[PATCH RSB v1 1/2] rtems-gcc-10-newlib-head.cfg: Add newlib patch
Ryan Long
ryan.long at oarcorp.com
Mon Sep 13 14:51:47 UTC 2021
Adds patch to add sanitation to the padding of bits and size_t types for
AArch64 tools builds with newlib. These changes have been made in ARM, but
newlib has yet to pull them. This can be removed once newlib has pulled
the code.
Updates #4510
rtems/config/tools/rtems-gcc-10-newlib-head.cfg | 3 +++
1 file changed, 3 insertions(+)
diff --git a/rtems/config/tools/rtems-gcc-10-newlib-head.cfg b/rtems/config/tools/rtems-gcc-10-newlib-head.cfg
index 69c4fb5..c54ac52 100644
--- a/rtems/config/tools/rtems-gcc-10-newlib-head.cfg
+++ b/rtems/config/tools/rtems-gcc-10-newlib-head.cfg
@@ -13,6 +13,9 @@
%patch add gcc -p1 https://devel.rtems.org/raw-attachment/ticket/4215/0001-nios2-Remove-custom-instruction-warnings.patch
%hash sha512 0001-nios2-Remove-custom-instruction-warnings.patch afd8a5e6bdcc5b75d5fbbf558bdf56ccac400521a6eec9d88cc95f6be67c481f2dbf8faa0f6ddc1e4ac7c56a84938714d80e46e9cf80ec4b8fcd739986449881
++%patch add newlib -p1 https://devel.rtems.org/raw-attachment/ticket/4510/0001-aarch64-Add-ILP32-ABI-support-in-assembly.patch
++%hash sha512 0001-aarch64-Add-ILP32-ABI-support-in-assembly.patch BHRMimj6ztKPHQFxypI8RwPmno96B56eVQGx5dtCtcOb+qICMrQC1fa0jP3JrR8RGJI4y61RoYvpnj6EbTmRKA==
%define newlib_version 4f81149
%define newlib_external 1
%define newlib_expand_name sourceware-mirror-newlib-cygwin-%{newlib_version}
1.8.3.1
