[PATCH RSB] Remove automake/autoconf from rtems 6 tools
Thu Sep 16 14:57:35 UTC 2021
On Thu, Sep 16, 2021 at 9:50 AM Gedare Bloom <gedare at rtems.org> wrote:
> Hi Joel,
> On Thu, Sep 16, 2021 at 8:42 AM Joel Sherrill <joel at rtems.org> wrote:
> > These are unneeded with the waf build system.
> > Closes #4081.
> You should also git rm the rtems-autotools* files?
I thought the ones in bare were for use when building other packages but
happy to delete those also.
V2 may already be on the list.
--joel
> >  rtems/config/6/rtems-default.bset    | 2 --
> >  rtems/config/6/rtems-microblaze.bset | 2 --
> >  2 files changed, 4 deletions(-)
> > diff --git a/rtems/config/6/rtems-default.bset b/rtems/config/6/rtems-default.bset
> > index 1b60066..0c07b08 100644
> > --- a/rtems/config/6/rtems-default.bset
> > +++ b/rtems/config/6/rtems-default.bset
> > @@ -3,8 +3,6 @@
> >  %include 6/rtems-base.bset
> > -6/rtems-autotools
> >  # Build gdb first to raise the Python install error as early as possible.
> >  # GDB needs expat so it needs to be built before.
> > diff --git a/rtems/config/6/rtems-microblaze.bset b/rtems/config/6/rtems-microblaze.bset
> > index 4b12899..3eb7a89 100644
> > --- a/rtems/config/6/rtems-microblaze.bset
> > +++ b/rtems/config/6/rtems-microblaze.bset
> > @@ -6,8 +6,6 @@
> > -6/rtems-autotools
> >  devel/dtc-1.6.0-1
> > 1.8.3.1
> > devel mailing list
> > devel at rtems.org
