[PATCH] rtems: Generate <rtems/extension.h>
Sebastian Huber
Fri Sep 10 09:40:13 UTC 2021
Hello Chris,
thanks for the review.
On 10/09/2021 10:55, Chris Johns wrote:
> Nice set of changes. My comments are below ....
> On 10/9/21 6:11 pm, Sebastian Huber wrote:
>> Remove the duplicated description which is an out dated copy and paste
>> from the Classic API Guide. Instead, thoroughly document the individual
>> extensions.
>> Change license to BSD-2-Clause according to file histories and
>> documentation re-licensing agreement.
>> Update #3899.
>> Update #3993.
>> cpukit/include/rtems/extension.h | 758 ++++++++++++++++++++++++-------
>> 1 file changed, 583 insertions(+), 175 deletions(-)
>> diff --git a/cpukit/include/rtems/extension.h b/cpukit/include/rtems/extension.h
>> index 6f97ebe24c..ceb8eb9a1f 100644
>> --- a/cpukit/include/rtems/extension.h
>> +++ b/cpukit/include/rtems/extension.h
>> -typedef Internal_errors_Source rtems_fatal_source;
>> + * @ingroup RTEMSAPIClassicUserExt
>> + * @brief Deletes the extension set.
>> + * @param id is the extension set identifier.
>> + * This directive deletes the extension set specified by ``id``.
>> + * @retval ::RTEMS_SUCCESSFUL The requested operation was successful.
>> + * @retval ::RTEMS_INVALID_ID There was no extension set associated with the
>> + * identifier specified by ``id``.
>> + * @par Notes
>> + * The ESCB for the deleted extension set is reclaimed by RTEMS.
> ESCB? Can the definition to be local to here rather than needing to reach for
> the mouse, a browser, working internet link, a built doxygen .... :)
In the manuals you have a link to a glossary entry. This feature is not
yet implemented for the Doxygen output.
>> + * @par Constraints
>> + * @parblock
>> + * The following constraints apply to this directive:
>> + * * The directive may be called from within device driver initialization
>> + * context.
> Seem a little to ""specread"" .. maybe .. "during device driver initialization"?
This phrase is already used in a lot of directives. If we would like to
change this, then this should be done in a separate patch set:
https://git.rtems.org/rtems-central/tree/spec/constraint/directive-ctx-devinit.yml
>> + * * The directive may be called from within task context.
> Specread ?? ... "within task context" ... "within a task's context" ?
Same as above:
https://git.rtems.org/rtems-central/tree/spec/constraint/directive-ctx-task.yml
>> + * * The directive may obtain and release the object allocator mutex. This may
>> + * cause the calling task to be preempted.
> Block or preempted? I assume the task may be preempted before making the call?
The obtain will block the task, if the mutex is already owned by another
task:
https://git.rtems.org/rtems-central/tree/spec/constraint/object-allocator.yml
This phrase should be improved in a separate patch set.
> Do we assume task and thread and inter-changeable?
Yes, task is used mainly for Classic API tasks, and threads for tasks in
general.
>> + * * The calling task does not have to be the task that created the object.
>> + * Any local task that knows the object identifier can delete the object.
>> + * @endparblock
>> +rtems_status_code rtems_extension_delete( rtems_id id );
>> +/* Generated from spec:/rtems/userext/if/fatal */
>> + * @brief Fatal extensions are invoked when the system should terminate.
> Should? Is it too late by the time the call is being made?
Yes, should, the fatal extension can prevent a system termination. An
example is the POSIX task exitted extension.
>> + * @param source is the system termination source. The source indicates the
>> + * component which caused the system termination request, see
>> + * ::rtems_fatal_source. The system termination code may provide additional
>> + * information related to the system termination request.
>> + * @param always_set_to_false is a value equal to false.
>> + * @param code is the system termination code. This value must be interpreted
>> + * with respect to the source.
>> + * @par Notes
>> + * @parblock
>> + * The fatal extensions are invoked in extension forward order.
> What does forward order mean?
This is in the glossary:
https://docs.rtems.org/branches/master/c-user/glossary.html#term-extension-forward-order
>> + * The fatal extension should be extremely careful with respect to the RTEMS
>> + * directives it calls. Depending on the system termination source, the system
>> + * may be in an undefined and corrupt state.
> Where is the list defined that is means "undefined and corrupt"?
You have to look at the system termination source documentation to
figure this out.
>> + * It is recommended to register fatal extensions through initial extension
>> + * sets, see #CONFIGURE_INITIAL_EXTENSIONS.
