[PATCH] rtems: Generate <rtems/extension.h>
Fri Sep 10 08:55:26 UTC 2021
Nice set of changes. My comments are below ....
On 10/9/21 6:11 pm, Sebastian Huber wrote:
> Remove the duplicated description which is an out dated copy and paste
> from the Classic API Guide.  Instead, thoroughly document the individual
> extensions.
> Change license to BSD-2-Clause according to file histories and
> documentation re-licensing agreement.
> Update #3899.
> Update #3993.
>  cpukit/include/rtems/extension.h | 758 ++++++++++++++++++++++++-------
>  1 file changed, 583 insertions(+), 175 deletions(-)
> diff --git a/cpukit/include/rtems/extension.h b/cpukit/include/rtems/extension.h
> index 6f97ebe24c..ceb8eb9a1f 100644
> --- a/cpukit/include/rtems/extension.h
> +++ b/cpukit/include/rtems/extension.h
> @@ -1,190 +1,311 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
>   * @file
>   * @ingroup RTEMSImplClassicUserExt
> - * @brief User Extensions API.
> + * @brief This header file defines the User Extensions Manager API.
> + * Copyright (C) 2009, 2021 embedded brains GmbH (http://www.embedded-brains.de)
> + * Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> - *  COPYRIGHT (c) 1989-2008.
> - *  On-Line Applications Research Corporation (OAR).
> + * This file is part of the RTEMS quality process and was automatically
> + * generated.  If you find something that needs to be fixed or
> + * worded better please post a report or patch to an RTEMS mailing list
> + * or raise a bug report:
> + * https://www.rtems.org/bugs.html
> + * For information on updating and regenerating please refer to the How-To
> + * section in the Software Requirements Engineering chapter of the
> + * RTEMS Software Engineering manual.  The manual is provided as a part of
> + * a release.  For development sources please refer to the online
> + * documentation at:
> - *  The license and distribution terms for this file may be
> - *  found in the file LICENSE in this distribution or at
> - *  http://www.rtems.org/license/LICENSE.
> + * https://docs.rtems.org
> +/* Generated from spec:/rtems/userext/if/header */
>  #ifndef _RTEMS_EXTENSION_H
>  #define _RTEMS_EXTENSION_H
>  #include <rtems/rtems/status.h>
>  #include <rtems/rtems/types.h>
> -#include <rtems/score/userext.h>
> +#include <rtems/score/interr.h>
> +#include <rtems/score/userextdata.h>
>  #ifdef __cplusplus
>  extern "C" {
>  #endif
> +/* Generated from spec:/rtems/userext/if/group */
>   * @defgroup RTEMSAPIClassicUserExt User Extensions Manager
>   * @ingroup RTEMSAPIClassic
>   * @brief The User Extensions Manager allows the application developer to
> - * augment the executive by allowing them to supply extension routines which
> - * are invoked at critical system events.
> - * @section RTEMSAPIClassicUserExtSets Extension Sets
> - * An @ref User_extensions_Table "extension set" is defined as a set of
> - * routines which are invoked at each of the critical system events at which
> - * user extension routines are invoked.  Together a set of these routines
> - * typically perform a specific functionality such as performance monitoring or
> - * debugger support.
> - * RTEMS allows the user to have multiple extension sets active at the same
> - * time. First, a single static extension set may be defined as the
> - * application's User Extension Table which is included as part of the
> - * Configuration Table. This extension set is active for the entire life of the
> - * system and may not be deleted. This extension set is especially important
> - * because it is the only way the application can provided a fatal error
> - * extension which is invoked if RTEMS fails during the
> - * rtems_initialize_data_structures() directive. The static extension set is
> - * optional and may be configured as @c NULL if no static extension set is
> - * required.
> - * Second, the user can install dynamic extensions using the
> - * rtems_extension_create() directive. These extensions are RTEMS objects in
> - * that they have a name, an ID, and can be dynamically created and deleted. In
> - * contrast to the static extension set, these extensions can only be created
> - * and installed after the rtems_initialize_data_structures() directive
> - * successfully completes execution. Dynamic extensions are useful for
> - * encapsulating the functionality of an extension set. For example, the
> - * application could use extensions to manage a special coprocessor, do
> - * performance monitoring, and to do stack bounds checking. Each of these
> - * extension sets could be written and installed independently of the others.
