[PATCH] c-user: Add "Cache Manager" chapter
Sebastian Huber
Fri Sep 10 08:49:54 UTC 2021
The Cache Manager directives are available via <rtems.h>. Document most
of them in the Classic API Guide.
Not documented are the following directive since the API is not yet
stable:
* rtems_cache_coherent_allocate()
* rtems_cache_coherent_free()
* rtems_cache_coherent_add_area()
Not documented are the following directive since the directives are not
implemented on maintained platforms:
* rtems_cache_freeze_data()
* rtems_cache_freeze_instruction()
* rtems_cache_unfreeze_data()
* rtems_cache_unfreeze_instruction()
Close #4513.
Here is the updated document for review:
https://ftp.rtems.org/pub/rtems/people/sebh/c-user.pdf
c-user/cache/directives.rst | 665 ++++++++++++++++++++++++++++++++++
c-user/cache/index.rst | 15 +
c-user/cache/introduction.rst | 101 ++++++
c-user/index.rst | 1 +
4 files changed, 782 insertions(+)
create mode 100644 c-user/cache/directives.rst
create mode 100644 c-user/cache/index.rst
create mode 100644 c-user/cache/introduction.rst
diff --git a/c-user/cache/directives.rst b/c-user/cache/directives.rst
new file mode 100644
index 0000000..98349db
--- /dev/null
+++ b/c-user/cache/directives.rst
@@ -0,0 +1,665 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 2016 Pavel Pisa
+.. Copyright (C) 2014, 2021 embedded brains GmbH (http://www.embedded-brains.de)
+.. Copyright (C) 2000, 2008 On-Line Applications Research Corporation (OAR)
+.. This file is part of the RTEMS quality process and was automatically
+.. generated. If you find something that needs to be fixed or
+.. worded better please post a report or patch to an RTEMS mailing list
+.. or raise a bug report:
+.. https://www.rtems.org/bugs.html
+.. For information on updating and regenerating please refer to the How-To
+.. section in the Software Requirements Engineering chapter of the
+.. RTEMS Software Engineering manual. The manual is provided as a part of
+.. a release. For development sources please refer to the online
+.. documentation at:
+.. https://docs.rtems.org
+.. _CacheManagerDirectives:
+Directives
+This section details the directives of the Cache Manager. A subsection is
+dedicated to each of this manager's directives and lists the calling sequence,
+parameters, description, return values, and notes of the directive.
+.. Generated from spec:/rtems/cache/if/flush-multiple-data-lines
+.. raw:: latex
+ \clearpage
+.. index:: rtems_cache_flush_multiple_data_lines()
+.. _InterfaceRtemsCacheFlushMultipleDataLines:
+rtems_cache_flush_multiple_data_lines()
+Flushes the data cache lines covering the memory area.
+.. rubric:: CALLING SEQUENCE:
+.. code-block:: c
+ void rtems_cache_flush_multiple_data_lines( const void *begin, size_t size );
+.. rubric:: PARAMETERS:
+``begin``
+ This parameter is the begin address of the memory area to flush.
+``size``
+ This parameter is the size in bytes of the memory area to flush.
+.. rubric:: DESCRIPTION:
+Dirty data cache lines covering the area are transfered to memory. Depending
+on the cache implementation this may mark the lines as invalid.
+.. rubric:: CONSTRAINTS:
+The following constraints apply to this directive:
+* The directive may be called from within any runtime context.
+* The directive will not cause the calling task to be preempted.
+.. Generated from spec:/rtems/cache/if/invalidate-multiple-data-lines
+.. raw:: latex
+ \clearpage
+.. index:: rtems_cache_invalidate_multiple_data_lines()
+.. _InterfaceRtemsCacheInvalidateMultipleDataLines:
+rtems_cache_invalidate_multiple_data_lines()
+Invalidates the data cache lines covering the memory area.
+.. code-block:: c
+ void rtems_cache_invalidate_multiple_data_lines(
+ const void *begin,
+ size_t size
+``begin``
+ This parameter is the begin address of the memory area to invalidate.
+``size``
+ This parameter is the size in bytes of the memory area to invalidate.
+The cache lines covering the area are marked as invalid. A later read access
+in the area will load the data from memory.
+.. rubric:: NOTES:
+In case the area is not aligned on cache line boundaries, then this operation
+may destroy unrelated data.
+On some systems, the cache lines may be flushed before they are invalidated.
