[PATCH v2 5/5] cpukit: Add AArch64 SMP Support
Kinsey Moore
kinsey.moore at oarcorp.com
Mon Sep 20 22:56:49 UTC 2021
Version 1 of this patch did not update the Versal BSP's usage of the MMU
calls.
Kinsey
On 9/20/2021 17:43, Kinsey Moore wrote:
> This adds SMP support for AArch64 in cpukit and for the ZynqMP BSPs.
> bsps/aarch64/include/bsp/aarch64-mmu.h | 13 ++-
> bsps/aarch64/shared/start/aarch64-smp.c | 85 +++++++++++++++++++
> bsps/aarch64/shared/start/start.S | 12 +--
> .../aarch64/xilinx-versal/start/bspstartmmu.c | 4 +-
> bsps/aarch64/xilinx-zynqmp/include/bsp.h | 9 ++
> .../xilinx-zynqmp/start/bspstarthooks.c | 40 ++++++++-
> .../aarch64/xilinx-zynqmp/start/bspstartmmu.c | 28 ++++--
> .../cpu/aarch64/aarch64-exception-interrupt.S | 6 +-
> cpukit/score/cpu/aarch64/cpu_asm.S | 78 ++++++++++++++++-
> cpukit/score/cpu/aarch64/include/rtems/asm.h | 5 ++
> .../cpu/aarch64/include/rtems/score/cpu.h | 13 ++-
> .../cpu/aarch64/include/rtems/score/cpuimpl.h | 67 ++++++++++++++-
> spec/build/bsps/aarch64/xilinx-zynqmp/abi.yml | 2 +
> spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml | 2 +
> .../bsps/aarch64/xilinx-zynqmp/objsmp.yml | 16 ++++
> spec/build/cpukit/optsmp.yml | 4 +
> testsuites/smptests/smpfatal08/init.c | 2 +-
> 17 files changed, 350 insertions(+), 36 deletions(-)
> create mode 100644 bsps/aarch64/shared/start/aarch64-smp.c
> create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/objsmp.yml
> diff --git a/bsps/aarch64/include/bsp/aarch64-mmu.h b/bsps/aarch64/include/bsp/aarch64-mmu.h
> index e82012576f..a5f6e846f3 100644
> --- a/bsps/aarch64/include/bsp/aarch64-mmu.h
> +++ b/bsps/aarch64/include/bsp/aarch64-mmu.h
> @@ -385,17 +385,14 @@ BSP_START_TEXT_SECTION static inline void aarch64_mmu_setup_translation_table(
> -aarch64_mmu_setup_translation_table_and_enable(
> - const aarch64_mmu_config_entry *config_table,
> - size_t config_count
> +aarch64_mmu_enable( void )
> uint64_t sctlr;
> - aarch64_mmu_setup_translation_table(
> - config_table,
> - config_count
> + /* CPUECTLR_EL1.SMPEN is already set on ZynqMP and is not writable */
> + /* Invalidate cache */
> + rtems_cache_invalidate_entire_data();
> /* Enable MMU and cache */
> sctlr = _AArch64_Read_sctlr_el1();
> diff --git a/bsps/aarch64/shared/start/aarch64-smp.c b/bsps/aarch64/shared/start/aarch64-smp.c
> new file mode 100644
> index 0000000000..5ec7babce7
> --- /dev/null
> +++ b/bsps/aarch64/shared/start/aarch64-smp.c
> @@ -0,0 +1,85 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * @ingroup RTEMSBSPsAArch64Shared
> + * @brief SMP startup and interop code.
