[PATCH v2 5/5] cpukit: Add AArch64 SMP Support
Kinsey Moore kinsey.moore at oarcorp.com
Mon Sep 20 22:43:41 UTC 2021
This adds SMP support for AArch64 in cpukit and for the ZynqMP BSPs.
 bsps/aarch64/include/bsp/aarch64-mmu.h        | 13 ++-
 bsps/aarch64/shared/start/aarch64-smp.c       | 85 +++++++++++++++++++
 bsps/aarch64/shared/start/start.S             | 12 +--
 .../aarch64/xilinx-versal/start/bspstartmmu.c |  4 +-
 bsps/aarch64/xilinx-zynqmp/include/bsp.h      |  9 ++
 .../xilinx-zynqmp/start/bspstarthooks.c       | 40 ++++++++-
 .../aarch64/xilinx-zynqmp/start/bspstartmmu.c | 28 ++++--
 .../cpu/aarch64/aarch64-exception-interrupt.S |  6 +-
 cpukit/score/cpu/aarch64/cpu_asm.S            | 78 ++++++++++++++++-
 cpukit/score/cpu/aarch64/include/rtems/asm.h  |  5 ++
 .../cpu/aarch64/include/rtems/score/cpu.h     | 13 ++-
 .../cpu/aarch64/include/rtems/score/cpuimpl.h | 67 ++++++++++++++-
 spec/build/bsps/aarch64/xilinx-zynqmp/abi.yml |  2 +
 spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml |  2 +
 .../bsps/aarch64/xilinx-zynqmp/objsmp.yml     | 16 ++++
 spec/build/cpukit/optsmp.yml                  |  4 +
 testsuites/smptests/smpfatal08/init.c         |  2 +-
 17 files changed, 350 insertions(+), 36 deletions(-)
 create mode 100644 bsps/aarch64/shared/start/aarch64-smp.c
 create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/objsmp.yml
diff --git a/bsps/aarch64/include/bsp/aarch64-mmu.h b/bsps/aarch64/include/bsp/aarch64-mmu.h
index e82012576f..a5f6e846f3 100644
--- a/bsps/aarch64/include/bsp/aarch64-mmu.h
+++ b/bsps/aarch64/include/bsp/aarch64-mmu.h
@@ -385,17 +385,14 @@ BSP_START_TEXT_SECTION static inline void aarch64_mmu_setup_translation_table(
-aarch64_mmu_setup_translation_table_and_enable(
-  const aarch64_mmu_config_entry *config_table,
-  size_t config_count
+aarch64_mmu_enable( void )
   uint64_t sctlr;
-  aarch64_mmu_setup_translation_table(
-    config_table,
-    config_count
+  /* CPUECTLR_EL1.SMPEN is already set on ZynqMP and is not writable */
+  /* Invalidate cache */
+  rtems_cache_invalidate_entire_data();
   /* Enable MMU and cache */
   sctlr = _AArch64_Read_sctlr_el1();
diff --git a/bsps/aarch64/shared/start/aarch64-smp.c b/bsps/aarch64/shared/start/aarch64-smp.c
new file mode 100644
index 0000000000..5ec7babce7
--- /dev/null
+++ b/bsps/aarch64/shared/start/aarch64-smp.c
@@ -0,0 +1,85 @@
+ * @file
+ * @ingroup RTEMSBSPsAArch64Shared
+ * @brief SMP startup and interop code.
