[PATCH 3/5] score: Provide two thread pin/unpin defaults
Sebastian Huber
Fri Sep 17 07:02:57 UTC 2021
The uniprocessor schedulers do not support systems with more than more
processors. So they rivially support thread pinning and thus the
SMP_FATAL_SCHEDULER_PIN_OR_UNPIN_NOT_SUPPORTED cannot happen.
Add a second default implementation for SMP schedulers which do not
support thread pinning.
Change license to BSD-2-Clause according to file history and re-licensing
agreement.
Update #3053.
cpukit/include/rtems/score/scheduler.h | 27 ++++++++--
.../score/schedulerpriorityaffinitysmp.h | 4 +-
.../rtems/score/schedulerprioritysmp.h | 4 +-
.../include/rtems/score/schedulersimplesmp.h | 4 +-
.../include/rtems/score/schedulerstrongapa.h | 4 +-
cpukit/score/src/schedulerdefaultpinunpin.c | 31 ++++++++---
.../src/schedulerdefaultpinunpindonothing.c | 54 +++++++++++++++++++
spec/build/cpukit/objsmp.yml | 1 +
8 files changed, 112 insertions(+), 17 deletions(-)
create mode 100644 cpukit/score/src/schedulerdefaultpinunpindonothing.c
diff --git a/cpukit/include/rtems/score/scheduler.h b/cpukit/include/rtems/score/scheduler.h
index 6cb07c4ff1..36fc1fd39c 100644
--- a/cpukit/include/rtems/score/scheduler.h
+++ b/cpukit/include/rtems/score/scheduler.h
@@ -443,16 +443,37 @@ Priority_Control _Scheduler_default_Unmap_priority(
Thread_Scheduler_state next_state
+ * @brief Does nothing.
+ * This default implementation for the thread pin or unpin operations should
+ * be used by uniprocessor schedulers if SMP support is enabled.
+ * @param scheduler This parameter is unused.
+ * @param the_thread This parameter is unused.
+ * @param node This parameter is unused.
+ * @param cpu This parameter is unused.
+ void _Scheduler_default_Pin_or_unpin_do_nothing(
+ const Scheduler_Control *scheduler,
+ Thread_Control *the_thread,
+ Scheduler_Node *node,
+ struct Per_CPU_Control *cpu
* @brief Does nothing in a single processor system, otherwise a fatal error
* is issued.
+ * be used by SMP schedulers which do not support thread pinning.
- void _Scheduler_default_Pin_or_unpin(
+ void _Scheduler_default_Pin_or_unpin_not_supported(
@@ -474,8 +495,8 @@ Priority_Control _Scheduler_default_Unmap_priority(
_Scheduler_default_Ask_for_help, \
_Scheduler_default_Reconsider_help_request, \
_Scheduler_default_Withdraw_node, \
- _Scheduler_default_Pin_or_unpin, \
+ _Scheduler_default_Pin_or_unpin_do_nothing, \
NULL, \
NULL,
#else
diff --git a/cpukit/include/rtems/score/schedulerpriorityaffinitysmp.h b/cpukit/include/rtems/score/schedulerpriorityaffinitysmp.h
index 772a83f541..01f96c8996 100644
--- a/cpukit/include/rtems/score/schedulerpriorityaffinitysmp.h
+++ b/cpukit/include/rtems/score/schedulerpriorityaffinitysmp.h
@@ -65,8 +65,8 @@ extern "C" {
_Scheduler_priority_affinity_SMP_Ask_for_help, \
_Scheduler_priority_affinity_SMP_Reconsider_help_request, \
_Scheduler_priority_affinity_SMP_Withdraw_node, \
+ _Scheduler_default_Pin_or_unpin_no_supported, \
_Scheduler_priority_affinity_SMP_Add_processor, \
_Scheduler_priority_affinity_SMP_Remove_processor, \
_Scheduler_priority_affinity_SMP_Node_initialize, \
diff --git a/cpukit/include/rtems/score/schedulerprioritysmp.h b/cpukit/include/rtems/score/schedulerprioritysmp.h
index 80979a36ba..591d3f8ca7 100644
--- a/cpukit/include/rtems/score/schedulerprioritysmp.h
