[PATCH v1 1/5] bsps/shared: Add PSCI SMP startup support
Kinsey Moore kinsey.moore at oarcorp.com
Mon Sep 20 21:38:25 UTC 2021
This adds the SMP function that supports spinup of additional CPU cores
using the ARM standard PSCI inteface. This interface is provided by QEMU
as well as ARM Trusted Firmware running in monitor mode (EL3) on ARMv7 and
AArch64 CPUs. This supports activation va SMC or HVC instructions
depending on BSP configuration.
 bsps/shared/start/bspsmp-arm-psci.c | 92 +++++++++++++++++++++++++++++
 1 file changed, 92 insertions(+)
 create mode 100644 bsps/shared/start/bspsmp-arm-psci.c
diff --git a/bsps/shared/start/bspsmp-arm-psci.c b/bsps/shared/start/bspsmp-arm-psci.c
new file mode 100644
index 0000000000..879aeb6480
--- /dev/null
+++ b/bsps/shared/start/bspsmp-arm-psci.c
@@ -0,0 +1,92 @@
+ * @file
+ * @ingroup RTEMSBSPsShared
+ * @brief PSCI-based BSP CPU start.
+ * Copyright (C) 2021 On-Line Applications Research Corporation (OAR)
+ * Written by Kinsey Moore <kinsey.moore at oarcorp.com>
+ * are met:
+#include <rtems/score/smpimpl.h>
+#include <bsp/start.h>
+#include <bsp.h>
+#if defined( AARCH64_MULTILIB_ARCH_V8 ) || \
+  defined( AARCH64_MULTILIB_ARCH_V8_ILP32 )
+#include <rtems/score/aarch64-system-registers.h>
+#else
+#include <rtems/score/aarch32-system-registers.h>
+#endif
+#define REGISTER_PREFIX "x"
+#else
+#define REGISTER_PREFIX "r"
+#endif
+bool _CPU_SMP_Start_processor( uint32_t cpu_index )
+  uint32_t PSCI_FN_SYSTEM_CPU_ON = 0xC4000003;
+  uint64_t target_cpu = _AArch64_Read_mpidr_el1();
+  uint64_t ret;
+#else
+  uint32_t PSCI_FN_SYSTEM_CPU_ON = 0x84000003;
+  uint32_t target_cpu = _AArch32_Read_mpidr();
+  uint32_t ret;
+#endif
+  target_cpu &= ~( 0xff0000ffUL );
+  target_cpu |= cpu_index;
+  __asm__ volatile (
+    "mov " REGISTER_PREFIX "0, %1\n"
+    "mov " REGISTER_PREFIX "1, %2\n"
+    "mov " REGISTER_PREFIX "2, %3\n"
+    "mov " REGISTER_PREFIX "3, #0\n"
+#ifdef BSP_CPU_ON_SMC
+    "smc #0\n"
+#else
+    "hvc #0\n"
+#endif
+    "mov %0, " REGISTER_PREFIX "0\n"
+    : "=r" ( ret ) : "r" ( PSCI_FN_SYSTEM_CPU_ON ), "r" ( target_cpu ),
+    "r" ( _start )
+    : REGISTER_PREFIX "0", REGISTER_PREFIX "1", REGISTER_PREFIX "2",
+    REGISTER_PREFIX "3"
+  if ( ret != 0 ) {
+    return false;
+  return _Per_CPU_State_wait_for_non_initial_state( cpu_index, 0 );
2.30.2