+ * Copyright (C) 2021 On-Line Applications Research Corporation (OAR)
+ * Written by Kinsey Moore <kinsey.moore at oarcorp.com>
+ * are met:
+#include <rtems/score/smpimpl.h>
+#include <bsp/irq.h>
+static void bsp_inter_processor_interrupt( void *arg )
+  _SMP_Inter_processor_interrupt_handler( _Per_CPU_Get() );
+uint32_t _CPU_SMP_Initialize( void )
+  return arm_gic_irq_processor_count();
+void _CPU_SMP_Finalize_initialization( uint32_t cpu_count )
+  if ( cpu_count > 0 ) {
+    rtems_status_code sc;
+    sc = rtems_interrupt_handler_install(
+      ARM_GIC_IRQ_SGI_0,
+      "IPI",
+      RTEMS_INTERRUPT_UNIQUE,
+      bsp_inter_processor_interrupt,
+      NULL
+    _Assert( sc == RTEMS_SUCCESSFUL );
+    (void) sc;
+#if defined( BSP_DATA_CACHE_ENABLED ) || \
+    defined( BSP_INSTRUCTION_CACHE_ENABLED )
+    /* Enable unified L2 cache */
+    rtems_cache_enable_data();
+#endif
+void _CPU_SMP_Prepare_start_multitasking( void )
+  /* Do nothing */
+void _CPU_SMP_Send_interrupt( uint32_t target_processor_index )
+  arm_gic_irq_generate_software_irq(
+    1U << target_processor_index
diff --git a/bsps/aarch64/shared/start/start.S b/bsps/aarch64/shared/start/start.S
index f4c39dacdf..bc6a855217 100644
--- a/bsps/aarch64/shared/start/start.S
+++ b/bsps/aarch64/shared/start/start.S
@@ -166,21 +166,21 @@ _el1_start:
 #ifdef RTEMS_SMP
   /* Read MPIDR and get current processor index */
   mrs x7, mpidr_el1
-  and x7, #0xff
+  and x7, x7, #0xff
 #endif
 #ifdef RTEMS_SMP
    * Get current per-CPU control and store it in PL1 only Thread ID
-   * Register (TPIDRPRW).
+   * Register (TPIDR_EL1).
 #ifdef AARCH64_MULTILIB_ARCH_V8_ILP32
   ldr w1, =_Per_CPU_Information
 #else
   ldr x1, =_Per_CPU_Information
 #endif
-  add x1, x1, x7, asl #PER_CPU_CONTROL_SIZE_LOG2
-  mcr p15, 0, x1, c13, c0, 4
+  add x1, x1, x7, lsl #PER_CPU_CONTROL_SIZE_LOG2
+  msr TPIDR_EL1, x1
 #endif
@@ -201,8 +201,8 @@ _el1_start:
 #endif
   add x3, x1, x2
-  /* Save original DAIF value */
-  mrs  x4, DAIF
+  /* Disable interrupts */
+  msr DAIFSet, #0x2
 #ifdef BSP_START_NEEDS_REGISTER_INITIALIZATION
   mov x8, XZR
diff --git a/bsps/aarch64/xilinx-versal/start/bspstartmmu.c b/bsps/aarch64/xilinx-versal/start/bspstartmmu.c
index 6ab33cc4f1..8b622aec7d 100644
--- a/bsps/aarch64/xilinx-versal/start/bspstartmmu.c
+++ b/bsps/aarch64/xilinx-versal/start/bspstartmmu.c
@@ -70,8 +70,10 @@ versal_setup_mmu_and_cache( void )
   aarch64_mmu_setup();
-  aarch64_mmu_setup_translation_table_and_enable(
+  aarch64_mmu_setup_translation_table(
     &versal_mmu_config_table[ 0 ],
     RTEMS_ARRAY_SIZE( versal_mmu_config_table )
+  aarch64_mmu_enable();
diff --git a/bsps/aarch64/xilinx-zynqmp/include/bsp.h b/bsps/aarch64/xilinx-zynqmp/include/bsp.h
index 6d49b9ad2a..c867fe1801 100644
--- a/bsps/aarch64/xilinx-zynqmp/include/bsp.h
+++ b/bsps/aarch64/xilinx-zynqmp/include/bsp.h
@@ -60,6 +60,7 @@ extern "C" {
 #define BSP_ARM_GIC_DIST_BASE 0xf9010000
 #define BSP_RESET_SMC
+#define BSP_CPU_ON_SMC
  * @brief Zynq UltraScale+ MPSoC specific set up of the MMU.