+.. Generated from spec:/rtems/cache/if/invalidate-multiple-instruction-lines
+.. raw:: latex
+ \clearpage
+.. index:: rtems_cache_invalidate_multiple_instruction_lines()
+.. _InterfaceRtemsCacheInvalidateMultipleInstructionLines:
+rtems_cache_invalidate_multiple_instruction_lines()
+Invalidates the instruction cache lines covering the memory area.
+.. code-block:: c
+ void rtems_cache_invalidate_multiple_instruction_lines(
+ size_t size
+``begin``
+``size``
+The cache lines covering the area are marked as invalid. A later instruction
+fetch from the area will result in a load from memory.
+.. rubric:: NOTES:
+In SMP configurations, on processors without instruction cache snooping, this
+operation will invalidate the instruction cache lines on all processors.
+.. Generated from spec:/rtems/cache/if/instruction-sync-after-code-change
+.. raw:: latex
+ \clearpage
+.. index:: rtems_cache_instruction_sync_after_code_change()
+.. _InterfaceRtemsCacheInstructionSyncAfterCodeChange:
+rtems_cache_instruction_sync_after_code_change()
+Ensures necessary synchronization required after code changes.
+.. code-block:: c
+ void rtems_cache_instruction_sync_after_code_change(
+ size_t size
+``begin``
+ This parameter is the begin address of the code area to synchronize.
+``size``
+ This parameter is the size in bytes of the code area to synchronize.
+.. rubric:: NOTES:
+When code is loaded or modified, then most systems require synchronization
+instructions to update the instruction caches so that the loaded or modified
+code is fetched. For example, systems with separate data and instruction
+caches or systems without instruction cache snooping. The directives should be
+used by run time loader for example.
+.. Generated from spec:/rtems/cache/if/get-maximal-line-size
+.. raw:: latex
+ \clearpage
+.. index:: rtems_cache_get_maximal_line_size()
+.. _InterfaceRtemsCacheGetMaximalLineSize:
+rtems_cache_get_maximal_line_size()
+Gets the maximal cache line size in bytes of all caches (data, instruction, or
+unified).
+.. code-block:: c
+ size_t rtems_cache_get_maximal_line_size( void );
+.. rubric:: RETURN VALUES:
+``0``
+ There is no cache present.
+Returns the maximal cache line size in bytes of all caches (data, instruction,
+or unified).
+.. Generated from spec:/rtems/cache/if/get-data-line-size
+.. raw:: latex
+ \clearpage
+.. index:: rtems_cache_get_data_line_size()
+.. _InterfaceRtemsCacheGetDataLineSize:
+rtems_cache_get_data_line_size()
+Gets the data cache line size in bytes.
+.. code-block:: c
+ size_t rtems_cache_get_data_line_size( void );
+``0``
+ There is no data cache present.
+Returns the data cache line size in bytes. For multi-level caches this is the
+maximum of the cache line sizes of all levels.
+.. Generated from spec:/rtems/cache/if/get-instruction-line-size
+.. raw:: latex
+ \clearpage
+.. index:: rtems_cache_get_instruction_line_size()
+.. _InterfaceRtemsCacheGetInstructionLineSize:
+rtems_cache_get_instruction_line_size()
+Gets the instruction cache line size in bytes.
+.. code-block:: c
+ size_t rtems_cache_get_instruction_line_size( void );
+``0``
+ There is no instruction cache present.
+Returns the instruction cache line size in bytes. For multi-level caches this
+is the maximum of the cache line sizes of all levels.
+.. Generated from spec:/rtems/cache/if/get-data-size
+.. raw:: latex
+ \clearpage
+.. index:: rtems_cache_get_data_cache_size()
+.. _InterfaceRtemsCacheGetDataCacheSize:
+rtems_cache_get_data_cache_size()
+Gets the data cache size in bytes for the cache level.
+.. code-block:: c
+ size_t rtems_cache_get_data_cache_size( uint32_t level );
+``level``
+ This parameter is the requested data cache level. The cache level zero
+ specifies the entire data cache.
+``0``
+ There is no data cache present at the requested cache level.
+Returns the data cache size in bytes of the requested cache level.
+.. Generated from spec:/rtems/cache/if/get-instruction-size
+.. raw:: latex
+ \clearpage
+.. index:: rtems_cache_get_instruction_cache_size()
+.. _InterfaceRtemsCacheGetInstructionCacheSize:
+rtems_cache_get_instruction_cache_size()
+Gets the instruction cache size in bytes for the cache level.