> - * All user extensions are optional and RTEMS places no naming restrictions on
> - * the user. The user extension entry points are copied into an internal RTEMS
> - * structure. This means the user does not need to keep the table after
> - * creating it, and changing the handler entry points dynamically in a table
> - * once created has no effect. Creating a table local to a function can save
> - * space in space limited applications.
> - * Extension switches do not effect the context switch overhead if no switch
> - * handler is installed.
> - * @section RTEMSAPIClassicUserExtTCB Task Control Block Area
> - * RTEMS provides for a pointer to a user-defined data area for each extension
> - * set to be linked to each task's control block (TCB). This area is only
> - * available for the dynamic extensions. This set of pointers is an extension
> - * of the TCB and can be used to store additional data required by the user's
> - * extension functions.
> - * The TCB extension is an array of pointers in the TCB. The index into the
> - * table can be obtained from the extension identifier returned when the
> - * extension is created:
> - * @code
> - * rtems_tcb *task = some_task;
> - * size_t index = rtems_object_id_get_index(extension_id);
> - * void *extension_data = task->extensions [index];
> - * @endcode
> - * The number of pointers in the area is the same as the number of user
> - * extension sets configured. This allows an application to augment the TCB
> - * with user-defined information. For example, an application could implement
> - * task profiling by storing timing statistics in the TCB's extended memory
> - * area. When a task context switch is being executed, the task switch
> - * extension could read a real-time clock to calculate how long the task being
> - * swapped out has run as well as timestamp the starting time for the task
> - * being swapped in.
> - * If used, the extended memory area for the TCB should be allocated and the
> - * TCB extension pointer should be set at the time the task is created or
> - * started by either the task create or task start extension. The application
> - * is responsible for managing this extended memory area for the TCBs. The
> - * memory may be reinitialized by the task restart extension and should be
> - * deallocated by the task delete extension when the task is deleted. Since the
> - * TCB extension buffers would most likely be of a fixed size, the RTEMS
> - * partition manager could be used to manage the application's extended memory
> - * area. The application could create a partition of fixed size TCB extension
> - * buffers and use the partition manager's allocation and deallocation
> - * directives to obtain and release the extension buffers.
> - * @section RTEMSAPIClassicUserExtOrder Order of Invokation
> - * When one of the critical system events occur, the user extensions are
> - * invoked in either @a forward or @a reverse order. Forward order indicates
> - * that the static extension set is invoked followed by the dynamic extension
> - * sets in the order in which they were created. Reverse order means that the
> - * dynamic extension sets are invoked in the opposite of the order in which
> - * they were created followed by the static extension set. By invoking the
> - * extension sets in this order, extensions can be built upon one another. At
> - * the following system events, the extensions are invoked in forward order:
> - * - Task creation
> - * - Task start
> - * - Task restart
> - * - Task context switch
> - * - Post task context switch
> - * - Task begins to execute
> - * At the following system events, the extensions are invoked in reverse order:
> - * - Task exit
> - * - Task deletion
> - * - Fatal error detection
> - * At these system events, the extensions are invoked in reverse order to
> - * insure that if an extension set is built upon another, the more complicated
> - * extension is invoked before the extension set it is built upon. For example,
> - * by invoking the static extension set last it is known that the "system"
> - * fatal error extension will be the last fatal error extension executed.
> - * Another example is use of the task delete extension by the Standard C
> - * Library. Extension sets which are installed after the Standard C Library
> - * will operate correctly even if they utilize the C Library because the C
> - * Library's task delete extension is invoked after that of the other
> - * extensions.
> -typedef User_extensions_thread_create_extension   rtems_task_create_extension;
> -typedef User_extensions_thread_delete_extension   rtems_task_delete_extension;
> -typedef User_extensions_thread_start_extension    rtems_task_start_extension;
> -typedef User_extensions_thread_restart_extension  rtems_task_restart_extension;
> -typedef User_extensions_thread_switch_extension   rtems_task_switch_extension;
> -typedef User_extensions_thread_begin_extension    rtems_task_begin_extension;
> -typedef User_extensions_thread_exitted_extension  rtems_task_exitted_extension;
> -typedef User_extensions_fatal_extension           rtems_fatal_extension;
> -typedef User_extensions_thread_terminate_extension rtems_task_terminate_extension;
> + *   augment the executive by allowing them to supply extension routines which
> + *   are invoked at critical system events.
> -typedef User_extensions_Table                     rtems_extensions_table;
> +/* Generated from spec:/rtems/userext/if/delete */
> -typedef Internal_errors_Source rtems_fatal_source;
> + * @ingroup RTEMSAPIClassicUserExt
> + * @brief Deletes the extension set.