@@ -68,6 +69,14 @@ extern "C" {
 BSP_START_TEXT_SECTION void zynqmp_setup_mmu_and_cache(void);
+ * @brief Zynq UltraScale+ MPSoC specific set up of the MMU for non-primary
+ * cores.
+ * Provide in the application to override the defaults in the BSP.
+BSP_START_TEXT_SECTION void zynqmp_setup_secondary_cpu_mmu_and_cache( void );
 void zynqmp_debug_console_flush(void);
 uint32_t zynqmp_clock_i2c0(void);
diff --git a/bsps/aarch64/xilinx-zynqmp/start/bspstarthooks.c b/bsps/aarch64/xilinx-zynqmp/start/bspstarthooks.c
index 7bd787592c..ad688088e5 100644
--- a/bsps/aarch64/xilinx-zynqmp/start/bspstarthooks.c
+++ b/bsps/aarch64/xilinx-zynqmp/start/bspstarthooks.c
@@ -38,12 +38,46 @@
 #include <bsp.h>
 #include <bsp/start.h>
-BSP_START_TEXT_SECTION void bsp_start_hook_0(void)
+#ifdef RTEMS_SMP
+#include <rtems/score/aarch64-system-registers.h>
+#include <bsp/irq-generic.h>
+#endif
+BSP_START_TEXT_SECTION void bsp_start_hook_0( void )
-  /* Do nothing */
+#ifdef RTEMS_SMP
+  uint32_t cpu_index_self;
+  cpu_index_self = _SMP_Get_current_processor();
+  if ( cpu_index_self != 0 ) {
+    if (
+      cpu_index_self >= rtems_configuration_get_maximum_processors()
+      || !_SMP_Should_start_processor( cpu_index_self )
+      while ( true ) {
+        _AARCH64_Wait_for_event();
+    /* Change the VBAR from the start to the normal vector table */
+    AArch64_start_set_vector_base();
+    zynqmp_setup_secondary_cpu_mmu_and_cache();
+    arm_gic_irq_initialize_secondary_cpu();
+    bsp_interrupt_vector_enable( ARM_GIC_IRQ_SGI_0 );
+    _SMP_Start_multitasking_on_secondary_processor(
+      _Per_CPU_Get_by_index( cpu_index_self )
+#endif
-BSP_START_TEXT_SECTION void bsp_start_hook_1(void)
+BSP_START_TEXT_SECTION void bsp_start_hook_1( void )
   bsp_start_copy_sections();
diff --git a/bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c b/bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c
index 8d302e97b5..09012c9db5 100644
--- a/bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c
+++ b/bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c
@@ -41,13 +41,6 @@
 BSP_START_DATA_SECTION static const aarch64_mmu_config_entry
 zynqmp_mmu_config_table[] = {
   AARCH64_MMU_DEFAULT_SECTIONS,
-#if defined( RTEMS_SMP )
-    .begin = 0xffff0000U,
-    .end = 0xffffffffU,
-    .flags = AARCH64_MMU_DEVICE
-#endif
     .begin = 0xf9000000U,
     .end = 0xf9100000U,
@@ -70,8 +63,27 @@ zynqmp_setup_mmu_and_cache( void )
     &zynqmp_mmu_config_table[ 0 ],
     RTEMS_ARRAY_SIZE( zynqmp_mmu_config_table )
+ * Make weak and let the user override.
