[PATCH v4] arm/xilinx: Fix zynq-uart interrupt receive
chrisj at rtems.org
chrisj at rtems.org
Wed Sep 15 06:29:07 UTC 2021
- Trigger on a single character entering the RX FIFO
- Disable the RX timeout
- Send up to a FIFO full of data
bsps/include/dev/serial/zynq-uart.h | 1 +
bsps/shared/dev/serial/zynq-uart-polled.c | 45 ++++++-------
bsps/shared/dev/serial/zynq-uart.c | 78 +++++++++++++----------
3 files changed, 67 insertions(+), 57 deletions(-)
diff --git a/bsps/include/dev/serial/zynq-uart.h b/bsps/include/dev/serial/zynq-uart.h
index 220d9b7717..b21e16f6de 100644
--- a/bsps/include/dev/serial/zynq-uart.h
+++ b/bsps/include/dev/serial/zynq-uart.h
@@ -52,6 +52,7 @@ extern "C" {
typedef struct {
rtems_termios_device_context base;
volatile struct zynq_uart *regs;
+ int tx_queued;
bool transmitting;
rtems_vector_number irq;
} zynq_uart_context;
diff --git a/bsps/shared/dev/serial/zynq-uart-polled.c b/bsps/shared/dev/serial/zynq-uart-polled.c
index 95c51dea11..6865fa8d6f 100644
--- a/bsps/shared/dev/serial/zynq-uart-polled.c
+++ b/bsps/shared/dev/serial/zynq-uart-polled.c
@@ -121,35 +121,35 @@ void zynq_uart_initialize(rtems_termios_device_context *base)
volatile zynq_uart *regs = ctx->regs;
uint32_t brgr = 0x3e;
uint32_t bauddiv = 0x6;
+ uint32_t mode_clks = regs->mode & ZYNQ_UART_MODE_CLKS;
- zynq_uart_reset_tx_flush(ctx);
+ while ((regs->channel_sts & ZYNQ_UART_CHANNEL_STS_TEMPTY) == 0 ||
+ (regs->channel_sts & ZYNQ_UART_CHANNEL_STS_TACTIVE) != 0) {
+ /* Wait */
- zynq_cal_baud_rate(ZYNQ_UART_DEFAULT_BAUD, &brgr, &bauddiv, regs->mode);
+ zynq_cal_baud_rate(ZYNQ_UART_DEFAULT_BAUD, &brgr, &bauddiv, mode_clks);
- regs->control &= ~(ZYNQ_UART_CONTROL_RXEN | ZYNQ_UART_CONTROL_TXEN);
- regs->control = ZYNQ_UART_CONTROL_RXDIS
- | ZYNQ_UART_CONTROL_TXDIS;
- regs->mode = ZYNQ_UART_MODE_CHMODE(ZYNQ_UART_MODE_CHMODE_NORMAL)
- | ZYNQ_UART_MODE_PAR(ZYNQ_UART_MODE_PAR_NONE)
- | ZYNQ_UART_MODE_CHRL(ZYNQ_UART_MODE_CHRL_8);
+ regs->control = 0;
+ regs->control = ZYNQ_UART_CONTROL_RXDIS | ZYNQ_UART_CONTROL_TXDIS;
regs->baud_rate_gen = ZYNQ_UART_BAUD_RATE_GEN_CD(brgr);
regs->baud_rate_div = ZYNQ_UART_BAUD_RATE_DIV_BDIV(bauddiv);
/* A Tx/Rx logic reset must be issued after baud rate manipulation */
- | ZYNQ_UART_CONTROL_RXRES
- | ZYNQ_UART_CONTROL_TXRES;
+ regs->control = ZYNQ_UART_CONTROL_RXRES | ZYNQ_UART_CONTROL_TXRES;
regs->rx_fifo_trg_lvl = ZYNQ_UART_RX_FIFO_TRG_LVL_RTRIG(0);
regs->rx_timeout = ZYNQ_UART_RX_TIMEOUT_RTO(0);
- regs->control = ZYNQ_UART_CONTROL_RXEN
- | ZYNQ_UART_CONTROL_TXEN
- | ZYNQ_UART_CONTROL_RSTTO;
+ regs->control = ZYNQ_UART_CONTROL_RXEN | ZYNQ_UART_CONTROL_TXEN;
+ regs->mode = ZYNQ_UART_MODE_CHMODE(ZYNQ_UART_MODE_CHMODE_NORMAL)
+ | ZYNQ_UART_MODE_PAR(ZYNQ_UART_MODE_PAR_NONE)
+ | ZYNQ_UART_MODE_CHRL(ZYNQ_UART_MODE_CHRL_8)
+ | mode_clks;
- * Some ZynqMP UARTs have a hardware bug that causes TX/RX logic restarts to
- * require a kick after baud rate registers are initialized.