>> + * @endparblock
>> +typedef User_extensions_fatal_extension rtems_fatal_extension;
>> +/* Generated from spec:/rtems/userext/if/fatal-code */
>> + * @brief This integer type represents system termination codes.
>> + * This integer type is large enough to store a 32-bit integer or a pointer.
>> + * @par Notes
>> + * The interpretation of a system termination code depends on the system
>> + * termination source, see ::rtems_fatal_source.
>> typedef Internal_errors_t rtems_fatal_code;
>> +/* Generated from spec:/rtems/userext/if/fatal-source */
>> + * @brief This enumeration represents system termination sources.
>> + * @par Notes
>> + * The system termination code may provide additional information depending on
>> + * the system termination source, see ::rtems_fatal_code.
>> +typedef Internal_errors_Source rtems_fatal_source;
>> +/* Generated from spec:/rtems/userext/if/ident */
>> - * @brief Creates an extension set object.
>> + * @brief Identifies an extension set by the object name.
>> + * @param name is the object name to look up.
>> + * @param[out] id is the pointer to an ::rtems_id object. When the directive
>> + * call is successful, the object identifier of an object with the specified
>> + * name will be stored in this object.
>> + * This directive obtains an extension set identifier associated with the
>> + * extension set name specified in ``name``.
>> + * @retval ::RTEMS_INVALID_ADDRESS The ``id`` parameter was NULL.
>> + * @retval ::RTEMS_INVALID_NAME The ``name`` parameter was 0.
>> + * @retval ::RTEMS_INVALID_NAME There was no object with the specified name on
>> + * the local node.
>> - * This directive creates a extension set object from the extension table
>> - * @a extension_table. The assigned extension set identifier is returned in
>> - * @a id. The identifier is used to access this extension set in other
>> - * extension set related directives. The name @a name will be assigned to the
>> - * extension set object.
>> + * @par Notes
>> + * @parblock
>> + * If the extension set name is not unique, then the extension set identifier
>> + * will match the first extension set with that name in the search order.
>> + * However, this extension set identifier is not guaranteed to correspond to
>> + * the desired extension set.
> and the extension set identifier is not guaranteed to correspond to
Yes, we change change this phrase, however, this is used in all the
object identification directives. So, this should be done in a separate
patch set.
>> + * The objects are searched from lowest to the highest index. Only the local
>> + * node is searched.
>> + * The extension set identifier is used with other extension related directives
>> + * to access the extension set.
>> + * @endparblock
>> + * @parblock
>> + * context.
>> + * * The directive will not cause the calling task to be preempted.
> As above.
This is the generic phrase that a directive will perform a scheduler
operation:
https://git.rtems.org/rtems-central/tree/spec/constraint/directive-no-preempt.yml
>> + * @endparblock
>> +rtems_status_code rtems_extension_ident( rtems_name name, rtems_id *id );
>> +/* Generated from spec:/rtems/userext/if/table */
>> + * @brief The extensions table contains a set of extensions which may be
>> + * registered in the system through the #CONFIGURE_INITIAL_EXTENSIONS
>> + * application configuration option or the rtems_extension_create()
>> + * directive.
>> +typedef User_extensions_Table rtems_extensions_table;
>> +/* Generated from spec:/rtems/userext/if/create */
>> + * @brief Creates an extension set.
>> + * @param name is the object name of the extension set.
>> + * @param extension_table is the table with the extensions to be used by the
>> + * extension set.> + *
>> + * call is successful, the identifier of the created extension set will be
>> + * stored in this object.
>> + * This directive creates an extension set which resides on the local node.
>> + * The extension set has the user-defined object name specified in ``name``.
>> + * The assigned object identifier is returned in ``id``. This identifier is
>> + * used to access the extension set with other extension set related
>> + * directives.
>> + * The extension set is initialized using the extension table specified in
>> + * ``extension_table``.
>> + * @retval ::RTEMS_INVALID_NAME The ``name`` parameter was invalid.
>> + * @retval ::RTEMS_INVALID_ADDRESS The ``extension_table`` parameter was NULL.
>> + * @retval ::RTEMS_TOO_MANY There was no inactive object available to create an
>> + * extension set. The number of extension sets available to the application
>> + * is configured through the #CONFIGURE_MAXIMUM_USER_EXTENSIONS application
>> + * configuration option.
>> + * @par Notes
>> + * @parblock
>> + * The user-provided extension set table is not used after the return of the
>> + * directive.
>> * Newly created extension sets are immediately installed and are invoked upon
>> * the next system event supporting an extension.
> As a set? That is all handlers provided are active at the same time?
All except the task switch extension.
>> - * This directive will not cause the calling task to be preempted.