+__attribute__ ( ( weak ) );
+  /* Perform basic MMU setup */
+  aarch64_mmu_setup();
+  /* Use the existing root page table already configured by CPU0 */
+  _AArch64_Write_ttbr0_el1( (uintptr_t) bsp_translation_table_base );
diff --git a/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S b/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
index cb0954a29b..b206f5764b 100644
--- a/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
+++ b/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
@@ -47,7 +47,11 @@
 .globl	_AArch64_Exception_interrupt_nest
-  #define SELF_CPU_CONTROL_GET_REG w19
+  #ifdef RTEMS_SMP
+    #define SELF_CPU_CONTROL_GET_REG x19
+  #else
+    #define SELF_CPU_CONTROL_GET_REG w19
+  #endif
 #else
 #endif
diff --git a/cpukit/score/cpu/aarch64/cpu_asm.S b/cpukit/score/cpu/aarch64/cpu_asm.S
index 9e609e06bd..2379698336 100644
--- a/cpukit/score/cpu/aarch64/cpu_asm.S
+++ b/cpukit/score/cpu/aarch64/cpu_asm.S
@@ -55,13 +55,22 @@
+DEFINE_FUNCTION_AARCH64(_CPU_Context_switch)
+	.globl	_CPU_Context_switch_no_return
+	.set	_CPU_Context_switch_no_return, _CPU_Context_switch
-#define reg_2 w2
+/* Sanitize inputs for ILP32 ABI */
+	mov w0, w0
+	mov w1, w1
+  #ifdef RTEMS_SMP
+    #define reg_2 x2
+  #else
+    #define reg_2 w2
+  #endif
 #else
 #define reg_2 x2
 #endif
-DEFINE_FUNCTION_AARCH64(_CPU_Context_switch)
 /* Start saving context */
 	GET_SELF_CPU_CONTROL	reg_2
 	ldr	w3, [x2, #PER_CPU_ISR_DISPATCH_DISABLE]
@@ -86,7 +95,30 @@ DEFINE_FUNCTION_AARCH64(_CPU_Context_switch)
 	str	x3, [x0, #AARCH64_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE]
 #ifdef RTEMS_SMP
-#error SMP not yet supported
+	 * The executing thread no longer executes on this processor.  Switch
+	 * the stack to the temporary interrupt stack of this processor.  Mark
+	 * the context of the executing thread as not executing.
+	dmb	SY
+	add	sp, x2, #(PER_CPU_INTERRUPT_FRAME_AREA + CPU_INTERRUPT_FRAME_SIZE)
+	mov	x3, #0
+	strb	w3, [x0, #AARCH64_CONTEXT_CONTROL_IS_EXECUTING_OFFSET]
+.L_check_is_executing:
+	/* Check the is executing indicator of the heir context */
+	add	x3, x1, #AARCH64_CONTEXT_CONTROL_IS_EXECUTING_OFFSET
+	ldaxrb	w4, [x3]
+	cmp	x4, #0
+	bne	.L_get_potential_new_heir
+	/* Try to update the is executing indicator of the heir context */
+	mov	x4, #1
+	stlxrb	w5, w4, [x3]
+	cmp	x5, #0
+	dmb	SY
 #endif
 /* Start restoring context */
@@ -129,6 +161,46 @@ DEFINE_FUNCTION_AARCH64(_CPU_Context_switch)
 DEFINE_FUNCTION_AARCH64(_CPU_Context_restore)
+#ifdef AARCH64_MULTILIB_ARCH_V8_ILP32
+/* Sanitize input for ILP32 ABI */
+	mov w0, w0
+#endif
         mov     x1, x0
         b       .L_restore
+#ifdef RTEMS_SMP
+.L_get_potential_new_heir:
+	/* We may have a new heir */
+	/* Read the executing and heir */
+	ldr	w4, [x2, #PER_CPU_OFFSET_EXECUTING]
+	ldr	w5, [x2, #PER_CPU_OFFSET_HEIR]
+#else
+	ldr	x4, [x2, #PER_CPU_OFFSET_EXECUTING]
+	ldr	x5, [x2, #PER_CPU_OFFSET_HEIR]
+#endif
+	 * Update the executing only if necessary to avoid cache line
+	 * monopolization.
