[PATCH RSB v2] Remove automake/autoconf from rtems 6 tools
Joel Sherrill
joel at rtems.org
Thu Sep 16 14:56:42 UTC 2021
These are unneeded with the waf build system.
Closes #4081.
bare/config/devel/autotools-base.bset | 9 ---------
bare/config/devel/autotools-internal.bset | 13 -------------
bare/config/devel/autotools.bset | 14 --------------
rtems/config/6/rtems-autotools-base.bset | 9 ---------
rtems/config/6/rtems-autotools-internal.bset | 11 -----------
rtems/config/6/rtems-autotools.bset | 25 -------------------------
rtems/config/6/rtems-default.bset | 2 --
rtems/config/6/rtems-microblaze.bset | 2 --
rtems/config/tools/rtems-autoconf-2.69-1.cfg | 23 -----------------------
rtems/config/tools/rtems-automake-1.12.6-1.cfg | 23 -----------------------
10 files changed, 131 deletions(-)
delete mode 100644 bare/config/devel/autotools-base.bset
delete mode 100644 bare/config/devel/autotools-internal.bset
delete mode 100644 bare/config/devel/autotools.bset
delete mode 100644 rtems/config/6/rtems-autotools-base.bset
delete mode 100644 rtems/config/6/rtems-autotools-internal.bset
delete mode 100644 rtems/config/6/rtems-autotools.bset
delete mode 100644 rtems/config/tools/rtems-autoconf-2.69-1.cfg
delete mode 100644 rtems/config/tools/rtems-automake-1.12.6-1.cfg
diff --git a/bare/config/devel/autotools-base.bset b/bare/config/devel/autotools-base.bset
deleted file mode 100644
index 22456ed..0000000
--- a/bare/config/devel/autotools-base.bset
+++ /dev/null
@@ -1,9 +0,0 @@
-# Build set for autoconf, automake, and libtools.
-%define release 1
-devel/autoconf-2.69-1
-devel/automake-1.12.6-1
-devel/libtool-2.4.2-1
diff --git a/bare/config/devel/autotools-internal.bset b/bare/config/devel/autotools-internal.bset
index bad3890..0000000
--- a/bare/config/devel/autotools-internal.bset
+++ /dev/null
@@ -1,13 +0,0 @@
-# Tools Set for Internal Autotools Stable
-# Do not use via the command line.
-%define _internal_autotools yes
-%define _disable_collecting yes
-%define _disable_packaging yes
-%define _disable_reporting yes
-%define _disable_installing yes
-%include devel/autotools-base.bset
diff --git a/bare/config/devel/autotools.bset b/bare/config/devel/autotools.bset
index 5fcafa4..0000000
--- a/bare/config/devel/autotools.bset
+++ /dev/null
@@ -1,14 +0,0 @@
-%define release 1
-# A magic internal path that would break if changes in the defaults.mc
-# macro file are made.
-%define _internal_autotools_path %{_tmppath}/sb-%{_uid}/${SB_PREFIX_CLEAN}
-devel/autotools-internal.bset
-devel/autotools-base.bset
diff --git a/rtems/config/6/rtems-autotools-base.bset b/rtems/config/6/rtems-autotools-base.bset
index c6819c1..0000000
--- a/rtems/config/6/rtems-autotools-base.bset
+++ /dev/null
@@ -1,9 +0,0 @@
-%define release 1
-%define rtems_arch none
-%include 6/rtems-base.bset
-package: rtems-%{rtems_version}-autotools-%{_host}-%{release}
-tools/rtems-autoconf-2.69-1
-tools/rtems-automake-1.12.6-1
diff --git a/rtems/config/6/rtems-autotools-internal.bset b/rtems/config/6/rtems-autotools-internal.bset
index 19d2f19..0000000
--- a/rtems/config/6/rtems-autotools-internal.bset
+++ /dev/null
@@ -1,11 +0,0 @@
-%include 6/rtems-autotools-base.bset
diff --git a/rtems/config/6/rtems-autotools.bset b/rtems/config/6/rtems-autotools.bset
index e57d25d..0000000
--- a/rtems/config/6/rtems-autotools.bset
+++ /dev/null
@@ -1,25 +0,0 @@
-# Autoconf and automake are not relocatable and cannot be cross-compiled.
-# RTEMS uses autoconf and automake and building RTEMS in the RSB requires
-# bootstrapping and this requires a current autoconf and automake. The RSB
-# provides to support by:
-# 1. Building and installing autoconf and automake with a prefix to a
-# temporary internal path.
-# 2. Using the temporary internal build, build and install another copy
-# using the final prefix location.
-# Disable emailing reports of this building for RTEMS.
-%define mail_disable
-6/rtems-autotools-internal
-6/rtems-autotools-base
diff --git a/rtems/config/6/rtems-default.bset b/rtems/config/6/rtems-default.bset
index 1b60066..0c07b08 100644
--- a/rtems/config/6/rtems-default.bset
+++ b/rtems/config/6/rtems-default.bset
@@ -3,8 +3,6 @@
-6/rtems-autotools
# Build gdb first to raise the Python install error as early as possible.
# GDB needs expat so it needs to be built before.
diff --git a/rtems/config/6/rtems-microblaze.bset b/rtems/config/6/rtems-microblaze.bset
index 4b12899..3eb7a89 100644
--- a/rtems/config/6/rtems-microblaze.bset
+++ b/rtems/config/6/rtems-microblaze.bset
@@ -6,8 +6,6 @@
-6/rtems-autotools
devel/dtc-1.6.0-1
diff --git a/rtems/config/tools/rtems-autoconf-2.69-1.cfg b/rtems/config/tools/rtems-autoconf-2.69-1.cfg
index 71ef4ed..0000000
--- a/rtems/config/tools/rtems-autoconf-2.69-1.cfg
+++ /dev/null
@@ -1,23 +0,0 @@
-# Autoconf 2.69.
-%if %{rtems_arch} == none
- %define _target %{_host}
-%endif
-%include %{_configdir}/checks.cfg
-%include %{_configdir}/base.cfg
-%include %{_configdir}/versions.cfg
-%define rtems_autoconf_version 2.69
-# Check the version of autoconf in the path.
-%if %{__autoconf_ver} < %{rtems_autoconf_version}
- # Tools configuration.
- %include %{_configdir}/devel/autoconf-2.69-1.cfg
-%endif
diff --git a/rtems/config/tools/rtems-automake-1.12.6-1.cfg b/rtems/config/tools/rtems-automake-1.12.6-1.cfg
index f844013..0000000
--- a/rtems/config/tools/rtems-automake-1.12.6-1.cfg
+++ /dev/null
@@ -1,23 +0,0 @@
-# Automake 1.12.6
-%endif
-%define rtems_automake_version 1.12.6
-# Check the version of automake in the path.
-%if %{__automake_ver} < %{rtems_automake_version}
- %include %{_configdir}/devel/automake-1.12.6-1.cfg
-%endif
1.8.3.1
