[PATCH RSB v3] Remove automake/autoconf from rtems 6 tools
Gedare Bloom
gedare at rtems.org
Fri Sep 17 22:38:42 UTC 2021
this looks right, just test it before pushing :)
On Thu, Sep 16, 2021 at 1:26 PM Joel Sherrill <joel at rtems.org> wrote:
> These are unneeded with the waf build system.
> Closes #4081.
> rtems/config/6/rtems-autotools-base.bset | 9 ---------
> rtems/config/6/rtems-autotools-internal.bset | 11 -----------
> rtems/config/6/rtems-autotools.bset | 25 -------------------------
> rtems/config/6/rtems-default.bset | 2 --
> rtems/config/6/rtems-microblaze.bset | 2 --
> 5 files changed, 49 deletions(-)
> delete mode 100644 rtems/config/6/rtems-autotools-base.bset
> delete mode 100644 rtems/config/6/rtems-autotools-internal.bset
> delete mode 100644 rtems/config/6/rtems-autotools.bset
> diff --git a/rtems/config/6/rtems-autotools-base.bset b/rtems/config/6/rtems-autotools-base.bset
> deleted file mode 100644
> index c6819c1..0000000
> --- a/rtems/config/6/rtems-autotools-base.bset
> +++ /dev/null
> @@ -1,9 +0,0 @@
> -%define release 1
> -%define rtems_arch none
> -%include 6/rtems-base.bset
> -package: rtems-%{rtems_version}-autotools-%{_host}-%{release}
> -tools/rtems-autoconf-2.69-1
> -tools/rtems-automake-1.12.6-1
> diff --git a/rtems/config/6/rtems-autotools-internal.bset b/rtems/config/6/rtems-autotools-internal.bset
> index 19d2f19..0000000
> --- a/rtems/config/6/rtems-autotools-internal.bset
> +++ /dev/null
> @@ -1,11 +0,0 @@
> -# Do not use via the command line.
> -%define _internal_autotools yes
> -%define _disable_collecting yes
> -%define _disable_packaging yes
> -%define _disable_reporting yes
> -%define _disable_installing yes
> -%include 6/rtems-autotools-base.bset
> diff --git a/rtems/config/6/rtems-autotools.bset b/rtems/config/6/rtems-autotools.bset
> index e57d25d..0000000
> --- a/rtems/config/6/rtems-autotools.bset
> +++ /dev/null
> @@ -1,25 +0,0 @@
> -# Autoconf and automake are not relocatable and cannot be cross-compiled.
> -# RTEMS uses autoconf and automake and building RTEMS in the RSB requires
> -# bootstrapping and this requires a current autoconf and automake. The RSB
> -# provides to support by:
> -# 1. Building and installing autoconf and automake with a prefix to a
> -# temporary internal path.
> -# 2. Using the temporary internal build, build and install another copy
> -# using the final prefix location.
> -# A magic internal path that would break if changes in the defaults.mc
> -# macro file are made.
> -%define _internal_autotools_path %{_tmppath}/sb-%{_uid}/${SB_PREFIX_CLEAN}
> -# Disable emailing reports of this building for RTEMS.
> -%define mail_disable
> -6/rtems-autotools-internal
> -6/rtems-autotools-base
> diff --git a/rtems/config/6/rtems-default.bset b/rtems/config/6/rtems-default.bset
> index 1b60066..0c07b08 100644
> --- a/rtems/config/6/rtems-default.bset
> +++ b/rtems/config/6/rtems-default.bset
> @@ -3,8 +3,6 @@
> -6/rtems-autotools
> # Build gdb first to raise the Python install error as early as possible.
> # GDB needs expat so it needs to be built before.
> diff --git a/rtems/config/6/rtems-microblaze.bset b/rtems/config/6/rtems-microblaze.bset
> index 4b12899..3eb7a89 100644
> --- a/rtems/config/6/rtems-microblaze.bset
> +++ b/rtems/config/6/rtems-microblaze.bset
> @@ -6,8 +6,6 @@
> -6/rtems-autotools
> devel/dtc-1.6.0-1
> 1.8.3.1
> devel mailing list
> devel at rtems.org