+	cmp	x4, x5
+	beq	.L_check_is_executing
+	/* Calculate the heir context pointer */
+	sub	x4, x1, x4
+	add	x1, x5, x4
+	/* Update the executing */
+	str	w5, [x2, #PER_CPU_OFFSET_EXECUTING]
+#else
+	str	x5, [x2, #PER_CPU_OFFSET_EXECUTING]
+#endif
+	b	.L_check_is_executing
+#endif
diff --git a/cpukit/score/cpu/aarch64/include/rtems/asm.h b/cpukit/score/cpu/aarch64/include/rtems/asm.h
index 35bf533c8a..fa53e08291 100644
--- a/cpukit/score/cpu/aarch64/include/rtems/asm.h
+++ b/cpukit/score/cpu/aarch64/include/rtems/asm.h
@@ -81,7 +81,12 @@
   .align 8 ; .globl name ; name: ; .globl name ## _aarch64 ; name ## _aarch64:
 .macro GET_SELF_CPU_CONTROL REG
+#ifdef RTEMS_SMP
+	/* Use Thread ID Register (TPIDR_EL1) */
+	mrs	\REG, TPIDR_EL1
+#else
 	ldr	\REG, =_Per_CPU_Information
+#endif
 .endm
diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
index dacc18638e..82f74193a2 100644
--- a/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
@@ -134,9 +134,9 @@
 #ifdef RTEMS_SMP
   #if defined(AARCH64_MULTILIB_VFP)
-    #define AARCH64_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 0x70
+    #define AARCH64_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 0xb8
   #else
-    #define AARCH64_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 0x30
+    #define AARCH64_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 0x78
   #endif
 #endif
@@ -191,12 +191,12 @@ typedef struct {
 static inline void _AARCH64_Data_memory_barrier( void )
-  __asm__ volatile ( "dmb LD" : : : "memory" );
+  __asm__ volatile ( "dmb SY" : : : "memory" );
 static inline void _AARCH64_Data_synchronization_barrier( void )
-  __asm__ volatile ( "dsb LD" : : : "memory" );
+  __asm__ volatile ( "dsb SY" : : : "memory" );
 static inline void _AARCH64_Instruction_synchronization_barrier( void )
@@ -313,6 +313,11 @@ void _CPU_ISR_install_vector(
 void _CPU_Context_switch( Context_Control *run, Context_Control *heir );
+RTEMS_NO_RETURN void _CPU_Context_switch_no_return(
+  Context_Control *executing,
+  Context_Control *heir
 RTEMS_NO_RETURN void _CPU_Context_restore( Context_Control *new_context );
 #ifdef RTEMS_SMP
diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
index 0536ecd860..90fd48ad4e 100644
--- a/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
@@ -50,7 +50,7 @@
 #define CPU_PER_CPU_CONTROL_SIZE 0
-#define CPU_INTERRUPT_FRAME_SIZE 240
+#define CPU_INTERRUPT_FRAME_SIZE 0x2E0
 #ifndef ASM
@@ -60,6 +60,71 @@ extern "C" {
 RTEMS_NO_RETURN void _CPU_Fatal_halt( uint32_t source, CPU_Uint32ptr error );
+typedef struct {
+  uint64_t x0;
+  uint64_t register_lr_original;
+  uint64_t register_lr;
+  uint64_t x1;
+  uint64_t x2;
+  uint64_t x3;
+  uint64_t x4;
+  uint64_t x5;
+  uint64_t x6;
+  uint64_t x7;
+  uint64_t x8;
+  uint64_t x9;
+  uint64_t x10;
+  uint64_t x11;
+  uint64_t x12;
+  uint64_t x13;
+  uint64_t x14;
+  uint64_t x15;
+  uint64_t x16;
+  uint64_t x17;
+  uint64_t x18;
+  uint64_t x19;
+  uint64_t x20;
+  uint64_t x21;
+#ifdef AARCH64_MULTILIB_VFP
+  uint128_t q0;
+  uint128_t q1;
+  uint128_t q2;
+  uint128_t q3;
+  uint128_t q4;
+  uint128_t q5;
+  uint128_t q6;
+  uint128_t q7;
+  uint128_t q8;
