[PATCH RSB] Remove automake/autoconf from rtems 6 tools
Thu Sep 16 14:50:31 UTC 2021
Hi Joel,
On Thu, Sep 16, 2021 at 8:42 AM Joel Sherrill <joel at rtems.org> wrote:
> These are unneeded with the waf build system.
> Closes #4081.
You should also git rm the rtems-autotools* files?
>  rtems/config/6/rtems-default.bset    | 2 --
>  rtems/config/6/rtems-microblaze.bset | 2 --
>  2 files changed, 4 deletions(-)
> diff --git a/rtems/config/6/rtems-default.bset b/rtems/config/6/rtems-default.bset
> index 1b60066..0c07b08 100644
> --- a/rtems/config/6/rtems-default.bset
> +++ b/rtems/config/6/rtems-default.bset
> @@ -3,8 +3,6 @@
>  %include 6/rtems-base.bset
> -6/rtems-autotools
>  # Build gdb first to raise the Python install error as early as possible.
>  # GDB needs expat so it needs to be built before.
> diff --git a/rtems/config/6/rtems-microblaze.bset b/rtems/config/6/rtems-microblaze.bset
> index 4b12899..3eb7a89 100644
> --- a/rtems/config/6/rtems-microblaze.bset
> +++ b/rtems/config/6/rtems-microblaze.bset
> @@ -6,8 +6,6 @@
> -6/rtems-autotools
>  devel/dtc-1.6.0-1
> 1.8.3.1
> devel mailing list
> devel at rtems.org
