[PATCH] bsp-builder: Fix mailer options exception
Mon Sep 20 20:43:51 UTC 2021
Hi Alex,
I prefer Python’s argparse and prefer we move the other way. The options handling originally came from the RSB and has lots of issues. I regret it.
Sorry about this.
> On 21 Sep 2021, at 2:08 am, Alex White <alex.white at oarcorp.com> wrote:
> This changes the object holding the command line arguments from an
> argparse.Namespace to an rtemstoolkit.options.command_line. This matches
> the type expected by rtemstoolkit.mailer.mail.__init__ and is the type
> used in tester/rt/test.py and run.py.
> tester/rt/check.py | 151 +++++++++++++++++++++++++--------------------
> 1 file changed, 84 insertions(+), 67 deletions(-)
> diff --git a/tester/rt/check.py b/tester/rt/check.py
> index c01c25d..982b65e 100755
> --- a/tester/rt/check.py
> +++ b/tester/rt/check.py
> @@ -54,6 +54,8 @@ from rtemstoolkit import rtems
> from rtemstoolkit import textbox
> from rtemstoolkit import version
> +import tester.rt.options
> # Group loggin entries together.
> @@ -1153,55 +1155,40 @@ def run(args):
>         description += 'can build based on tier, architecture, or BSP. You can control '
>         description += 'the profile of build with various build configuration settings.'
> -        argsp = argparse.ArgumentParser(prog = 'rtems-bsp-builder',
> -                                        description = description)
> -        argsp.add_argument('--prefix', help = 'Prefix to build the BSP.',
> -                           type = str)
> -        argsp.add_argument('--rtems-tools', help = 'The RTEMS tools directory.',
> -                           type = str)
> -        argsp.add_argument('--rtems', help = 'The RTEMS source tree.',
> -                           type = str)
> -        argsp.add_argument('--build-path', help = 'Path to build in.',
> -                           type = str)
> -        argsp.add_argument('--log', help = 'Log file.', type = str)
> -        argsp.add_argument('--config-report', help = 'Report the configuration.',
> -                           type = str, default = None,
> -                           choices = ['all', 'profiles', 'builds', 'archs'])
> -        argsp.add_argument('--warnings-report', help = 'Report the warnings to a file.',
> -                           type = str, default = None)
> -        argsp.add_argument('--failures-report', help = 'Report the failures to a file.',
> -        argsp.add_argument('--stop-on-error', help = 'Stop on an error.',
> -                           action = 'store_true')
> -        argsp.add_argument('--no-clean', help = 'Do not clean the build output.',
> -        argsp.add_argument('--profiles', help = 'Build the listed profiles (profile,profile,..).',
> -                           type = str, default = 'tier-1')
> -        argsp.add_argument('--arch', help = 'Build the architectures (arch,arch,..).',
> -                           type = str)
> -        argsp.add_argument('--bsp', help = 'Build the BSPs (arch/bsp,arch/bsp,..).',
> -                           type = str)
> -        argsp.add_argument('--build', help = 'Build name to build (see --config-report).',
> -                           type = str, default='all')
> -        argsp.add_argument('--jobs', help = 'Number of jobs to run.',
> -                           type = str, default = '1/%d' % (host.cpus()))
> -        argsp.add_argument('--dry-run', help = 'Do not run the actual builds.',
> -        mailer.add_arguments(argsp)
> -        opts = argsp.parse_args(args[1:])
> +        optargs = {
> +            '--prefix': 'Prefix to build the BSP.',
> +            '--rtems-tools': 'The RTEMS tools directory.',
> +            '--rtems': 'The RTEMS source tree.',
> +            '--build-path': 'Path to build in.',
> +            '--log': 'Log file.',
> +            '--config-report': 'Report the configuration.',
> +            '--warnings-report': 'Report the warnings to a file.',
> +            '--failures-report': 'Report the failures to a file.',
> +            '--stop-on-error': 'Stop on an error.',
> +            '--no-clean': 'Do not clean the build output.',
> +            '--profiles': 'Build the listed profiles (profile,profile,..).',
> +            '--arch': 'Build the architectures (arch,arch,..).',
> +            '--bsp': 'Build the BSPs (arch/bsp,arch/bsp,..).',
> +            '--build': 'Build name to build (see --config-report).',
> +            '--jobs': 'Number of jobs to run.',
> +            '--dry-run': 'Do not run the actual builds.'
> +        mailer.append_options(optargs)
> +        opts = tester.rt.options.load(args, optargs = optargs)
>         mail = None
> -        if opts.mail:
> +        if opts.find_arg('--mail'):
>             mail = mailer.mail(opts)
>             # Request these now to generate any errors.