+  uint128_t q9;
+  uint128_t q10;
+  uint128_t q11;
+  uint128_t q12;
+  uint128_t q13;
+  uint128_t q14;
+  uint128_t q15;
+  uint128_t q16;
+  uint128_t q17;
+  uint128_t q18;
+  uint128_t q19;
+  uint128_t q20;
+  uint128_t q21;
+  uint128_t q22;
+  uint128_t q23;
+  uint128_t q24;
+  uint128_t q25;
+  uint128_t q26;
+  uint128_t q27;
+  uint128_t q28;
+  uint128_t q29;
+  uint128_t q30;
+  uint128_t q31;
+#endif /* AARCH64_MULTILIB_VFP */
+  uint64_t register_elr;
+  uint64_t register_spsr;
+  uint64_t register_fpsr;
+  uint64_t register_fpcr;
+} CPU_Interrupt_frame;
 void _CPU_Context_volatile_clobber( uintptr_t pattern );
 void _CPU_Context_validate( uintptr_t pattern );
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/abi.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/abi.yml
index 56c7694f35..59b5f922d4 100644
--- a/spec/build/bsps/aarch64/xilinx-zynqmp/abi.yml
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/abi.yml
@@ -8,9 +8,11 @@ copyrights:
 - Copyright (C) 2020 On-Line Applications Research (OAR)
 default:
 - -mcpu=cortex-a53
+- -mno-outline-atomics
 default-by-variant:
 - value:
   - -mcpu=cortex-a53
+  - -mno-outline-atomics
   - -mabi=ilp32
   variants:
   - aarch64/xilinx_zynqmp_ilp32_qemu
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml
index 1a356903cd..9d4fe505c3 100644
--- a/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml
@@ -19,6 +19,8 @@ links:
   uid: abi
 - role: build-dependency
   uid: obj
+- role: build-dependency
+  uid: objsmp
   uid: optloadoff
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/objsmp.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/objsmp.yml
index 0000000000..752e6622c6
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/objsmp.yml
@@ -0,0 +1,16 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: objects
+cflags: []
+copyrights:
+- Copyright (C) 2021 On-Line Applications Research (OAR)
+cppflags: []
+cxxflags: []
+enabled-by:
+- RTEMS_SMP
+includes: []
+install: []
+links: []
+source:
+- bsps/aarch64/shared/start/aarch64-smp.c
+- bsps/shared/start/bspsmp-arm-psci.c
+type: build
diff --git a/spec/build/cpukit/optsmp.yml b/spec/build/cpukit/optsmp.yml
index eefeef44aa..b4a2d2c771 100644
--- a/spec/build/cpukit/optsmp.yml
+++ b/spec/build/cpukit/optsmp.yml
@@ -11,6 +11,10 @@ default-by-variant: []
 description: |
   Enable the Symmetric Multiprocessing (SMP) support
 enabled-by:
+- aarch64/xilinx_zynqmp_ilp32_qemu
+- aarch64/xilinx_zynqmp_ilp32_zu3eg
+- aarch64/xilinx_zynqmp_lp64_qemu
+- aarch64/xilinx_zynqmp_lp64_zu3eg
 - arm/altcycv_devkit
 - arm/fvp_cortex_r52
 - arm/imx7
diff --git a/testsuites/smptests/smpfatal08/init.c b/testsuites/smptests/smpfatal08/init.c
index bcfb3b72be..0964a6047c 100644
--- a/testsuites/smptests/smpfatal08/init.c
+++ b/testsuites/smptests/smpfatal08/init.c
@@ -76,7 +76,7 @@ void _CPU_SMP_Prepare_start_multitasking(void)
 #if defined(RTEMS_PARAVIRT) \
   || (!defined(__leon__) && !defined(__PPC__) \
-    && !defined(__arm__) && !defined(__riscv))
+    && !defined(__arm__) && !defined(__riscv) && !defined(__aarch64__))
 uint32_t _CPU_SMP_Get_current_processor(void)
   return 0;
2.30.2