> + * @param id is the extension set identifier.
> + * This directive deletes the extension set specified by ``id``.
> + * @retval ::RTEMS_SUCCESSFUL The requested operation was successful.
> + * @retval ::RTEMS_INVALID_ID There was no extension set associated with the
> + *   identifier specified by ``id``.
> + * @par Notes
> + * The ESCB for the deleted extension set is reclaimed by RTEMS.
ESCB? Can the definition to be local to here rather than needing to reach for
the mouse, a browser, working internet link, a built doxygen .... :)
> + * @par Constraints
> + * @parblock
> + * The following constraints apply to this directive:
> + * * The directive may be called from within device driver initialization
> + *   context.
Seem a little to ""specread"" .. maybe .. "during device driver initialization"?
> + * * The directive may be called from within task context.
Specread ?? ... "within task context" ... "within a task's context" ?
> + * * The directive may obtain and release the object allocator mutex.  This may
> + *   cause the calling task to be preempted.
Block or preempted? I assume the task may be preempted before making the call?
Do we assume task and thread and inter-changeable?
> + * * The calling task does not have to be the task that created the object.
> + *   Any local task that knows the object identifier can delete the object.
> + * @endparblock
> +rtems_status_code rtems_extension_delete( rtems_id id );
> +/* Generated from spec:/rtems/userext/if/fatal */
> + * @brief Fatal extensions are invoked when the system should terminate.
Should? Is it too late by the time the call is being made?
> + * @param source is the system termination source.  The source indicates the
> + *   component which caused the system termination request, see
> + *   ::rtems_fatal_source.  The system termination code may provide additional
> + *   information related to the system termination request.
> + * @param always_set_to_false is a value equal to false.
> + * @param code is the system termination code.  This value must be interpreted
> + *   with respect to the source.
> + * @par Notes
> + * @parblock
> + * The fatal extensions are invoked in extension forward order.
What does forward order mean?
> + * The fatal extension should be extremely careful with respect to the RTEMS
> + * directives it calls.  Depending on the system termination source, the system
> + * may be in an undefined and corrupt state.
Where is the list defined that is means "undefined and corrupt"?
> + * It is recommended to register fatal extensions through initial extension
> + * sets, see #CONFIGURE_INITIAL_EXTENSIONS.
> + * @endparblock
> +typedef User_extensions_fatal_extension rtems_fatal_extension;
> +/* Generated from spec:/rtems/userext/if/fatal-code */
> + * @brief This integer type represents system termination codes.
> + * This integer type is large enough to store a 32-bit integer or a pointer.
> + * @par Notes
> + * The interpretation of a system termination code depends on the system
> + * termination source, see ::rtems_fatal_source.
>  typedef Internal_errors_t rtems_fatal_code;
> +/* Generated from spec:/rtems/userext/if/fatal-source */
> + * @brief This enumeration represents system termination sources.
> + * @par Notes
> + * The system termination code may provide additional information depending on
> + * the system termination source, see ::rtems_fatal_code.
> +typedef Internal_errors_Source rtems_fatal_source;
> +/* Generated from spec:/rtems/userext/if/ident */
> - * @brief Creates an extension set object.
> + * @brief Identifies an extension set by the object name.
> + * @param name is the object name to look up.
> + * @param[out] id is the pointer to an ::rtems_id object.  When the directive
> + *   call is successful, the object identifier of an object with the specified
> + *   name will be stored in this object.
> + * This directive obtains an extension set identifier associated with the
> + * extension set name specified in ``name``.
> + * @retval ::RTEMS_INVALID_ADDRESS The ``id`` parameter was NULL.
> + * @retval ::RTEMS_INVALID_NAME The ``name`` parameter was 0.
> + * @retval ::RTEMS_INVALID_NAME There was no object with the specified name on
> + *   the local node.
> - * This directive creates a extension set object from the extension table
> - * @a extension_table.  The assigned extension set identifier is returned in
> - * @a id.  The identifier is used to access this extension set in other
> - * extension set related directives.  The name @a name will be assigned to the
> - * extension set object.
> + * @par Notes
> + * @parblock
> + * If the extension set name is not unique, then the extension set identifier
> + * will match the first extension set with that name in the search order.
