[PATCH 2/5] score: SCHEDULER_OPERATION_DEFAULT_GET_SET_AFFINITY
Sebastian Huber
Fri Sep 17 07:02:56 UTC 2021
Rename SCHEDULER_OPERATION_DEFAULT_GET_SET_AFFINITY in
SCHEDULER_DEFAULT_SET_AFFINITY_OPERATION. Add Doxygen comment.
cpukit/include/rtems/score/scheduler.h | 16 ++++++++++++++--
cpukit/include/rtems/score/schedulercbs.h | 2 +-
cpukit/include/rtems/score/scheduleredf.h | 2 +-
cpukit/include/rtems/score/schedulerpriority.h | 2 +-
.../include/rtems/score/schedulerprioritysmp.h | 2 +-
cpukit/include/rtems/score/schedulersimple.h | 2 +-
cpukit/include/rtems/score/schedulersimplesmp.h | 2 +-
7 files changed, 20 insertions(+), 8 deletions(-)
diff --git a/cpukit/include/rtems/score/scheduler.h b/cpukit/include/rtems/score/scheduler.h
index 25b6723efd..6cb07c4ff1 100644
--- a/cpukit/include/rtems/score/scheduler.h
+++ b/cpukit/include/rtems/score/scheduler.h
@@ -605,11 +605,23 @@ void _Scheduler_default_Start_idle(
Scheduler_Node *node,
const Processor_mask *affinity
+#endif
- #define SCHEDULER_OPERATION_DEFAULT_GET_SET_AFFINITY \
+ * @brief This define provides the default implementation for the
+ * SMP-specific set affinity operation.
+ * The default implementation _Scheduler_default_Set_affinity() is intended for
+ * uniprocessor schedulers and SMP schedulers which only support an affinity to
+ * all online processors.
+ * If SMP support is disabled, the define evaluates to nothing.
+#if defined(RTEMS_SMP)
+ #define SCHEDULER_DEFAULT_SET_AFFINITY_OPERATION \
, _Scheduler_default_Set_affinity
#else
#endif
diff --git a/cpukit/include/rtems/score/schedulercbs.h b/cpukit/include/rtems/score/schedulercbs.h
index 396dfc17be..4b7efc8340 100644
--- a/cpukit/include/rtems/score/schedulercbs.h
+++ b/cpukit/include/rtems/score/schedulercbs.h
@@ -69,7 +69,7 @@ extern "C" {
_Scheduler_CBS_Cancel_job, /* cancel period of task */ \
_Scheduler_default_Tick, /* tick entry point */ \
_Scheduler_default_Start_idle /* start idle entry point */ \
- SCHEDULER_OPERATION_DEFAULT_GET_SET_AFFINITY \
+ SCHEDULER_DEFAULT_SET_AFFINITY_OPERATION \
/* Return values for CBS server. */
diff --git a/cpukit/include/rtems/score/scheduleredf.h b/cpukit/include/rtems/score/scheduleredf.h
index 54b1cd71bc..9e643b93eb 100644
--- a/cpukit/include/rtems/score/scheduleredf.h
+++ b/cpukit/include/rtems/score/scheduleredf.h
@@ -68,7 +68,7 @@ extern "C" {
_Scheduler_EDF_Cancel_job, /* cancel period of task */ \
typedef struct {
diff --git a/cpukit/include/rtems/score/schedulerpriority.h b/cpukit/include/rtems/score/schedulerpriority.h
index 45a312ffaf..e0991f5e31 100644
--- a/cpukit/include/rtems/score/schedulerpriority.h
+++ b/cpukit/include/rtems/score/schedulerpriority.h
@@ -59,7 +59,7 @@ extern "C" {
_Scheduler_default_Cancel_job, /* cancel period of task */ \
typedef struct {
diff --git a/cpukit/include/rtems/score/schedulerprioritysmp.h b/cpukit/include/rtems/score/schedulerprioritysmp.h
index d6ab6f6fdd..80979a36ba 100644
--- a/cpukit/include/rtems/score/schedulerprioritysmp.h
+++ b/cpukit/include/rtems/score/schedulerprioritysmp.h
@@ -103,7 +103,7 @@ typedef struct {
_Scheduler_default_Cancel_job, \
_Scheduler_default_Tick, \
_Scheduler_SMP_Start_idle \
diff --git a/cpukit/include/rtems/score/schedulersimple.h b/cpukit/include/rtems/score/schedulersimple.h
index 155027f3d3..63310e9796 100644
--- a/cpukit/include/rtems/score/schedulersimple.h
+++ b/cpukit/include/rtems/score/schedulersimple.h
@@ -58,7 +58,7 @@ extern "C" {
diff --git a/cpukit/include/rtems/score/schedulersimplesmp.h b/cpukit/include/rtems/score/schedulersimplesmp.h
index 6b7e111208..158bea74db 100644
--- a/cpukit/include/rtems/score/schedulersimplesmp.h
+++ b/cpukit/include/rtems/score/schedulersimplesmp.h
@@ -85,7 +85,7 @@ typedef struct {
2.31.1