> + * Copyright (C) 2021 On-Line Applications Research Corporation (OAR)
> + * Written by Kinsey Moore <kinsey.moore at oarcorp.com>
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + * notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + * notice, this list of conditions and the following disclaimer in the
> + * documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#include <rtems/score/smpimpl.h>
> +#include <bsp/irq.h>
> +static void bsp_inter_processor_interrupt( void *arg )
> + _SMP_Inter_processor_interrupt_handler( _Per_CPU_Get() );
> +uint32_t _CPU_SMP_Initialize( void )
> + return arm_gic_irq_processor_count();
> +void _CPU_SMP_Finalize_initialization( uint32_t cpu_count )
> + if ( cpu_count > 0 ) {
> + rtems_status_code sc;
> + sc = rtems_interrupt_handler_install(
> + ARM_GIC_IRQ_SGI_0,
> + "IPI",
> + RTEMS_INTERRUPT_UNIQUE,
> + bsp_inter_processor_interrupt,
> + NULL
> + _Assert( sc == RTEMS_SUCCESSFUL );
> + (void) sc;
> +#if defined( BSP_DATA_CACHE_ENABLED ) || \
> + defined( BSP_INSTRUCTION_CACHE_ENABLED )
> + /* Enable unified L2 cache */
> + rtems_cache_enable_data();
> +#endif
> +void _CPU_SMP_Prepare_start_multitasking( void )
> + /* Do nothing */
> +void _CPU_SMP_Send_interrupt( uint32_t target_processor_index )
> + arm_gic_irq_generate_software_irq(
> + 1U << target_processor_index
> diff --git a/bsps/aarch64/shared/start/start.S b/bsps/aarch64/shared/start/start.S
> index f4c39dacdf..bc6a855217 100644
> --- a/bsps/aarch64/shared/start/start.S
> +++ b/bsps/aarch64/shared/start/start.S
> @@ -166,21 +166,21 @@ _el1_start:
> #ifdef RTEMS_SMP
> /* Read MPIDR and get current processor index */
> mrs x7, mpidr_el1
> - and x7, #0xff
> + and x7, x7, #0xff
> #endif
> #ifdef RTEMS_SMP
> * Get current per-CPU control and store it in PL1 only Thread ID
> - * Register (TPIDRPRW).
> + * Register (TPIDR_EL1).
> #ifdef AARCH64_MULTILIB_ARCH_V8_ILP32
> ldr w1, =_Per_CPU_Information
> #else
> ldr x1, =_Per_CPU_Information
> #endif
> - add x1, x1, x7, asl #PER_CPU_CONTROL_SIZE_LOG2
> - mcr p15, 0, x1, c13, c0, 4
> + add x1, x1, x7, lsl #PER_CPU_CONTROL_SIZE_LOG2
> + msr TPIDR_EL1, x1
> #endif
> @@ -201,8 +201,8 @@ _el1_start:
> #endif
> add x3, x1, x2
> - /* Save original DAIF value */
> - mrs x4, DAIF
> + /* Disable interrupts */
> + msr DAIFSet, #0x2
> #ifdef BSP_START_NEEDS_REGISTER_INITIALIZATION
> mov x8, XZR
> diff --git a/bsps/aarch64/xilinx-versal/start/bspstartmmu.c b/bsps/aarch64/xilinx-versal/start/bspstartmmu.c
> index 6ab33cc4f1..8b622aec7d 100644
> --- a/bsps/aarch64/xilinx-versal/start/bspstartmmu.c
> +++ b/bsps/aarch64/xilinx-versal/start/bspstartmmu.c
> @@ -70,8 +70,10 @@ versal_setup_mmu_and_cache( void )
> aarch64_mmu_setup();
> - aarch64_mmu_setup_translation_table_and_enable(
> + aarch64_mmu_setup_translation_table(
> &versal_mmu_config_table[ 0 ],
> RTEMS_ARRAY_SIZE( versal_mmu_config_table )
> + aarch64_mmu_enable();
> diff --git a/bsps/aarch64/xilinx-zynqmp/include/bsp.h b/bsps/aarch64/xilinx-zynqmp/include/bsp.h
> index 6d49b9ad2a..c867fe1801 100644
> --- a/bsps/aarch64/xilinx-zynqmp/include/bsp.h
> +++ b/bsps/aarch64/xilinx-zynqmp/include/bsp.h
> @@ -60,6 +60,7 @@ extern "C" {
> #define BSP_ARM_GIC_DIST_BASE 0xf9010000
> #define BSP_RESET_SMC
> +#define BSP_CPU_ON_SMC
> * @brief Zynq UltraScale+ MPSoC specific set up of the MMU.