+.. code-block:: c
+ size_t rtems_cache_get_instruction_cache_size( uint32_t level );
+``level``
+ This parameter is the requested instruction cache level. The cache level
+ zero specifies the entire instruction cache.
+``0``
+ There is no instruction cache present at the requested cache level.
+Returns the instruction cache size in bytes of the requested cache level.
+.. Generated from spec:/rtems/cache/if/flush-entire-data
+.. raw:: latex
+ \clearpage
+.. index:: rtems_cache_flush_entire_data()
+.. _InterfaceRtemsCacheFlushEntireData:
+rtems_cache_flush_entire_data()
+Flushes the entire data cache.
+.. code-block:: c
+ void rtems_cache_flush_entire_data( void );
+.. Generated from spec:/rtems/cache/if/invalidate-entire-data
+.. raw:: latex
+ \clearpage
+.. index:: rtems_cache_invalidate_entire_data()
+.. _InterfaceRtemsCacheInvalidateEntireData:
+rtems_cache_invalidate_entire_data()
+Invalidates the entire data cache.
+.. code-block:: c
+ void rtems_cache_invalidate_entire_data( void );
+.. Generated from spec:/rtems/cache/if/invalidate-entire-instruction
+.. raw:: latex
+ \clearpage
+.. index:: rtems_cache_invalidate_entire_instruction()
+.. _InterfaceRtemsCacheInvalidateEntireInstruction:
+rtems_cache_invalidate_entire_instruction()
+Invalidates the entire instruction cache.
+.. code-block:: c
+ void rtems_cache_invalidate_entire_instruction( void );
+.. Generated from spec:/rtems/cache/if/enable-data
+.. raw:: latex
+ \clearpage
+.. index:: rtems_cache_enable_data()
+.. _InterfaceRtemsCacheEnableData:
+rtems_cache_enable_data()
+Enables the data cache.
+.. code-block:: c
+ void rtems_cache_enable_data( void );
+.. Generated from spec:/rtems/cache/if/disable-data
+.. raw:: latex
+ \clearpage
+.. index:: rtems_cache_disable_data()
+.. _InterfaceRtemsCacheDisableData:
+rtems_cache_disable_data()
+Disables the data cache.
+.. code-block:: c
+ void rtems_cache_disable_data( void );
+.. Generated from spec:/rtems/cache/if/enable-instruction
+.. raw:: latex
+ \clearpage
+.. index:: rtems_cache_enable_instruction()
+.. _InterfaceRtemsCacheEnableInstruction:
+rtems_cache_enable_instruction()
+Enables the instruction cache.
+.. code-block:: c
+ void rtems_cache_enable_instruction( void );
+.. Generated from spec:/rtems/cache/if/disable-instruction
+.. raw:: latex
+ \clearpage
+.. index:: rtems_cache_disable_instruction()
+.. _InterfaceRtemsCacheDisableInstruction:
+rtems_cache_disable_instruction()
+Disables the instruction cache.
+.. code-block:: c
+ void rtems_cache_disable_instruction( void );
+.. Generated from spec:/rtems/cache/if/aligned-malloc
+.. raw:: latex
+ \clearpage
+.. index:: rtems_cache_aligned_malloc()
+.. _InterfaceRtemsCacheAlignedMalloc:
+rtems_cache_aligned_malloc()
+Allocates memory from the C Program Heap which begins at a cache line boundary.
+.. code-block:: c
+ void *rtems_cache_aligned_malloc( size_t size );
+``size``
+ This parameter is the size in bytes of the memory area to allocate.
+`NULL <https://en.cppreference.com/w/c/types/NULL>`_
+ There is not enough memory available to satisfy the allocation request.
+Returns the begin address of the allocated memory. The begin address is on a
+cache line boundary.
+* The directive may be called from within device driver initialization context.
+* The directive may be called from within task context.
