[PATCH 1/1] Added Implementation / tests for pthread_cond_clockwait()
Matt Joyce mfjoyce2004 at gmail.com
Sat Sep 18 14:46:30 UTC 2021
Added implementation of the pthread_cond_clockwait()
method to cpukit/posix/src/condclockwait.c. Additional
logic added to condwaitsupp.c to implement the new
method. Pthread_cond_clockwait() has been added to the
Issue 8 POSIX Standard.
psxcond03 test added to testsuites/psxtests to test the
newly added method.
 cpukit/include/rtems/posix/condimpl.h         |   9 +-
 cpukit/posix/src/condclockwait.c              |  78 +++
 cpukit/posix/src/condtimedwait.c              |   3 +-
 cpukit/posix/src/condwait.c                   |   1 +
 cpukit/posix/src/condwaitsupp.c               | 114 ++++-
 spec/build/testsuites/psxtests/grp.yml        |   2 +
 spec/build/testsuites/psxtests/psxcond03.yml  |  20 +
 testsuites/psxtests/Makefile.am               |   9 +
 testsuites/psxtests/configure.ac              |   1 +
 testsuites/psxtests/psxcond03/init.c          | 466 ++++++++++++++++++
 testsuites/psxtests/psxcond03/psxcond03.doc   |  44 ++
 testsuites/psxtests/psxcond03/psxcond03.scn   |   3 +
 testsuites/psxtests/psxcond03/system.h        |  61 +++
 .../psxhdrs/pthread/pthread_cond_clockwait.c  |   2 +-
 14 files changed, 788 insertions(+), 25 deletions(-)
 create mode 100644 cpukit/posix/src/condclockwait.c
 create mode 100644 spec/build/testsuites/psxtests/psxcond03.yml
 create mode 100644 testsuites/psxtests/psxcond03/init.c
 create mode 100644 testsuites/psxtests/psxcond03/psxcond03.doc
 create mode 100644 testsuites/psxtests/psxcond03/psxcond03.scn
 create mode 100644 testsuites/psxtests/psxcond03/system.h
diff --git a/cpukit/include/rtems/posix/condimpl.h b/cpukit/include/rtems/posix/condimpl.h
index 66e09bf6d8..c49fbb24d4 100644
--- a/cpukit/include/rtems/posix/condimpl.h
+++ b/cpukit/include/rtems/posix/condimpl.h
@@ -39,6 +39,8 @@ typedef struct {
 #define POSIX_CONDITION_VARIABLES_MAGIC 0x18dfb1feUL
+#define CLOCK_NOT_SPECIFIED 0xdeadbeef
  *  Constant to indicate condition variable does not currently have
  *  a mutex assigned to it.
@@ -150,9 +152,10 @@ int _POSIX_Condition_variables_Signal_support(
  * timed wait version of condition variable wait routines.
 int _POSIX_Condition_variables_Wait_support(
-  pthread_cond_t            *cond,
-  pthread_mutex_t           *mutex,
-  const struct timespec     *abstime
+  pthread_cond_t               *restrict cond,
+  pthread_mutex_t              *restrict mutex,
+  clockid_t                    clock_id,
+  const struct timespec        *restrict abstime
 bool _POSIX_Condition_variables_Auto_initialization(
diff --git a/cpukit/posix/src/condclockwait.c b/cpukit/posix/src/condclockwait.c
new file mode 100644
index 0000000000..ebc95c86b4
--- /dev/null
+++ b/cpukit/posix/src/condclockwait.c
@@ -0,0 +1,78 @@
+ * @file
+ * @ingroup POSIXAPI
+ * @brief Waiting on a Condition
+* Copyright (C) 2021 Matthew Joyce
+* Redistribution and use in source and binary forms, with or without
+* modification, are permitted provided that the following conditions
+* are met:
+* 1. Redistributions of source code must retain the above copyright
+*    notice, this list of conditions and the following disclaimer.
+* 2. Redistributions in binary form must reproduce the above copyright
+*    notice, this list of conditions and the following disclaimer in the
+*    documentation and/or other materials provided with the distribution.
+* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+* POSSIBILITY OF SUCH DAMAGE.
+/* Defining to have access to function prototype in libc/include/pthread.h */
+#define _GNU_SOURCE
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/posix/condimpl.h>
+#include <rtems/score/todimpl.h>
+ *  pthread_cond_clockwait() appears in the Issue 8 POSIX Standard
+int pthread_cond_clockwait(
+   * POSIX Issue 8 does not specify that EINVAL is returned when abstime
+   * equals NULL.
