[PATCH 0/1] v4: Implementation of Condclockwait and Test
Matt Joyce mfjoyce2004 at gmail.com
Sat Sep 18 14:46:29 UTC 2021
This version contains some formatting fixes from v3.
Thank you!
Matt Joyce (1):
  Added Implementation / tests for pthread_cond_clockwait()
 cpukit/include/rtems/posix/condimpl.h         |   9 +-
 cpukit/posix/src/condclockwait.c              |  78 +++
 cpukit/posix/src/condtimedwait.c              |   3 +-
 cpukit/posix/src/condwait.c                   |   1 +
 cpukit/posix/src/condwaitsupp.c               | 114 ++++-
 spec/build/testsuites/psxtests/grp.yml        |   2 +
 spec/build/testsuites/psxtests/psxcond03.yml  |  20 +
 testsuites/psxtests/Makefile.am               |   9 +
 testsuites/psxtests/configure.ac              |   1 +
 testsuites/psxtests/psxcond03/init.c          | 466 ++++++++++++++++++
 testsuites/psxtests/psxcond03/psxcond03.doc   |  44 ++
 testsuites/psxtests/psxcond03/psxcond03.scn   |   3 +
 testsuites/psxtests/psxcond03/system.h        |  61 +++
 .../psxhdrs/pthread/pthread_cond_clockwait.c  |   2 +-
 14 files changed, 788 insertions(+), 25 deletions(-)
 create mode 100644 cpukit/posix/src/condclockwait.c
 create mode 100644 spec/build/testsuites/psxtests/psxcond03.yml
 create mode 100644 testsuites/psxtests/psxcond03/init.c
 create mode 100644 testsuites/psxtests/psxcond03/psxcond03.doc
 create mode 100644 testsuites/psxtests/psxcond03/psxcond03.scn
 create mode 100644 testsuites/psxtests/psxcond03/system.h
2.31.1
