/covoar/CoverageWriterRTEMS.cc
> @@ -30,9 +30,9 @@ namespace Coverage {
> void CoverageWriterRTEMS::writeFile(
> const std::string& file,
> - CoverageMapBase* coverage,
> - uint32_t lowAddress,
> - uint32_t highAddress
> + CoverageMapBase* coverage,
> + uint32_t lowAddress,
> + uint32_t highAddress
> std::ofstream coverageFile;
> @@ -52,9 +52,9 @@ namespace Coverage {
> /* clear out the header and fill it in */
> - memset( &header, 0, sizeof(header) );
> + memset( &header, 0, sizeof( header ) );
> header.ver = 0x1;
> - header.header_length = sizeof(header);
> + header.header_length = sizeof( header );
> header.start = lowAddress;
> header.end = highAddress;
> strcpy( header.desc, "RTEMS Coverage Data" );
> @@ -68,8 +68,8 @@ namespace Coverage {
> throw rld::error( what, "CoverageWriterRTEMS::writeFile" );
> - for ( a=lowAddress ; a < highAddress ; a++ ) {
> - cover = ((coverage->wasExecuted( a )) ? 0x01 : 0);
> + for ( a = lowAddress; a < highAddress; a++ ) {
> + cover = ( ( coverage->wasExecuted( a ) ) ? 0x01 : 0 );
> bytes_before = coverageFile.tellp();
> @@ -78,11 +78,10 @@ namespace Coverage {
> std::cerr << "CoverageWriterRTEMS::writeFile - write to "
> << file
> << " at address 0x%"
> - << std::hex << std::setfill('0')
> - << std::setw(8) << a
> - << std::setfill(' ') << std::dec
> - << " failed"
> - << std::endl;
> + << std::hex << std::setfill( '0' )
> + << std::setw( 8 ) << a
> + << std::setfill( ' ' ) << std::dec
> + << " failed\n";
The "\n" should be std::endl.