+  if ( abstime == NULL ) {
+    return EINVAL;
+   * POSIX Issue 8 specifies that EINVAL is returned when the clock is not
+   * supported.
+  if ( clock_id != CLOCK_REALTIME ) {
+    if ( clock_id != CLOCK_MONOTONIC ) {
+      return EINVAL;
+  return _POSIX_Condition_variables_Wait_support(
+    cond,
+    mutex,
+    clock_id,
+    abstime
diff --git a/cpukit/posix/src/condtimedwait.c b/cpukit/posix/src/condtimedwait.c
index 0bc8bfc18e..cefd1d6cb6 100644
--- a/cpukit/posix/src/condtimedwait.c
+++ b/cpukit/posix/src/condtimedwait.c
@@ -36,8 +36,9 @@ int pthread_cond_timedwait(
     return EINVAL; /* not specified */
-    cond,
+    cond,
     mutex,
+    CLOCK_NOT_SPECIFIED,
     abstime
diff --git a/cpukit/posix/src/condwait.c b/cpukit/posix/src/condwait.c
index 09431e216d..85ca8e27c7 100644
--- a/cpukit/posix/src/condwait.c
+++ b/cpukit/posix/src/condwait.c
@@ -54,6 +54,7 @@ int pthread_cond_wait(
     cond,
     mutex,
     NULL
diff --git a/cpukit/posix/src/condwaitsupp.c b/cpukit/posix/src/condwaitsupp.c
index ee2f8a0787..01d5ca9794 100644
--- a/cpukit/posix/src/condwaitsupp.c
+++ b/cpukit/posix/src/condwaitsupp.c
@@ -26,6 +26,57 @@
 #include <rtems/score/status.h>
+#ifdef CLOCK_REALTIME_COARSE
+  RTEMS_STATIC_ASSERT(
+    ( CLOCK_NOT_SPECIFIED != CLOCK_REALTIME_COARSE),
+     "CLOCK_NOT_SPECIFIED conflicts with existing POSIX defined clock/n" );
+#endif
+#ifdef CLOCK_PROCESS_CPUTIME_ID
+    ( CLOCK_NOT_SPECIFIED != CLOCK_PROCESS_CPUTIME_ID),
+#endif
+    ( CLOCK_NOT_SPECIFIED != CLOCK_REALTIME),
+#endif
+#ifdef CLOCK_THREAD_CPUTIME_ID
+    ( CLOCK_NOT_SPECIFIED != CLOCK_THREAD_CPUTIME_ID),
+#endif
+#ifdef CLOCK_MONOTONIC
+    ( CLOCK_NOT_SPECIFIED != CLOCK_MONOTONIC),
+#endif
+#ifdef CLOCK_MONOTONIC_RAW
+    ( CLOCK_NOT_SPECIFIED != CLOCK_MONOTONIC_RAW),
+#endif
+#ifdef CLOCK_MONOTONIC_COARSE
+    ( CLOCK_NOT_SPECIFIED != CLOCK_MONOTONIC_COARSE),
+#endif
+#ifdef CLOCK_BOOTTIME
+    ( CLOCK_NOT_SPECIFIED != CLOCK_BOOTTIME),
+#endif
+#ifdef CLOCK_REALTIME_ALARM
+    ( CLOCK_NOT_SPECIFIED != CLOCK_REALTIME_ALARM),
+#endif
+#ifdef CLOCK_BOOTTIME_ALARM
+    ( CLOCK_NOT_SPECIFIED != CLOCK_BOOTTIME_ALARM),
+#endif
 static void _POSIX_Condition_variables_Mutex_unlock(
   Thread_queue_Queue   *queue,
   Thread_Control       *the_thread,
@@ -92,37 +143,66 @@ static void _POSIX_Condition_variables_Enqueue_with_timeout_realtime(
   POSIX_Condition_variables_Control *the_cond;
-  unsigned long                      flags;
-  Thread_queue_Context               queue_context;
-  int                                error;
+  unsigned long                     flags;
+  Thread_queue_Context              queue_context;
+  int                               error;
   Thread_Control                    *executing;
+  pthread_condattr_t                attr;
   the_cond = _POSIX_Condition_variables_Get( cond );
   POSIX_CONDITION_VARIABLES_VALIDATE_OBJECT( the_cond, flags );
   _Thread_queue_Context_initialize( &queue_context );
-  if ( abstime != NULL ) {
-    _Thread_queue_Context_set_timeout_argument( &queue_context, abstime, true );
+  _Thread_queue_Context_set_timeout_argument( &queue_context, abstime, true );
+  error = pthread_condattr_init( &attr );
+  _Assert( error == 0 );
-    if ( _POSIX_Condition_variables_Get_clock( flags ) == CLOCK_MONOTONIC ) {
+   * If the parameter clock_id is not specified, then the clock from the
+   * condition attributes shall be used.