>> + * An alternative to dynamically created extension sets are initial extensions,
>> + * see #CONFIGURE_INITIAL_EXTENSIONS. Initial extensions are recommended for
>> + * extension sets which provide a fatal error extension.
>> + * For control and maintenance of the extension set, RTEMS allocates a ESCB
>> + * from the local ESCB free pool and initializes it.
>> + * @endparblock
>> + * @parblock
>> - * @retval RTEMS_SUCCESSFUL Extension set created successfully.
>> - * @retval RTEMS_INVALID_ADDRESS Identifier pointer is @c NULL.
>> - * @retval RTEMS_INVALID_NAME Invalid extension set name.
>> - * @retval RTEMS_TOO_MANY Too many extension sets created.
>> + * context.
>> + * * The number of extension sets available to the application is configured
>> + * through the #CONFIGURE_MAXIMUM_USER_EXTENSIONS application configuration
>> + * option.
>> + * @endparblock
> Is having handlers entries set to NULL discussed? That is specific tables for
> unique non-overlapping functions?
No, I will add this.
>> rtems_status_code rtems_extension_create(
>> rtems_name name,
>> @@ -192,47 +313,334 @@ rtems_status_code rtems_extension_create(
>> rtems_id *id
>> +/* Generated from spec:/rtems/userext/if/task-begin */
>> - * @brief Identifies an extension set object by a name.
>> + * @brief Task begin extensions are invoked when a task begins execution.
>> - * This directive obtains an extension set identifier in @a id associated with
>> - * the extension set name @a name. If the extension set name is not unique,
>> - * then the extension set identifier will match one of the extension sets with
>> - * that name. However, this extension set identifier is not guaranteed to
>> - * correspond to the desired extension set. The extension set identifier is
>> - * used to access this extension set in other extension set related directives.
>> + * @param executing is the TCB of the executing thread.
>> + * @par Notes
>> + * @parblock
>> + * The task begin extensions are invoked in extension forward order.
>> - * @retval RTEMS_SUCCESSFUL Extension set identified successfully.
>> - * @retval RTEMS_INVALID_NAME Extension set name not found or invalid name.
>> + * Task begin extensions are invoked with thread dispatching enabled. This
>> + * allows the use of dynamic memory allocation, creation of POSIX keys, and use
>> + * of C++ thread-local storage. Blocking synchronization primitives are
>> + * allowed also.
>> + * The task begin extensions are invoked before the global construction.
> Construction of what?
This is the term used by the Classic API Guide:
https://docs.rtems.org/branches/master/c-user/initialization/operations.html#global-construction
>> + * The task begin extensions may be called as a result of a task restart
>> + * through rtems_task_restart().
>> + * @endparblock
>> + * @parblock
>> + * The following constraints apply to functions of this type:
>> + * * Thread dispatching is enabled.
>> + * * The executing thread is not the owner of the object allocator mutex.
>> + * @endparblock
>> -rtems_status_code rtems_extension_ident(
>> - rtems_name name,
>> - rtems_id *id
>> +typedef User_extensions_thread_begin_extension rtems_task_begin_extension;
>> +/* Generated from spec:/rtems/userext/if/task-create */
>> - * @brief Deletes an extension set object specified by the identifier @a id.
>> + * @brief Task create extensions are invoked when a task is created.
>> + * @param executing is the TCB of the executing thread. When the idle thread
>> + * is created, the executing thread is equal to NULL.
>> + * @param created is the TCB of the created thread.
>> + * @return Returns true, if the task create extension was successful, otherwise
>> + * false.
>> + * @par Notes
>> + * @parblock
>> + * The task create extensions are invoked in extension forward order.
> As above.
>> - * Any subsequent references to the extension's name and identifier are
>> - * invalid.
>> + * The task create extensions are invoked after a new task has been completely
>> + * initialized, but before it is started.
>> + * While normal tasks are created, the executing thread is the owner of the
>> + * object allocator mutex. The object allocator mutex allows nesting, so the
>> + * normal memory allocation routines can be used allocate memory for the
>> + * created thread.
>> - * @retval RTEMS_SUCCESSFUL Extension set deleted successfully.
>> - * @retval RTEMS_INVALID_ID Invalid extension set identifier.
>> + * If the task create extension returns false, then the task create operation
>> + * stops immediately and the entire task create operation will fail. In this
>> + * case, all task delete extensions are invoked, see
>> + * ::rtems_task_delete_extension.
>> + * @endparblock
>> + * @parblock
>> + * * While the system is initialized, thread dispatching is disabled.
>> + * * While the system is in the multitasking state, thread dispatching is
>> + * enabled.
