[PATCH RSB v1 2/2] rtems-gcc-head-newlib-head.cfg: Add newlib patch
Ryan Long ryan.long at oarcorp.com
Mon Sep 13 14:51:48 UTC 2021
Adds patch to add sanitation to the padding of bits and size_t types for
AArch64 tools builds with newlib. These changes have been made in ARM, but
newlib has yet to pull them. This can be removed once newlib has pulled
the code.
Updates #4510
 rtems/config/tools/rtems-gcc-head-newlib-head.cfg | 3 +++
 1 file changed, 3 insertions(+)
diff --git a/rtems/config/tools/rtems-gcc-head-newlib-head.cfg b/rtems/config/tools/rtems-gcc-head-newlib-head.cfg
index 4939ca5..fdb04d2 100644
--- a/rtems/config/tools/rtems-gcc-head-newlib-head.cfg
+++ b/rtems/config/tools/rtems-gcc-head-newlib-head.cfg
@@ -13,6 +13,9 @@
 %source set newlib --rsb-file=newlib-%{newlib_version}.tar.gz https://codeload.github.com/RTEMS/sourceware-mirror-newlib-cygwin/tar.gz/%{newlib_version}
 %hash sha512 newlib-%{newlib_version}.tar.gz 9ded46b3077508ef05bbb4bf424777a0baa5aab9c7c0c902fb5529bb73b5b5034c35282e2dbf270cbcd44d84940a20ee270e329db4e4b501046978c18f78a11c
+%patch add newlib -p1 https://devel.rtems.org/raw-attachment/ticket/4510/0001-aarch64-Add-ILP32-ABI-support-in-assembly.patch
+%hash sha512 0001-aarch64-Add-ILP32-ABI-support-in-assembly.patch BHRMimj6ztKPHQFxypI8RwPmno96B56eVQGx5dtCtcOb+qICMrQC1fa0jP3JrR8RGJI4y61RoYvpnj6EbTmRKA==
 %define with_threads 1
 %define with_plugin 0
 %define with_iconv 1
1.8.3.1