+  if ( clock_id == CLOCK_NOT_SPECIFIED ) {
+    error = pthread_condattr_getclock( &attr, &clock_id );
+   * Now we have the desired clock_id, whether it came from cond_timedwait or
+   * cond_clockwait. If abstime is specified, we use the clock_id to set the
+   * correct timeout.
+  if ( abstime != NULL ) {
+     * We have already validated supported clocks in condclockwait.c.
+     * if clock_id is not CLOCK_MONOTONIC, then it is CLOCK_REALTIME.
+    if ( clock_id == CLOCK_MONOTONIC ) {
       _Thread_queue_Context_set_enqueue_callout(
         &queue_context,
         _POSIX_Condition_variables_Enqueue_with_timeout_monotonic
     } else {
-      _Thread_queue_Context_set_enqueue_callout(
+        _Thread_queue_Context_set_enqueue_callout(
         &queue_context,
-  } else {
+   * Otherwise, if the abstime parameter is NULL, this is a call to
+   * pthread_cond_wait and no timeout is necessary.
+  else {
       &queue_context,
       _POSIX_Condition_variables_Enqueue_no_timeout
@@ -138,9 +218,7 @@ int _POSIX_Condition_variables_Wait_support(
     _POSIX_Condition_variables_Release( the_cond, &queue_context );
     return EINVAL;
   the_cond->mutex = mutex;
   _Thread_queue_Context_set_thread_state(
     &queue_context,
     STATES_WAITING_FOR_CONDITION_VARIABLE
@@ -151,8 +229,8 @@ int _POSIX_Condition_variables_Wait_support(
     executing,
     &queue_context
-  error = _POSIX_Get_error_after_wait( executing );
+  error = _POSIX_Get_error_after_wait( executing );
    *  If the thread is interrupted, while in the thread queue, by
    *  a POSIX signal, then pthread_cond_wait returns spuriously,
@@ -160,15 +238,12 @@ int _POSIX_Condition_variables_Wait_support(
    *  returns a success status, except for the fact that it was not
    *  woken up a pthread_cond_signal() or a pthread_cond_broadcast().
   if ( error == EINTR ) {
     error = 0;
    *  When we get here the dispatch disable level is 0.
   if ( error != EPERM ) {
     int mutex_error;
@@ -178,6 +253,5 @@ int _POSIX_Condition_variables_Wait_support(
       error = EINVAL;
   return error;
diff --git a/spec/build/testsuites/psxtests/grp.yml b/spec/build/testsuites/psxtests/grp.yml
index fb7ce465ae..dc55c05124 100644
--- a/spec/build/testsuites/psxtests/grp.yml
+++ b/spec/build/testsuites/psxtests/grp.yml
@@ -87,6 +87,8 @@ links:
   uid: psxcond01
 - role: build-dependency
   uid: psxcond02
+- role: build-dependency
+  uid: psxcond03
   uid: psxconfig01
diff --git a/spec/build/testsuites/psxtests/psxcond03.yml b/spec/build/testsuites/psxtests/psxcond03.yml
index 0000000000..c0d53eb04e
--- /dev/null
+++ b/spec/build/testsuites/psxtests/psxcond03.yml
@@ -0,0 +1,20 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags: []
+copyrights:
+- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+cppflags: []
+cxxflags: []
+enabled-by: true
+features: c cprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/psxtests/psxcond03/init.c
+- cpukit/posix/src/condclockwait.c
+stlib: []
+target: testsuites/psxtests/psxcond03.exe
+type: build
+use-after: []
+use-before: []
\ No newline at end of file
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index a35f00b665..de1a87b05f 100755
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -349,6 +349,15 @@ psxcond02_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxcond02) \
 	$(support_includes) -I$(top_srcdir)/include
 endif
+if TEST_psxcond03
+psx_tests += psxcond03
+psx_screens += psxcond03/psxcond03.scn
+psx_docs += psxcond03/psxcond03.doc
+psxcond03_SOURCES = psxcond03/init.c psxcond03/system.h include/pmacros.h
+psxcond03_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxcond03) \
