[PATCH RSB v3] Remove automake/autoconf from rtems 6 tools
Joel Sherrill
joel at rtems.org
Fri Sep 17 23:16:41 UTC 2021
Thanks. I will.
Lots of family distractions the past few days. Sorry for screwing it up so
much.
On Fri, Sep 17, 2021, 5:38 PM Gedare Bloom <gedare at rtems.org> wrote:
> this looks right, just test it before pushing :)
> On Thu, Sep 16, 2021 at 1:26 PM Joel Sherrill <joel at rtems.org> wrote:
> > These are unneeded with the waf build system.
> > Closes #4081.
> > rtems/config/6/rtems-autotools-base.bset | 9 ---------
> > rtems/config/6/rtems-autotools-internal.bset | 11 -----------
> > rtems/config/6/rtems-autotools.bset | 25
> > rtems/config/6/rtems-default.bset | 2 --
> > rtems/config/6/rtems-microblaze.bset | 2 --
> > 5 files changed, 49 deletions(-)
> > delete mode 100644 rtems/config/6/rtems-autotools-base.bset
> > delete mode 100644 rtems/config/6/rtems-autotools-internal.bset
> > delete mode 100644 rtems/config/6/rtems-autotools.bset
> > diff --git a/rtems/config/6/rtems-autotools-base.bset
> b/rtems/config/6/rtems-autotools-base.bset
> > deleted file mode 100644
> > index c6819c1..0000000
> > --- a/rtems/config/6/rtems-autotools-base.bset
> > +++ /dev/null
> > @@ -1,9 +0,0 @@
> > -%define release 1
> > -%define rtems_arch none
> > -%include 6/rtems-base.bset
> > -package: rtems-%{rtems_version}-autotools-%{_host}-%{release}
> > -tools/rtems-autoconf-2.69-1
> > -tools/rtems-automake-1.12.6-1
> > diff --git a/rtems/config/6/rtems-autotools-internal.bset
> b/rtems/config/6/rtems-autotools-internal.bset
> > index 19d2f19..0000000
> > --- a/rtems/config/6/rtems-autotools-internal.bset
> > +++ /dev/null
> > @@ -1,11 +0,0 @@
> > -# Do not use via the command line.
> > -%define _internal_autotools yes
> > -%define _disable_collecting yes
> > -%define _disable_packaging yes
> > -%define _disable_reporting yes
> > -%define _disable_installing yes
> > -%include 6/rtems-autotools-base.bset
> > diff --git a/rtems/config/6/rtems-autotools.bset
> b/rtems/config/6/rtems-autotools.bset
> > index e57d25d..0000000
> > --- a/rtems/config/6/rtems-autotools.bset
> > +++ /dev/null
> > @@ -1,25 +0,0 @@
> > -# Autoconf and automake are not relocatable and cannot be
> cross-compiled.
> > -# RTEMS uses autoconf and automake and building RTEMS in the RSB
> requires
> > -# bootstrapping and this requires a current autoconf and automake. The
> RSB
> > -# provides to support by:
> > -# 1. Building and installing autoconf and automake with a prefix to a
> > -# temporary internal path.
> > -# 2. Using the temporary internal build, build and install another copy
> > -# using the final prefix location.
> > -# A magic internal path that would break if changes in the defaults.mc
> > -# macro file are made.
> > -%define _internal_autotools_path
> %{_tmppath}/sb-%{_uid}/${SB_PREFIX_CLEAN}
> > -# Disable emailing reports of this building for RTEMS.
> > -%define mail_disable
> > -6/rtems-autotools-internal
> > -6/rtems-autotools-base
> > diff --git a/rtems/config/6/rtems-default.bset
> b/rtems/config/6/rtems-default.bset
> > index 1b60066..0c07b08 100644
> > --- a/rtems/config/6/rtems-default.bset
> > +++ b/rtems/config/6/rtems-default.bset
> > @@ -3,8 +3,6 @@
> > -6/rtems-autotools
> > # Build gdb first to raise the Python install error as early as
> possible.
> > # GDB needs expat so it needs to be built before.
> > diff --git a/rtems/config/6/rtems-microblaze.bset
> b/rtems/config/6/rtems-microblaze.bset
> > index 4b12899..3eb7a89 100644
> > --- a/rtems/config/6/rtems-microblaze.bset
> > +++ b/rtems/config/6/rtems-microblaze.bset
> > @@ -6,8 +6,6 @@
> > -6/rtems-autotools
> > devel/dtc-1.6.0-1
> > 1.8.3.1
> > devel mailing list
> > devel at rtems.org