>> + * * While an idle thread or another internal system thread is created, the
>> + * object allocator mutex has no owner.
>> + * * While a task is created by rtems_task_create(), the executing thread is
>> + * the owner of the object allocator mutex.
>> + * * While a task is constructed by rtems_task_construct(), the executing
>> + * thread is the owner of the object allocator mutex.
>> + * * While a task is created by pthread_create(), the executing thread is the
>> + * owner of the object allocator mutex.
>> + * @endparblock
>> -rtems_status_code rtems_extension_delete(
>> - rtems_id id
>> +typedef User_extensions_thread_create_extension rtems_task_create_extension;
>> +/* Generated from spec:/rtems/userext/if/task-delete */
>> + * @brief Task delete extensions are invoked when a task is deleted.
>> + * @param executing is the TCB of the executing thread. If the idle thread is
>> + * created and one of the initial task create extension fails, then the
>> + * executing thread is equal to NULL.
>> + * @param created is the TCB of the deleted thread. The executing and deleted
>> + * arguments are never equal.
>> + * @par Notes
>> + * @parblock
>> + * The task delete extensions are invoked in extension reverse order.
>> + * The task delete extensions are invoked by task create directives before an
>> + * attempt to allocate a TCB is made.
>> + * If a task create extension failed, then a task delete extension may be
>> + * invoked without a previous invocation of the corresponding task create
>> + * extension of the extension set.
>> + * @endparblock
>> + * @parblock
>> + * enabled.
>> + * @endparblock
>> +typedef User_extensions_thread_delete_extension rtems_task_delete_extension;
>> +/* Generated from spec:/rtems/userext/if/task-exitted */
>> + * @brief Task exitted extensions are invoked when a task entry returns.
>> + * @par Notes
>> + * The task exitted extensions are invoked in extension forward order.
>> + * @parblock
>> + * @endparblock
>> +typedef User_extensions_thread_exitted_extension rtems_task_exitted_extension;
>> +/* Generated from spec:/rtems/userext/if/task-restart */
>> + * @brief Task restart extensions are invoked when a task restarts.
>> + * @param restarted is the TCB of the executing thread. Yes, the executing
>> + * thread.
>> + * @par Notes
>> + * @parblock
>> + * The task restart extensions are invoked in extension forward order.
>> + * The task restart extensions are invoked in the context of the restarted
>> + * thread right before the execution context is reloaded. The thread stack
>> + * reflects the previous execution context.
>> + * Thread restart and delete requests issued by restart extensions lead to
>> + * recursion.
>> + * @endparblock
>> + * @parblock
>> + * * Thread life is protected.
>> + * @endparblock
>> +typedef User_extensions_thread_restart_extension rtems_task_restart_extension;
>> +/* Generated from spec:/rtems/userext/if/task-start */
>> + * @brief Task start extensions are invoked when a task was made ready for the
>> + * first time.
>> + * @param started is the TCB of the started thread.
>> + * @par Notes
>> + * @parblock
>> + * The task start extensions are invoked in extension forward order.
>> + * In SMP configurations, the thread may already run on another processor
>> + * before the task start extensions are actually invoked. Task switch and task
>> + * begin extensions may run before or in parallel with the thread start
>> + * extension in SMP configurations, see ::rtems_task_switch_extension and
>> + * ::rtems_task_begin_extension.
> I did not know this about SMP. Which context is this handler invoked in? The
> terminate below describes this nicely.
See below for the context:
>> + * @endparblock
>> + * @parblock
>> + * * Thread dispatching is disabled.
>> + * @endparblock
>> +typedef User_extensions_thread_start_extension rtems_task_start_extension;
>> +/* Generated from spec:/rtems/userext/if/task-switch */
>> + * @brief Task switch extensions are invoked when a thread switch from an
>> + * executing thread to a heir thread takes place.
>> + * @param executing is the TCB of the executing thread. In SMP configurations,
>> + * this is the previously executing thread also known as the ancestor thread.
>> + * @param heir is the TCB of the heir thread. In SMP configurations, this is
>> + * the executing thread.
>> + * @par Notes
>> + * @parblock
>> + * The task switch extensions are invoked in extension forward order.
>> + * The invocation conditions of the task switch extensions depend on whether
>> + * RTEMS was build with SMP support enabled or disabled. A user must pay
> Built not build. It is "was built" or "is built"?
>> + * attention to the differences to correctly implement a task switch extension.
>> + * Where the system was built with SMP support disabled, the task switch
> Was or is? A few other spots below depending on what is decided.
You are the native speaker ;-)
This phrase is used in several places. I don't know what is better
English "was built" or "is built".
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