>             from_addr = mail.from_address()
>             smtp_host = mail.smtp_host()
> -            if 'mail_to' in opts and opts.mail_to is not None:
> -                to_addr = opts.mail_to
> +            to_addr = opts.find_arg('--mail-to')
> +            if to_addr:
> +                to_addr = to_addr[1]
>             else:
>                 to_addr = 'build at rtems.org'
> -        if opts.log is not None:
> -            logf = opts.log
> +        if opts.find_arg('--log') is not None:
> +            logf = opts.find_arg('--log')[1]
>         log.default = log.log([logf])
>         log.notice(title())
>         log.output(command_line())
> @@ -1211,48 +1198,78 @@ def run(args):
>                                                         smtp_host))
>         config = rtems.configuration()
> -        config.load(config_file, opts.build)
> +        build = opts.find_arg('--build')
> +        if build is not None:
> +            build = build[1]
> +        config.load(config_file, build)
> -        if opts.config_report:
> -            log.notice('Configuration Report: %s' % (opts.config_report))
> +        config_report = opts.find_arg('--config-report')
> +        if config_report is not None:
> +            log.notice('Configuration Report: %s' % (config_report[1]))
>             c_profiles = False
>             c_builds = False
>             c_archs = False
> -            if opts.config_report == 'all':
> +            if config_report[1] == 'all':
>                 c_profiles = True
>                 c_builds = True
>                 c_archs = True
> -            elif opts.config_report == 'profiles':
> +            elif config_report[1] == 'profiles':
>                 c_profiles = True
> -            elif opts.config_report == 'builds':
> +            elif config_report[1] == 'builds':
>                 c_builds = True
> -            elif opts.config_report == 'archs':
> +            elif config_report[1] == 'archs':
>                 c_archs = True
>             log.notice(config.report(c_profiles, c_builds, c_archs))
>             sys.exit(0)
> -        if opts.rtems is None:
> +        rtems_opt = opts.find_arg('--rtems')
> +        if rtems_opt is None:
>             raise error.general('No RTEMS source provided on the command line')
> -        if opts.prefix is not None:
> -            prefix = path.shell(opts.prefix)
> -        if opts.rtems_tools is not None:
> -            tools = path.shell(opts.rtems_tools)
> -        if opts.build_path is not None:
> -            build_dir = path.shell(opts.build_path)
> -        options = { 'stop-on-error'   : opts.stop_on_error,
> -                    'no-clean'        : opts.no_clean,
> -                    'dry-run'         : opts.dry_run,
> -                    'jobs'            : opts.jobs,
> -                    'warnings-report' : opts.warnings_report,
> -                    'failures-report' : opts.failures_report }
> +        prefix_opt = opts.find_arg('--prefix')
> +        if prefix_opt is not None:
> +            prefix = path.shell(prefix_opt[1])
> +        rtems_tools = opts.find_arg('--rtems-tools')
> +        if rtems_tools is not None:
> +            tools = path.shell(rtems_tools[1])
> +        build_path = opts.find_arg('--build-path')
> +        if build_path is not None:
> +            build_dir = path.shell(build_path[1])
> +        jobs = opts.find_arg('--jobs')
> +        if jobs is not None:
> +            jobs = jobs[1]
> +        else:
> +            jobs = '1/%d' % (host.cpus())
> +        warnings_report = opts.find_arg('--warnings-report')
> +        if warnings_report is not None:
> +            warnings_report = warnings_report[1]
> +        failures_report = opts.find_arg('--failures-report')
> +        if failures_report is not None:
> +            failures_report = failures_report[1]
> +        options = { 'stop-on-error'   : opts.find_arg('--stop-on-error'),
> +                    'no-clean'        : opts.no_clean(),
> +                    'dry-run'         : opts.dry_run(),
> +                    'jobs'            : jobs,
> +                    'warnings-report' : warnings_report,
> +                    'failures-report' : failures_report }
>         b = builder(config, rtems_version(), prefix, tools,
> -                    path.shell(opts.rtems), build_dir, options)
> +                    path.shell(rtems_opt[1]), build_dir, options)
> -        profiles = comma_split(opts.profiles)
> -        archs = comma_split(opts.arch)
> -        bsps = comma_split(opts.bsp)
> +        profiles_opt = opts.find_arg('--profiles')
> +        if profiles_opt is not None:
> +            profiles_opt = profiles_opt[1]
> +        else:
> +            profiles_opt = 'tier-1'
> +        arch_opt = opts.find_arg('--arch')
> +        if arch_opt is not None:
> +            arch_opt = arch_opt[1]
> +        bsp_opt = opts.find_arg('--bsp')
> +        if bsp_opt is not None:
> +            bsp_opt = bsp_opt[1]
> +        profiles = comma_split(profiles_opt)
> +        archs = comma_split(arch_opt)
> +        bsps = comma_split(bsp_opt)
>         # The default is build a profile.
> 2.27.0
> devel mailing list
> devel at rtems.org