+* The directive may obtain and release the object allocator mutex. This may
+ cause the calling task to be preempted.
diff --git a/c-user/cache/index.rst b/c-user/cache/index.rst
index 0000000..c8f7263
--- /dev/null
+++ b/c-user/cache/index.rst
@@ -0,0 +1,15 @@
+.. Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+.. index:: cache
+.. _RTEMSAPIClassicCache:
+Cache Manager
+.. toctree::
+ introduction
+ directives
diff --git a/c-user/cache/introduction.rst b/c-user/cache/introduction.rst
index 0000000..6cae4b2
--- /dev/null
+++ b/c-user/cache/introduction.rst
@@ -0,0 +1,101 @@
+.. Generated from spec:/rtems/cache/if/group
+.. _CacheManagerIntroduction:
+Introduction
+.. The following list was generated from:
+.. spec:/rtems/cache/if/flush-multiple-data-lines
+.. spec:/rtems/cache/if/invalidate-multiple-data-lines
+.. spec:/rtems/cache/if/invalidate-multiple-instruction-lines
+.. spec:/rtems/cache/if/instruction-sync-after-code-change
+.. spec:/rtems/cache/if/get-maximal-line-size
+.. spec:/rtems/cache/if/get-data-line-size
+.. spec:/rtems/cache/if/get-instruction-line-size
+.. spec:/rtems/cache/if/get-data-size
+.. spec:/rtems/cache/if/get-instruction-size
+.. spec:/rtems/cache/if/flush-entire-data
+.. spec:/rtems/cache/if/invalidate-entire-data
+.. spec:/rtems/cache/if/invalidate-entire-instruction
+.. spec:/rtems/cache/if/enable-data
+.. spec:/rtems/cache/if/disable-data
+.. spec:/rtems/cache/if/enable-instruction
+.. spec:/rtems/cache/if/disable-instruction
+.. spec:/rtems/cache/if/aligned-malloc
+The Cache Manager provides functions to perform maintenance operations for data
+and instruction caches.
+The actual actions of the Cache Manager operations depend on the hardware and
+the implementation provided by the CPU architecture port or a board support
+package. Cache implementations tend to be highly hardware dependent. The
+directives provided by the Cache Manager are:
+* :ref:`InterfaceRtemsCacheFlushMultipleDataLines` - Flushes the data cache
+ lines covering the memory area.
+* :ref:`InterfaceRtemsCacheInvalidateMultipleDataLines` - Invalidates the data
+ cache lines covering the memory area.
+* :ref:`InterfaceRtemsCacheInvalidateMultipleInstructionLines` - Invalidates
+ the instruction cache lines covering the memory area.
+* :ref:`InterfaceRtemsCacheInstructionSyncAfterCodeChange` - Ensures necessary
+ synchronization required after code changes.
+* :ref:`InterfaceRtemsCacheGetMaximalLineSize` - Gets the maximal cache line
+ size in bytes of all caches (data, instruction, or unified).
+* :ref:`InterfaceRtemsCacheGetDataLineSize` - Gets the data cache line size in
+ bytes.
+* :ref:`InterfaceRtemsCacheGetInstructionLineSize` - Gets the instruction cache
+ line size in bytes.
+* :ref:`InterfaceRtemsCacheGetDataCacheSize` - Gets the data cache size in
+ bytes for the cache level.
+* :ref:`InterfaceRtemsCacheGetInstructionCacheSize` - Gets the instruction
+ cache size in bytes for the cache level.
+* :ref:`InterfaceRtemsCacheFlushEntireData` - Flushes the entire data cache.
+* :ref:`InterfaceRtemsCacheInvalidateEntireData` - Invalidates the entire data
+ cache.
+* :ref:`InterfaceRtemsCacheInvalidateEntireInstruction` - Invalidates the
+ entire instruction cache.
+* :ref:`InterfaceRtemsCacheEnableData` - Enables the data cache.
+* :ref:`InterfaceRtemsCacheDisableData` - Disables the data cache.
+* :ref:`InterfaceRtemsCacheEnableInstruction` - Enables the instruction cache.
+* :ref:`InterfaceRtemsCacheDisableInstruction` - Disables the instruction
+ cache.
+* :ref:`InterfaceRtemsCacheAlignedMalloc` - Allocates memory from the C Program
+ Heap which begins at a cache line boundary.
diff --git a/c-user/index.rst b/c-user/index.rst
index ae782f0..385ea95 100644
--- a/c-user/index.rst
+++ b/c-user/index.rst
@@ -45,6 +45,7 @@ RTEMS Classic API Guide (|version|).
dual-ported-memory/index
io/index
kernel-character-io/index
+ cache/index
fatal-error/index
board_support_packages
user-extensions/index
2.31.1