+	$(support_includes) -I$(top_srcdir)/include
+endif
 if TEST_psxconfig01
 psx_tests += psxconfig01
 psx_screens += psxconfig01/psxconfig01.scn
diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
index 3f95010cd3..d88f52a846 100644
--- a/testsuites/psxtests/configure.ac
+++ b/testsuites/psxtests/configure.ac
@@ -79,6 +79,7 @@ RTEMS_TEST_CHECK([psxclockrealtime01])
 RTEMS_TEST_CHECK([psxconcurrency01])
 RTEMS_TEST_CHECK([psxcond01])
 RTEMS_TEST_CHECK([psxcond02])
+RTEMS_TEST_CHECK([psxcond03])
 RTEMS_TEST_CHECK([psxconfig01])
 RTEMS_TEST_CHECK([psxdevctl01])
 RTEMS_TEST_CHECK([psxeintr_join])
diff --git a/testsuites/psxtests/psxcond03/init.c b/testsuites/psxtests/psxcond03/init.c
index 0000000000..54d5d5c7a4
--- /dev/null
+++ b/testsuites/psxtests/psxcond03/init.c
@@ -0,0 +1,466 @@
+* are met:
+/* Defining in order to access pthread_cond_clockwait in pthread.h */
+#endif
+#define CONFIGURE_INIT
+#include <pthread.h>
+#include <sched.h>
+#include <errno.h>
+#include <rtems.h>
+#include <tmacros.h>
+#include "system.h"
+pthread_cond_t cond = PTHREAD_COND_INITIALIZER;
+pthread_cond_t bad_cond;
+pthread_mutex_t mutex = PTHREAD_MUTEX_INITIALIZER;
+pthread_mutex_t bad_mutex;
+pthread_mutex_t new_mutex = PTHREAD_MUTEX_INITIALIZER;
+clockid_t clock_id1 = CLOCK_MONOTONIC;
+clockid_t clock_id2 = CLOCK_REALTIME;
+clockid_t clock_id3 = CLOCK_MONOTONIC_RAW;
+int count;
+int eno;
+int status;
+const char rtems_test_name[] = "PSXCOND 3";
+void *POSIX_Init(
+  void *argument
+  TEST_BEGIN();
+  pthread_t t1;
+  struct timespec abstime;
+  /* Expected pass: Clock Monotonic with sufficient abstime */
+  abstime.tv_sec = 2;
+  abstime.tv_nsec = 1;
+  status = pthread_create( &t1, NULL, thread_func, NULL );
+  rtems_test_assert( status == 0 );
+  status = pthread_mutex_lock( &mutex );
+  while ( count == 0 ){
+    eno = pthread_cond_clockwait( &cond, &mutex, clock_id1, &abstime );
+    if ( eno != 0 ) {
+      break;
+  count -= 1;
+  status = pthread_mutex_unlock( &mutex );
+  rtems_test_assert( eno == 0 );
+  status = pthread_join( t1, NULL );
+  /* Expected fail: Clock Monotonic with insufficient abstime */
+  abstime.tv_sec = 0;
+    if ( eno != 0 ) {
+      break;
+  count -= 1;
+  rtems_test_assert( eno == ETIMEDOUT );
+  /* Expected pass: Clock Realtime with sufficient abstime */
+  status = clock_gettime( clock_id2, &abstime );
+  abstime.tv_sec += 4;
+    eno = pthread_cond_clockwait( &cond, &mutex, clock_id2, &abstime );
+    if ( eno != 0 ) {
+      break;
+  count -= 1;
+  /* Expected fail: Clock Realtime with insufficient abstime */
+    if ( eno != 0 ) {
+      break;
+  count -= 1;
+  /* Expected fail: Unsupported Clock */
+    eno = pthread_cond_clockwait( &cond, &mutex, clock_id3, &abstime );
+    if ( eno != 0 ) {
+      break;
+  count -= 1;
+  rtems_test_assert( eno == EINVAL );
+  /* Expected fail: Invalid Clock */
+    eno = pthread_cond_clockwait( &cond, &mutex, (int)NULL, &abstime );
+    if ( eno != 0 ) {
+      break;
+  count -= 1;
+    eno = pthread_cond_clockwait( &cond, &mutex, clock_id1, NULL );
+    if ( eno != 0 ) {
+      break;
+  count -= 1;
+    eno = pthread_cond_clockwait( NULL, &mutex, clock_id1, &abstime );
+    if ( eno != 0 ) {
+      break;
+  count -= 1;
+  /* Expected fail: Invalid Mutex */
+    eno = pthread_cond_clockwait( &cond, NULL, clock_id1, &abstime );
+    if ( eno != 0 ) {
+      break;
+  count -= 1;
+  rtems_test_assert( eno != 0 );
+  /* Expected fail: Uninitialized condition variable */
+    eno = pthread_cond_clockwait( &bad_cond, &mutex, clock_id1, &abstime );
+    if ( eno != 0 ) {
+      break;