> + * However, this extension set identifier is not guaranteed to correspond to
> + * the desired extension set.
and the extension set identifier is not guaranteed to correspond to
> + * The objects are searched from lowest to the highest index.  Only the local
> + * node is searched.
> + * The extension set identifier is used with other extension related directives
> + * to access the extension set.
> + * @endparblock
> + * @parblock
> + *   context.
> + * * The directive will not cause the calling task to be preempted.
As above.
> + * @endparblock
> +rtems_status_code rtems_extension_ident( rtems_name name, rtems_id *id );
> +/* Generated from spec:/rtems/userext/if/table */
> + * @brief The extensions table contains a set of extensions which may be
> + *   registered in the system through the #CONFIGURE_INITIAL_EXTENSIONS
> + *   application configuration option or the rtems_extension_create()
> + *   directive.
> +typedef User_extensions_Table rtems_extensions_table;
> +/* Generated from spec:/rtems/userext/if/create */
> + * @brief Creates an extension set.
> + * @param name is the object name of the extension set.
> + * @param extension_table is the table with the extensions to be used by the
> + *   extension set.> + *
> + *   call is successful, the identifier of the created extension set will be
> + *   stored in this object.
> + * This directive creates an extension set which resides on the local node.
> + * The extension set has the user-defined object name specified in ``name``.
> + * The assigned object identifier is returned in ``id``.  This identifier is
> + * used to access the extension set with other extension set related
> + * directives.
> + * The extension set is initialized using the extension table specified in
> + * ``extension_table``.
> + * @retval ::RTEMS_INVALID_NAME The ``name`` parameter was invalid.
> + * @retval ::RTEMS_INVALID_ADDRESS The ``extension_table`` parameter was NULL.
> + * @retval ::RTEMS_TOO_MANY There was no inactive object available to create an
> + *   extension set.  The number of extension sets available to the application
> + *   is configured through the #CONFIGURE_MAXIMUM_USER_EXTENSIONS application
> + *   configuration option.
> + * @par Notes
> + * @parblock
> + * The user-provided extension set table is not used after the return of the
> + * directive.
>   * Newly created extension sets are immediately installed and are invoked upon
>   * the next system event supporting an extension.
As a set? That is all handlers provided are active at the same time?
> - * This directive will not cause the calling task to be preempted.
> + * An alternative to dynamically created extension sets are initial extensions,
> + * see #CONFIGURE_INITIAL_EXTENSIONS.  Initial extensions are recommended for
> + * extension sets which provide a fatal error extension.
> + * For control and maintenance of the extension set, RTEMS allocates a ESCB
> + * from the local ESCB free pool and initializes it.
> + * @endparblock
> + * @parblock
> - * @retval RTEMS_SUCCESSFUL Extension set created successfully.
> - * @retval RTEMS_INVALID_ADDRESS Identifier pointer is @c NULL.
> - * @retval RTEMS_INVALID_NAME Invalid extension set name.
> - * @retval RTEMS_TOO_MANY Too many extension sets created.
> + *   context.
> + * * The number of extension sets available to the application is configured
> + *   through the #CONFIGURE_MAXIMUM_USER_EXTENSIONS application configuration
> + *   option.
> + * @endparblock
Is having handlers entries set to NULL discussed? That is specific tables for
unique non-overlapping functions?
>  rtems_status_code rtems_extension_create(
>    rtems_name                    name,
> @@ -192,47 +313,334 @@ rtems_status_code rtems_extension_create(
>    rtems_id                     *id
> +/* Generated from spec:/rtems/userext/if/task-begin */
> - * @brief Identifies an extension set object by a name.
> + * @brief Task begin extensions are invoked when a task begins execution.
> - * This directive obtains an extension set identifier in @a id associated with
> - * the extension set name @a name. If the extension set name is not unique,
> - * then the extension set identifier will match one of the extension sets with
> - * that name.  However, this extension set identifier is not guaranteed to
> - * correspond to the desired extension set. The extension set identifier is
> - * used to access this extension set in other extension set related directives.
> + * @param executing is the TCB of the executing thread.
> + * @par Notes
> + * @parblock
> + * The task begin extensions are invoked in extension forward order.
> - * @retval RTEMS_SUCCESSFUL Extension set identified successfully.
> - * @retval RTEMS_INVALID_NAME Extension set name not found or invalid name.
> + * Task begin extensions are invoked with thread dispatching enabled.  This
> + * allows the use of dynamic memory allocation, creation of POSIX keys, and use
> + * of C++ thread-local storage.  Blocking synchronization primitives are
> + * allowed also.
