[PATCH] c-user: Fix message manager documentation
Sebastian Huber
Tue Sep 14 15:52:15 UTC 2021
Remove bogus return status from rtems_message_queue_receive(). Clarify
rtems_message_queue_flush().
Close #4508.
c-user/message/directives.rst | 19 ++++++++++---------
1 file changed, 10 insertions(+), 9 deletions(-)
diff --git a/c-user/message/directives.rst b/c-user/message/directives.rst
index f320350..7317eb4 100644
--- a/c-user/message/directives.rst
+++ b/c-user/message/directives.rst
@@ -891,10 +891,6 @@ queue.
:c:macro:`RTEMS_UNSATISFIED`
The queue was empty.
-:c:macro:`RTEMS_UNSATISFIED`
- The queue was flushed while the calling task was waiting to receive a
- message.
:c:macro:`RTEMS_TIMEOUT`
The timeout happened while the calling task was waiting to receive a
message
@@ -1039,17 +1035,22 @@ present on the queue, count is set to zero.
The ``count`` parameter was `NULL
<https://en.cppreference.com/w/c/types/NULL>`_.
+.. rubric:: NOTES:
+The directive does not flush tasks waiting to receive a message from the
+:term:`wait queue` of the message queue.
.. rubric:: CONSTRAINTS:
The following constraints apply to this directive:
-* The directive may be called from within task context.
* The directive may be called from within interrupt context.
-* When the directive operates on a remote object, the directive sends a message
- to the remote node and waits for a reply. This will preempt the calling
- task.
+* The directive may be called from within device driver initialization context.
+* The directive may be called from within task context.
+* The directive will not cause the calling task to be preempted.
.. Generated from spec:/rtems/message/if/buffer
2.31.1
