[PATCH] rtems: Fix message manager documentation
Wed Sep 15 09:48:44 UTC 2021
Correct the description of the ``count`` parameter of
rtems_message_queue_flush().
Update #4508.
 cpukit/include/rtems/rtems/message.h | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/cpukit/include/rtems/rtems/message.h b/cpukit/include/rtems/rtems/message.h
index f288d94445..28014f325e 100644
--- a/cpukit/include/rtems/rtems/message.h
+++ b/cpukit/include/rtems/rtems/message.h
@@ -859,8 +859,8 @@ rtems_status_code rtems_message_queue_get_number_pending(
  * @param id is the queue identifier.
  * @param[out] count is the pointer to an uint32_t object.  When the directive
- *   call is successful, the number of unblocked tasks will be stored in this
- *   object.
+ *   call is successful, the number of pending messages removed from the queue
+ *   will be stored in this object.
  * This directive removes all pending messages from the queue specified by
  * ``id``.  The number of messages removed is returned in ``count``.  If no
2.31.1
