RSB
Tue Sep 14 00:02:09 UTC 2021
On Mon, Sep 13, 2021 at 6:54 PM Chris Johns <chrisj at rtems.org> wrote:
> On 13/9/21 11:20 pm, Joel Sherrill wrote:
> > Hi
> > If building a bset tar file, does it matter if the installation prefix
> > is writable?
> > ../source-builder/sb-set-builder --bset-tar-file --log=l-i386.txt
> > --prefix=/rtems/tools 5/rtems-i386
> > RTEMS Source Builder - Set Builder, 5 (c7870f6e6199)
> > error: prefix is not writable: /rtems/tools
> > It does if you are planning to immediately install but if building for
> > later installation, I don't think it matters.
> > Thoughts?
> What happens if you add --no-install?
It skips the test.
> If this does help the question moves to if making a bset is packaging around an
> install or is it the only output option?
With a bset-tar, I don't think it did an install anyway. But it's been
a long day. I can
check again tomorrow if you want me to.
Thanks for the quick response.
--joel
> Chris