+  count -= 1;
+    eno = pthread_cond_clockwait( &cond, &bad_mutex, clock_id1, &abstime );
+    if ( eno != 0 ) {
+      break;
+  count -= 1;
+    if ( eno != 0 ) {
+      break;
+  count -= 1;
+  /* Expected pass: Binding new mutex to condition variable */
+  status = pthread_create( &t1, NULL, thread_func2, NULL );
+  status = pthread_mutex_lock( &new_mutex );
+    eno = pthread_cond_clockwait( &cond, &new_mutex, clock_id2, &abstime );
+    if ( eno != 0 ) {
+      break;
+  count -= 1;
+  status = pthread_mutex_unlock( &new_mutex );
+  /* Expected fail: Timeout (abstime < current time) */
+  abstime.tv_sec -= 1;
+  abstime.tv_nsec -= 1;
+    if ( eno != 0 ) {
+      break;
+  count -= 1;
+  /* Expected Pass: Sufficient abstime to exceed sleep in thread_func3*/
+  abstime.tv_nsec += 1;
+  status = pthread_create( &t1, NULL, thread_func3, NULL );
+    if ( eno != 0 ) {
+      break;
+  count -= 1;
+  /* Expected Fail: Insufficient abstime to exceed sleep in thread_func3*/
+  abstime.tv_sec += 2;
+    if ( eno != 0 ) {
+      break;
+  count -= 1;
+  TEST_END();
+  rtems_test_exit( 0 );
+  return NULL;
+void *thread_func( void *arg )
+  int status;
+  if (count == 0) {
+    status = pthread_cond_signal( &cond );
+  count +=1;
+  return NULL;
+void *thread_func2( void *arg )
+  int status;
+  if ( count == 0 ) {
+  count +=1;
+  return NULL;
+void *thread_func3( void *arg )
+  int status;
+  /* Arbitrary sleep to test timeout functionality */
+  sleep(3);
+  count +=1;
+  return NULL;
diff --git a/testsuites/psxtests/psxcond03/psxcond03.doc b/testsuites/psxtests/psxcond03/psxcond03.doc
index 0000000000..4e9b582189
--- /dev/null
+++ b/testsuites/psxtests/psxcond03/psxcond03.doc
@@ -0,0 +1,44 @@
+* are met:
+This file describes the directives and concepts tested by this test set.
+test set name:  psxcond03
+directives:
+  pthread_cond_clockwait
+  pthread_create
+  pthread_mutex_lock
+  pthread_mutex_unlock
+  pthread_cond_signal
+  pthread_join
+concepts:
++ Tests the newly-added Issue 8 POSIX Standard pthread_cond_clockwait method.
+  Tests include valid/supported and invalid/unsupported clocks, sufficient and
+  insufficient timeouts, and invalid or uninitialized condition/mutex
+  parameters.
diff --git a/testsuites/psxtests/psxcond03/psxcond03.scn b/testsuites/psxtests/psxcond03/psxcond03.scn
index 0000000000..5935b1d478
--- /dev/null
+++ b/testsuites/psxtests/psxcond03/psxcond03.scn
@@ -0,0 +1,3 @@
+*** BEGIN OF TEST PSXCOND 3 ***
+*** END OF TEST PSXCOND 3 ***
diff --git a/testsuites/psxtests/psxcond03/system.h b/testsuites/psxtests/psxcond03/system.h
index 0000000000..b9dcb832ad
--- /dev/null
+++ b/testsuites/psxtests/psxcond03/system.h
@@ -0,0 +1,61 @@
+* are met:
+/* functions */
+#include <pmacros.h>
+#include <unistd.h>
+#include <errno.h>
+void *POSIX_Init(
+  void *argument
+void *thread_func(
+  void *argument
+  void *argument
+  void *argument
+/* configuration information */
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_MAXIMUM_POSIX_THREADS              4
+#define CONFIGURE_POSIX_INIT_THREAD_TABLE
+#include <rtems/confdefs.h>
+/* end of include file */
diff --git a/testsuites/psxtests/psxhdrs/pthread/pthread_cond_clockwait.c b/testsuites/psxtests/psxhdrs/pthread/pthread_cond_clockwait.c
index 15485eb587..fe91b7954f 100644
--- a/testsuites/psxtests/psxhdrs/pthread/pthread_cond_clockwait.c
+++ b/testsuites/psxtests/psxhdrs/pthread/pthread_cond_clockwait.c
@@ -49,7 +49,7 @@ int test( void )
   clockid_t clock_id = CLOCK_REALTIME;
-  abstime.tv_sec = 2;
+  abstime.tv_sec = 1;
   int result;
   /* This method appeared in the Issue 8 POSIX Standard */
2.31.1