> @@ -68,6 +69,14 @@ extern "C" {
> BSP_START_TEXT_SECTION void zynqmp_setup_mmu_and_cache(void);
> + * @brief Zynq UltraScale+ MPSoC specific set up of the MMU for non-primary
> + * cores.
> + * Provide in the application to override the defaults in the BSP.
> +BSP_START_TEXT_SECTION void zynqmp_setup_secondary_cpu_mmu_and_cache( void );
> void zynqmp_debug_console_flush(void);
> uint32_t zynqmp_clock_i2c0(void);
> diff --git a/bsps/aarch64/xilinx-zynqmp/start/bspstarthooks.c b/bsps/aarch64/xilinx-zynqmp/start/bspstarthooks.c
> index 7bd787592c..ad688088e5 100644
> --- a/bsps/aarch64/xilinx-zynqmp/start/bspstarthooks.c
> +++ b/bsps/aarch64/xilinx-zynqmp/start/bspstarthooks.c
> @@ -38,12 +38,46 @@
> #include <bsp.h>
> #include <bsp/start.h>
> -BSP_START_TEXT_SECTION void bsp_start_hook_0(void)
> +#ifdef RTEMS_SMP
> +#include <rtems/score/aarch64-system-registers.h>
> +#include <bsp/irq-generic.h>
> +#endif
> +BSP_START_TEXT_SECTION void bsp_start_hook_0( void )
> - /* Do nothing */
> +#ifdef RTEMS_SMP
> + uint32_t cpu_index_self;
> + cpu_index_self = _SMP_Get_current_processor();
> + if ( cpu_index_self != 0 ) {
> + if (
> + cpu_index_self >= rtems_configuration_get_maximum_processors()
> + || !_SMP_Should_start_processor( cpu_index_self )
> + while ( true ) {
> + _AARCH64_Wait_for_event();
> + /* Change the VBAR from the start to the normal vector table */
> + AArch64_start_set_vector_base();
> + zynqmp_setup_secondary_cpu_mmu_and_cache();
> + arm_gic_irq_initialize_secondary_cpu();
> + bsp_interrupt_vector_enable( ARM_GIC_IRQ_SGI_0 );
> + _SMP_Start_multitasking_on_secondary_processor(
> + _Per_CPU_Get_by_index( cpu_index_self )
> +#endif
> -BSP_START_TEXT_SECTION void bsp_start_hook_1(void)
> +BSP_START_TEXT_SECTION void bsp_start_hook_1( void )
> bsp_start_copy_sections();
> diff --git a/bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c b/bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c
> index 8d302e97b5..09012c9db5 100644
> --- a/bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c
> +++ b/bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c
> @@ -41,13 +41,6 @@
> BSP_START_DATA_SECTION static const aarch64_mmu_config_entry
> zynqmp_mmu_config_table[] = {
> AARCH64_MMU_DEFAULT_SECTIONS,
> -#if defined( RTEMS_SMP )
> - .begin = 0xffff0000U,
> - .end = 0xffffffffU,
> - .flags = AARCH64_MMU_DEVICE
> -#endif
> .begin = 0xf9000000U,
> .end = 0xf9100000U,
> @@ -70,8 +63,27 @@ zynqmp_setup_mmu_and_cache( void )
> &zynqmp_mmu_config_table[ 0 ],
> RTEMS_ARRAY_SIZE( zynqmp_mmu_config_table )
> + * Make weak and let the user override.