+++ b/cpukit/include/rtems/score/schedulerprioritysmp.h
@@ -93,8 +93,8 @@ typedef struct {
_Scheduler_priority_SMP_Ask_for_help, \
_Scheduler_priority_SMP_Reconsider_help_request, \
_Scheduler_priority_SMP_Withdraw_node, \
_Scheduler_priority_SMP_Add_processor, \
_Scheduler_priority_SMP_Remove_processor, \
_Scheduler_priority_SMP_Node_initialize, \
diff --git a/cpukit/include/rtems/score/schedulersimplesmp.h b/cpukit/include/rtems/score/schedulersimplesmp.h
index 158bea74db..ea4c55af0d 100644
--- a/cpukit/include/rtems/score/schedulersimplesmp.h
+++ b/cpukit/include/rtems/score/schedulersimplesmp.h
@@ -75,8 +75,8 @@ typedef struct {
_Scheduler_simple_SMP_Ask_for_help, \
_Scheduler_simple_SMP_Reconsider_help_request, \
_Scheduler_simple_SMP_Withdraw_node, \
_Scheduler_simple_SMP_Add_processor, \
_Scheduler_simple_SMP_Remove_processor, \
_Scheduler_simple_SMP_Node_initialize, \
diff --git a/cpukit/include/rtems/score/schedulerstrongapa.h b/cpukit/include/rtems/score/schedulerstrongapa.h
index 9ee922d46d..bff59c51fd 100644
--- a/cpukit/include/rtems/score/schedulerstrongapa.h
+++ b/cpukit/include/rtems/score/schedulerstrongapa.h
@@ -161,8 +161,8 @@ typedef struct {
_Scheduler_strong_APA_Ask_for_help, \
_Scheduler_strong_APA_Reconsider_help_request, \
_Scheduler_strong_APA_Withdraw_node, \
_Scheduler_strong_APA_Add_processor, \
_Scheduler_strong_APA_Remove_processor, \
_Scheduler_strong_APA_Node_initialize, \
diff --git a/cpukit/score/src/schedulerdefaultpinunpin.c b/cpukit/score/src/schedulerdefaultpinunpin.c
index 4aa2169c8e..df41a29dcb 100644
--- a/cpukit/score/src/schedulerdefaultpinunpin.c
+++ b/cpukit/score/src/schedulerdefaultpinunpin.c
@@ -1,18 +1,37 @@
* @file
* @ingroup RTEMSScoreScheduler
* @brief This source file contains the implementation of
- * _Scheduler_default_Pin_or_unpin().
+ * _Scheduler_default_Pin_or_unpin_not_supported().
- * Copyright (c) 2018 embedded brains GmbH
+ * Copyright (C) 2018 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
#ifdef HAVE_CONFIG_H
@@ -23,7 +42,7 @@
#include <rtems/score/interr.h>
#include <rtems/score/smpimpl.h>
-void _Scheduler_default_Pin_or_unpin(
+void _Scheduler_default_Pin_or_unpin_not_supported(
diff --git a/cpukit/score/src/schedulerdefaultpinunpindonothing.c b/cpukit/score/src/schedulerdefaultpinunpindonothing.c
new file mode 100644
index 0000000000..f7bab4f661
--- /dev/null
+++ b/cpukit/score/src/schedulerdefaultpinunpindonothing.c
@@ -0,0 +1,54 @@
+ * @file
+ * @ingroup RTEMSScoreScheduler
+ * @brief This source file contains the implementation of
+ * _Scheduler_default_Pin_or_unpin_do_nothing().
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/scheduler.h>
+void _Scheduler_default_Pin_or_unpin_do_nothing(
+ (void) scheduler;
+ (void) the_thread;
+ (void) node;
+ (void) cpu;
diff --git a/spec/build/cpukit/objsmp.yml b/spec/build/cpukit/objsmp.yml
index 8b3357d59c..ef097a86ed 100644
--- a/spec/build/cpukit/objsmp.yml
+++ b/spec/build/cpukit/objsmp.yml
@@ -15,6 +15,7 @@ source:
- cpukit/score/src/profilingsmplock.c
- cpukit/score/src/schedulerdefaultaskforhelp.c
- cpukit/score/src/schedulerdefaultpinunpin.c
+- cpukit/score/src/schedulerdefaultpinunpindonothing.c
- cpukit/score/src/schedulerdefaultsetaffinity.c
- cpukit/score/src/scheduleredfsmp.c
- cpukit/score/src/schedulerpriorityaffinitysmp.c
2.31.1
