[PATCH rtems-tools] check.py: Fix incorrect use of os.linesep
Chris Johns
chrisj at rtems.org
Tue Sep 14 22:49:49 UTC 2021
OK and thanks
On 15/9/21 1:29 am, Ryan Long wrote:
> Replaced a couple of calls to os.linesep() with os.linesep because
> os.linesep() does not exist.
> tester/rt/check.py | 4 ++--
> 1 file changed, 2 insertions(+), 2 deletions(-)
> diff --git a/tester/rt/check.py b/tester/rt/check.py
> index 95fa47e..c01c25d 100755
> --- a/tester/rt/check.py
> +++ b/tester/rt/check.py
> @@ -966,13 +966,13 @@ class builder:
> def _create_config(self, job, commands):
> filename = 'config-%s-%s-%s.ini' % (job.arch, job.bsp, job.build)
> cfg_file = open(path.join(self.rtems, filename),'w+')
> - cfg_file.write('[%s/%s]' + os.linsep() % (job.arch, job.bsp))
> + cfg_file.write('[%s/%s]' % (job.arch, job.bsp) + os.linesep)
> new_cfg_cmds = []
> for option in commands['configure'].split():
> if 'waf' in option or '--' in option or 'configure' in option:
> new_cfg_cmds += [option]
> else:
> - cfg_file.write(option + os.linesep())
> + cfg_file.write(option + os.linesep)
> commands['configure'] = ' '.join(new_cfg_cmds)
> cfg_file.close()