- zynq_uart_write_polled(base, 0);
+ while (zynq_uart_read_polled(base) >= 0) {
+ /* Drop */
+ zynq_uart_reset_tx_flush(ctx);
int zynq_uart_read_polled(rtems_termios_device_context *base)
@@ -172,7 +172,7 @@ void zynq_uart_write_polled(
zynq_uart_context *ctx = (zynq_uart_context *) base;
- while ((regs->channel_sts & ZYNQ_UART_CHANNEL_STS_TFUL) != 0) {
+ while ((regs->channel_sts & ZYNQ_UART_CHANNEL_STS_TNFUL) != 0) {
/* Wait */
@@ -187,7 +187,8 @@ void zynq_uart_reset_tx_flush(zynq_uart_context *ctx)
while (c-- > 0)
zynq_uart_write_polled(&ctx->base, '\r');
- while ((regs->channel_sts & ZYNQ_UART_CHANNEL_STS_TEMPTY) == 0) {
/* Wait */
diff --git a/bsps/shared/dev/serial/zynq-uart.c b/bsps/shared/dev/serial/zynq-uart.c
index 8503e31d49..8ff1d25da0 100644
--- a/bsps/shared/dev/serial/zynq-uart.c
+++ b/bsps/shared/dev/serial/zynq-uart.c
@@ -37,24 +37,24 @@ static void zynq_uart_interrupt(void *arg)
rtems_termios_tty *tty = arg;
zynq_uart_context *ctx = rtems_termios_get_device_context(tty);
- uint32_t channel_sts;
- if ((regs->irq_sts & (ZYNQ_UART_TIMEOUT | ZYNQ_UART_RTRIG)) != 0) {
- regs->irq_sts = ZYNQ_UART_TIMEOUT | ZYNQ_UART_RTRIG;
- do {
- char c = (char) ZYNQ_UART_TX_RX_FIFO_FIFO_GET(regs->tx_rx_fifo);
- rtems_termios_enqueue_raw_characters(tty, &c, 1);
- channel_sts = regs->channel_sts;
- } while ((channel_sts & ZYNQ_UART_CHANNEL_STS_REMPTY) == 0);
- } else {
+ if ((regs->irq_sts & ZYNQ_UART_RTRIG) != 0) {
+ char buf[32];
+ int c = 0;
+ regs->irq_sts = ZYNQ_UART_RTRIG;
+ while (c < sizeof(buf) &&
+ (regs->channel_sts & ZYNQ_UART_CHANNEL_STS_REMPTY) == 0) {
+ buf[c++] = (char) ZYNQ_UART_TX_RX_FIFO_FIFO_GET(regs->tx_rx_fifo);
+ rtems_termios_enqueue_raw_characters(tty, buf, c);
- if (ctx->transmitting && (channel_sts & ZYNQ_UART_CHANNEL_STS_TEMPTY) != 0) {
- rtems_termios_dequeue_characters(tty, 1);
+ if (ctx->transmitting) {
+ int sent = ctx->tx_queued;
+ regs->irq_dis = ZYNQ_UART_TEMPTY;
+ ctx->transmitting = false;
+ ctx->tx_queued = 0;
+ rtems_termios_dequeue_characters(tty, sent);
#endif
@@ -76,11 +76,10 @@ static bool zynq_uart_first_open(
zynq_uart_initialize(base);
#ifdef ZYNQ_CONSOLE_USE_INTERRUPTS
- regs->rx_timeout = 32;
- regs->rx_fifo_trg_lvl = ZYNQ_UART_FIFO_DEPTH / 2;
+ regs->rx_fifo_trg_lvl = 1;
regs->irq_dis = 0xffffffff;
regs->irq_sts = 0xffffffff;
- regs->irq_en = ZYNQ_UART_RTRIG | ZYNQ_UART_TIMEOUT;
+ regs->irq_en = ZYNQ_UART_RTRIG;
sc = rtems_interrupt_handler_install(
ctx->irq,
"UART",
@@ -119,18 +118,23 @@ static void zynq_uart_write_support(
if (len > 0) {
- ctx->transmitting = true;
+ const char *p = &buf[0];
regs->irq_sts = ZYNQ_UART_TEMPTY;
+ while (((regs->channel_sts & ZYNQ_UART_CHANNEL_STS_TNFUL) == 0) &&
+ len > 0) {
+ regs->tx_rx_fifo = ZYNQ_UART_TX_RX_FIFO_FIFO(*p);
+ ++p;
+ ++ctx->tx_queued;
+ --len;
+ ctx->transmitting = true;
regs->irq_en = ZYNQ_UART_TEMPTY;
- regs->tx_rx_fifo = ZYNQ_UART_TX_RX_FIFO_FIFO(buf[0]);
- } else {
- ctx->transmitting = false;
- regs->irq_dis = ZYNQ_UART_TEMPTY;
#else
ssize_t i;
for (i = 0; i < len; ++i) {
zynq_uart_write_polled(base, buf[i]);
@@ -164,6 +168,7 @@ static bool zynq_uart_set_attributes(
* Configure the mode register
+ mode = regs->mode & ZYNQ_UART_MODE_CLKS;
mode |= ZYNQ_UART_MODE_CHMODE(ZYNQ_UART_MODE_CHMODE_NORMAL);
@@ -208,22 +213,25 @@ static bool zynq_uart_set_attributes(
mode |= ZYNQ_UART_MODE_NBSTOP(ZYNQ_UART_MODE_NBSTOP_STOP_1);
- regs->mode = mode;
+ * Wait for any data in the TXFIFO to be sent then wait while the
+ * transmiter is active.
+ /* Wait */
/* Ignore baud rate of B0. There are no modem control lines to de-assert */
if (baud > 0) {
- regs->control |= ZYNQ_UART_CONTROL_RXRES
- regs->control |= ZYNQ_UART_CONTROL_RXEN | ZYNQ_UART_CONTROL_TXEN;
- zynq_uart_write_polled(context, 0);
+ regs->mode = mode;
+ regs->irq_sts = 0xffffffff;
return true;
2.24.1