> +__attribute__ ( ( weak ) );
> + /* Perform basic MMU setup */
> + aarch64_mmu_setup();
> + /* Use the existing root page table already configured by CPU0 */
> + _AArch64_Write_ttbr0_el1( (uintptr_t) bsp_translation_table_base );
> diff --git a/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S b/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
> index cb0954a29b..b206f5764b 100644
> --- a/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
> +++ b/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
> @@ -47,7 +47,11 @@
> .globl _AArch64_Exception_interrupt_nest
> - #define SELF_CPU_CONTROL_GET_REG w19
> + #ifdef RTEMS_SMP
> + #define SELF_CPU_CONTROL_GET_REG x19
> + #else
> + #define SELF_CPU_CONTROL_GET_REG w19
> + #endif
> #else
> #endif
> diff --git a/cpukit/score/cpu/aarch64/cpu_asm.S b/cpukit/score/cpu/aarch64/cpu_asm.S
> index 9e609e06bd..2379698336 100644
> --- a/cpukit/score/cpu/aarch64/cpu_asm.S
> +++ b/cpukit/score/cpu/aarch64/cpu_asm.S
> @@ -55,13 +55,22 @@
> +DEFINE_FUNCTION_AARCH64(_CPU_Context_switch)
> + .globl _CPU_Context_switch_no_return
> + .set _CPU_Context_switch_no_return, _CPU_Context_switch
> -#define reg_2 w2
> +/* Sanitize inputs for ILP32 ABI */
> + mov w0, w0
> + mov w1, w1
> + #ifdef RTEMS_SMP
> + #define reg_2 x2
> + #else
> + #define reg_2 w2
> + #endif
> #else
> #define reg_2 x2
> #endif
> -DEFINE_FUNCTION_AARCH64(_CPU_Context_switch)
> /* Start saving context */
> GET_SELF_CPU_CONTROL reg_2
> ldr w3, [x2, #PER_CPU_ISR_DISPATCH_DISABLE]
> @@ -86,7 +95,30 @@ DEFINE_FUNCTION_AARCH64(_CPU_Context_switch)
> str x3, [x0, #AARCH64_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE]
> #ifdef RTEMS_SMP
> -#error SMP not yet supported
> + * The executing thread no longer executes on this processor. Switch
> + * the stack to the temporary interrupt stack of this processor. Mark
> + * the context of the executing thread as not executing.
> + dmb SY
> + add sp, x2, #(PER_CPU_INTERRUPT_FRAME_AREA + CPU_INTERRUPT_FRAME_SIZE)
> + mov x3, #0
> + strb w3, [x0, #AARCH64_CONTEXT_CONTROL_IS_EXECUTING_OFFSET]
> +.L_check_is_executing:
> + /* Check the is executing indicator of the heir context */
> + add x3, x1, #AARCH64_CONTEXT_CONTROL_IS_EXECUTING_OFFSET
> + ldaxrb w4, [x3]
> + cmp x4, #0
> + bne .L_get_potential_new_heir
> + /* Try to update the is executing indicator of the heir context */
> + mov x4, #1
> + stlxrb w5, w4, [x3]
> + cmp x5, #0
> + dmb SY
> #endif
> /* Start restoring context */
> @@ -129,6 +161,46 @@ DEFINE_FUNCTION_AARCH64(_CPU_Context_switch)
> DEFINE_FUNCTION_AARCH64(_CPU_Context_restore)
> +#ifdef AARCH64_MULTILIB_ARCH_V8_ILP32
> +/* Sanitize input for ILP32 ABI */
> + mov w0, w0
> +#endif
> mov x1, x0
> b .L_restore
> +#ifdef RTEMS_SMP
> +.L_get_potential_new_heir:
> + /* We may have a new heir */
> + /* Read the executing and heir */
> + ldr w4, [x2, #PER_CPU_OFFSET_EXECUTING]
> + ldr w5, [x2, #PER_CPU_OFFSET_HEIR]
> +#else
> + ldr x4, [x2, #PER_CPU_OFFSET_EXECUTING]
> + ldr x5, [x2, #PER_CPU_OFFSET_HEIR]
> +#endif
> + * Update the executing only if necessary to avoid cache line
> + * monopolization.
