[PATCH RSB] Remove automake/autoconf from rtems 6 tools
Thu Sep 16 14:42:23 UTC 2021
These are unneeded with the waf build system.
Closes #4081.
 rtems/config/6/rtems-default.bset    | 2 --
 rtems/config/6/rtems-microblaze.bset | 2 --
 2 files changed, 4 deletions(-)
diff --git a/rtems/config/6/rtems-default.bset b/rtems/config/6/rtems-default.bset
index 1b60066..0c07b08 100644
--- a/rtems/config/6/rtems-default.bset
+++ b/rtems/config/6/rtems-default.bset
@@ -3,8 +3,6 @@
 %include 6/rtems-base.bset
-6/rtems-autotools
 # Build gdb first to raise the Python install error as early as possible.
 # GDB needs expat so it needs to be built before.
diff --git a/rtems/config/6/rtems-microblaze.bset b/rtems/config/6/rtems-microblaze.bset
index 4b12899..3eb7a89 100644
--- a/rtems/config/6/rtems-microblaze.bset
+++ b/rtems/config/6/rtems-microblaze.bset
@@ -6,8 +6,6 @@
-6/rtems-autotools
 devel/dtc-1.6.0-1
1.8.3.1