> + * The task begin extensions are invoked before the global construction.
Construction of what?
> + * The task begin extensions may be called as a result of a task restart
> + * through rtems_task_restart().
> + * @endparblock
> + * @parblock
> + * The following constraints apply to functions of this type:
> + * * Thread dispatching is enabled.
> + * * The executing thread is not the owner of the object allocator mutex.
> + * @endparblock
> -rtems_status_code rtems_extension_ident(
> -  rtems_name  name,
> -  rtems_id   *id
> +typedef User_extensions_thread_begin_extension rtems_task_begin_extension;
> +/* Generated from spec:/rtems/userext/if/task-create */
> - * @brief Deletes an extension set object specified by the identifier @a id.
> + * @brief Task create extensions are invoked when a task is created.
> + * @param executing is the TCB of the executing thread.  When the idle thread
> + *   is created, the executing thread is equal to NULL.
> + * @param created is the TCB of the created thread.
> + * @return Returns true, if the task create extension was successful, otherwise
> + *   false.
> + * @par Notes
> + * @parblock
> + * The task create extensions are invoked in extension forward order.
As above.
> - * Any subsequent references to the extension's name and identifier are
> - * invalid.
> + * The task create extensions are invoked after a new task has been completely
> + * initialized, but before it is started.
> + * While normal tasks are created, the executing thread is the owner of the
> + * object allocator mutex.  The object allocator mutex allows nesting, so the
> + * normal memory allocation routines can be used allocate memory for the
> + * created thread.
> - * @retval RTEMS_SUCCESSFUL Extension set deleted successfully.
> - * @retval RTEMS_INVALID_ID Invalid extension set identifier.
> + * If the task create extension returns false, then the task create operation
> + * stops immediately and the entire task create operation will fail.  In this
> + * case, all task delete extensions are invoked, see
> + * ::rtems_task_delete_extension.
> + * @endparblock
> + * @parblock
> + * * While the system is initialized, thread dispatching is disabled.
> + * * While the system is in the multitasking state, thread dispatching is
> + *   enabled.
> + * * While an idle thread or another internal system thread is created, the
> + *   object allocator mutex has no owner.
> + * * While a task is created by rtems_task_create(), the executing thread is
> + *   the owner of the object allocator mutex.
> + * * While a task is constructed by rtems_task_construct(), the executing
> + *   thread is the owner of the object allocator mutex.
> + * * While a task is created by pthread_create(), the executing thread is the
> + *   owner of the object allocator mutex.
> + * @endparblock
> -rtems_status_code rtems_extension_delete(
> -  rtems_id id
> +typedef User_extensions_thread_create_extension rtems_task_create_extension;
> +/* Generated from spec:/rtems/userext/if/task-delete */
> + * @brief Task delete extensions are invoked when a task is deleted.
> + * @param executing is the TCB of the executing thread.  If the idle thread is
> + *   created and one of the initial task create extension fails, then the
> + *   executing thread is equal to NULL.
> + * @param created is the TCB of the deleted thread.  The executing and deleted
> + *   arguments are never equal.
> + * @par Notes
> + * @parblock
> + * The task delete extensions are invoked in extension reverse order.
> + * The task delete extensions are invoked by task create directives before an
> + * attempt to allocate a TCB is made.
> + * If a task create extension failed, then a task delete extension may be
> + * invoked without a previous invocation of the corresponding task create
> + * extension of the extension set.
> + * @endparblock
> + * @parblock
> + *   enabled.
> + * @endparblock
> +typedef User_extensions_thread_delete_extension rtems_task_delete_extension;
> +/* Generated from spec:/rtems/userext/if/task-exitted */
> + * @brief Task exitted extensions are invoked when a task entry returns.
> + * @par Notes
> + * The task exitted extensions are invoked in extension forward order.
> + * @parblock
> + * @endparblock
> +typedef User_extensions_thread_exitted_extension rtems_task_exitted_extension;
> +/* Generated from spec:/rtems/userext/if/task-restart */
> + * @brief Task restart extensions are invoked when a task restarts.
> + * @param restarted is the TCB of the executing thread.  Yes, the executing
> + *   thread.
> + * @par Notes
> + * @parblock
> + * The task restart extensions are invoked in extension forward order.
> + * The task restart extensions are invoked in the context of the restarted
> + * thread right before the execution context is reloaded.  The thread stack
> + * reflects the previous execution context.