> + cmp x4, x5
> + beq .L_check_is_executing
> + /* Calculate the heir context pointer */
> + sub x4, x1, x4
> + add x1, x5, x4
> + /* Update the executing */
> + str w5, [x2, #PER_CPU_OFFSET_EXECUTING]
> +#else
> + str x5, [x2, #PER_CPU_OFFSET_EXECUTING]
> +#endif
> + b .L_check_is_executing
> +#endif
> diff --git a/cpukit/score/cpu/aarch64/include/rtems/asm.h b/cpukit/score/cpu/aarch64/include/rtems/asm.h
> index 35bf533c8a..fa53e08291 100644
> --- a/cpukit/score/cpu/aarch64/include/rtems/asm.h
> +++ b/cpukit/score/cpu/aarch64/include/rtems/asm.h
> @@ -81,7 +81,12 @@
> .align 8 ; .globl name ; name: ; .globl name ## _aarch64 ; name ## _aarch64:
> .macro GET_SELF_CPU_CONTROL REG
> +#ifdef RTEMS_SMP
> + /* Use Thread ID Register (TPIDR_EL1) */
> + mrs \REG, TPIDR_EL1
> +#else
> ldr \REG, =_Per_CPU_Information
> +#endif
> .endm
> diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
> index dacc18638e..82f74193a2 100644
> --- a/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
> @@ -134,9 +134,9 @@
> #ifdef RTEMS_SMP
> #if defined(AARCH64_MULTILIB_VFP)
> - #define AARCH64_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 0x70
> + #define AARCH64_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 0xb8
> #else
> - #define AARCH64_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 0x30
> + #define AARCH64_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 0x78
> #endif
> #endif
> @@ -191,12 +191,12 @@ typedef struct {
> static inline void _AARCH64_Data_memory_barrier( void )
> - __asm__ volatile ( "dmb LD" : : : "memory" );
> + __asm__ volatile ( "dmb SY" : : : "memory" );
> static inline void _AARCH64_Data_synchronization_barrier( void )
> - __asm__ volatile ( "dsb LD" : : : "memory" );
> + __asm__ volatile ( "dsb SY" : : : "memory" );
> static inline void _AARCH64_Instruction_synchronization_barrier( void )
> @@ -313,6 +313,11 @@ void _CPU_ISR_install_vector(
> void _CPU_Context_switch( Context_Control *run, Context_Control *heir );
> +RTEMS_NO_RETURN void _CPU_Context_switch_no_return(
> + Context_Control *executing,
> + Context_Control *heir
> RTEMS_NO_RETURN void _CPU_Context_restore( Context_Control *new_context );
> #ifdef RTEMS_SMP
> diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
> index 0536ecd860..90fd48ad4e 100644
> --- a/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
> @@ -50,7 +50,7 @@
> #define CPU_PER_CPU_CONTROL_SIZE 0
> -#define CPU_INTERRUPT_FRAME_SIZE 240
> +#define CPU_INTERRUPT_FRAME_SIZE 0x2E0
> #ifndef ASM
> @@ -60,6 +60,71 @@ extern "C" {
> RTEMS_NO_RETURN void _CPU_Fatal_halt( uint32_t source, CPU_Uint32ptr error );
> +typedef struct {
> + uint64_t x0;
> + uint64_t register_lr_original;
> + uint64_t register_lr;
> + uint64_t x1;
> + uint64_t x2;
> + uint64_t x3;
> + uint64_t x4;
> + uint64_t x5;
> + uint64_t x6;
> + uint64_t x7;
> + uint64_t x8;
> + uint64_t x9;
> + uint64_t x10;
> + uint64_t x11;
> + uint64_t x12;
> + uint64_t x13;
> + uint64_t x14;
> + uint64_t x15;
> + uint64_t x16;
> + uint64_t x17;
> + uint64_t x18;
> + uint64_t x19;
> + uint64_t x20;
> + uint64_t x21;
> +#ifdef AARCH64_MULTILIB_VFP
> + uint128_t q0;
> + uint128_t q1;
> + uint128_t q2;
> + uint128_t q3;
> + uint128_t q4;
> + uint128_t q5;
> + uint128_t q6;
> + uint128_t q7;
> + uint128_t q8;
> + uint128_t q9;
> + uint128_t q10;
> + uint128_t q11;
> + uint128_t q12;
> + uint128_t q13;
> + uint128_t q14;
> + uint128_t q15;
> + uint128_t q16;
> + uint128_t q17;
> + uint128_t q18;
> + uint128_t q19;
> + uint128_t q20;
> + uint128_t q21;
> + uint128_t q22;
> + uint128_t q23;
> + uint128_t q24;
> + uint128_t q25;
> + uint128_t q26;
> + uint128_t q27;
> + uint128_t q28;
> + uint128_t q29;
> + uint128_t q30;
> + uint128_t q31;
> +#endif /* AARCH64_MULTILIB_VFP */
> + uint64_t register_elr;
> + uint64_t register_spsr;
> + uint64_t register_fpsr;
> + uint64_t register_fpcr;
> +} CPU_Interrupt_frame;
> void _CPU_Context_volatile_clobber( uintptr_t pattern );
> void _CPU_Context_validate( uintptr_t pattern );
> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/abi.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/abi.yml
> index 56c7694f35..59b5f922d4 100644
> --- a/spec/build/bsps/aarch64/xilinx-zynqmp/abi.yml
> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/abi.yml
> @@ -8,9 +8,11 @@ copyrights:
> - Copyright (C) 2020 On-Line Applications Research (OAR)
> default:
> - -mcpu=cortex-a53
> +- -mno-outline-atomics
> default-by-variant:
> - value:
> - -mcpu=cortex-a53
> + - -mno-outline-atomics
> - -mabi=ilp32
> variants:
> - aarch64/xilinx_zynqmp_ilp32_qemu
> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml
> index 1a356903cd..9d4fe505c3 100644
> --- a/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml
> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml
> @@ -19,6 +19,8 @@ links:
> uid: abi
> - role: build-dependency
> uid: obj
> +- role: build-dependency
> + uid: objsmp
> uid: optloadoff
> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/objsmp.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/objsmp.yml
> index 0000000000..752e6622c6
> --- /dev/null
> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/objsmp.yml
> @@ -0,0 +1,16 @@
> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> +build-type: objects
> +cflags: []
> +copyrights:
> +- Copyright (C) 2021 On-Line Applications Research (OAR)
> +cppflags: []
> +cxxflags: []
> +enabled-by:
> +- RTEMS_SMP
> +includes: []
> +install: []
> +links: []
> +source:
> +- bsps/aarch64/shared/start/aarch64-smp.c
> +- bsps/shared/start/bspsmp-arm-psci.c
> +type: build
> diff --git a/spec/build/cpukit/optsmp.yml b/spec/build/cpukit/optsmp.yml
> index eefeef44aa..b4a2d2c771 100644
> --- a/spec/build/cpukit/optsmp.yml
> +++ b/spec/build/cpukit/optsmp.yml
> @@ -11,6 +11,10 @@ default-by-variant: []
> description: |
> Enable the Symmetric Multiprocessing (SMP) support
> enabled-by:
> +- aarch64/xilinx_zynqmp_ilp32_qemu
> +- aarch64/xilinx_zynqmp_ilp32_zu3eg
> +- aarch64/xilinx_zynqmp_lp64_qemu
> +- aarch64/xilinx_zynqmp_lp64_zu3eg
> - arm/altcycv_devkit
> - arm/fvp_cortex_r52
> - arm/imx7
> diff --git a/testsuites/smptests/smpfatal08/init.c b/testsuites/smptests/smpfatal08/init.c
> index bcfb3b72be..0964a6047c 100644
> --- a/testsuites/smptests/smpfatal08/init.c
> +++ b/testsuites/smptests/smpfatal08/init.c
> @@ -76,7 +76,7 @@ void _CPU_SMP_Prepare_start_multitasking(void)
> #if defined(RTEMS_PARAVIRT) \
> || (!defined(__leon__) && !defined(__PPC__) \
> - && !defined(__arm__) && !defined(__riscv))
> + && !defined(__arm__) && !defined(__riscv) && !defined(__aarch64__))
> uint32_t _CPU_SMP_Get_current_processor(void)
> return 0;