> + * Thread restart and delete requests issued by restart extensions lead to
> + * recursion.
> + * @endparblock
> + * @parblock
> + * * Thread life is protected.
> + * @endparblock
> +typedef User_extensions_thread_restart_extension rtems_task_restart_extension;
> +/* Generated from spec:/rtems/userext/if/task-start */
> + * @brief Task start extensions are invoked when a task was made ready for the
> + *   first time.
> + * @param started is the TCB of the started thread.
> + * @par Notes
> + * @parblock
> + * The task start extensions are invoked in extension forward order.
> + * In SMP configurations, the thread may already run on another processor
> + * before the task start extensions are actually invoked.  Task switch and task
> + * begin extensions may run before or in parallel with the thread start
> + * extension in SMP configurations, see ::rtems_task_switch_extension and
> + * ::rtems_task_begin_extension.
I did not know this about SMP. Which context is this handler invoked in? The
terminate below describes this nicely.
> + * @endparblock
> + * @parblock
> + * * Thread dispatching is disabled.
> + * @endparblock
> +typedef User_extensions_thread_start_extension rtems_task_start_extension;
> +/* Generated from spec:/rtems/userext/if/task-switch */
> + * @brief Task switch extensions are invoked when a thread switch from an
> + *   executing thread to a heir thread takes place.
> + * @param executing is the TCB of the executing thread.  In SMP configurations,
> + *   this is the previously executing thread also known as the ancestor thread.
> + * @param heir is the TCB of the heir thread.  In SMP configurations, this is
> + *   the executing thread.
> + * @par Notes
> + * @parblock
> + * The task switch extensions are invoked in extension forward order.
> + * The invocation conditions of the task switch extensions depend on whether
> + * RTEMS was build with SMP support enabled or disabled.  A user must pay
Built not build. It is "was built" or "is built"?
> + * attention to the differences to correctly implement a task switch extension.
> + * Where the system was built with SMP support disabled, the task switch
Was or is? A few other spots below depending on what is decided.
> + * extensions are invoked before the context switch from the currently
> + * executing thread to the heir thread.  The executing is a pointer to the TCB
> + * of the currently executing thread. The heir is a pointer to the TCB of the
> + * heir thread.  The context switch initiated through the multitasking start is
> + * not covered by the task switch extensions.
> + * Where the system was built with SMP support enabled, the task switch
> + * extensions are invoked after the context switch to the heir thread.  The
> + * executing is a pointer to the TCB of the previously executing thread.
> + * Despite the name, this is not the currently executing thread. The heir is a
> + * pointer to the TCB of the newly executing thread. This is the currently
> + * executing thread. The context switches initiated through the multitasking
> + * start are covered by the task switch extensions. The reason for the
> + * differences to uniprocessor configurations is that the context switch may
> + * update the heir thread of the processor.  The task switch extensions are
> + * invoked with maskable interrupts disabled and with ownership of a
> + * processor-specific SMP lock.  Task switch extensions may run in parallel on
> + * multiple processors.  It is recommended to use thread-local or
> + * processor-specific data structures for task switch extensions.  A global SMP
> + * lock should be avoided for performance reasons, see
> + * rtems_interrupt_lock_initialize().
> + * @endparblock
> + * @parblock
> + * * Where the system was built with SMP support enabled, maskable interrupts
> + *   are disabled for the executing thread.
> + * @endparblock
> +typedef User_extensions_thread_switch_extension rtems_task_switch_extension;
> +/* Generated from spec:/rtems/userext/if/task-terminate */
> + * @brief Task terminate extensions are invoked when a task terminates.
> + * @param executing is the TCB of the executing thread.  This is the
> + *   terminating thread.
> + * @par Notes
> + * @parblock
> + * The task terminate extensions are invoked in extension reverse order.
> + * The task terminate extensions are invoked in the context of the terminating
> + * thread right before the thread dispatch to the heir thread should take
> + * place. The thread stack reflects the previous execution context.  The POSIX
> + * cleanup and key destructors execute in this context.
> + * Thread restart and delete requests issued by terminate extensions lead to
> + * recursion.
> + * @endparblock
> + * @parblock
> + * @endparblock
> +typedef User_extensions_thread_terminate_extension rtems_task_terminate_extension;
>  #ifdef __cplusplus
>  #endif
> -#endif
> -/* end of include file */
> +#endif /* _RTEMS_EXTENSION_H */
