[PATCH v2 5/5] cpukit: Add AArch64 SMP Support
Tue Sep 21 00:15:52 UTC 2021
looks good, thanks. I'll follow-up later as I make progress on the
versal smp side too. that's still a bit broken.
On Mon, Sep 20, 2021 at 4:56 PM Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
> Version 1 of this patch did not update the Versal BSP's usage of the MMU
> calls.
> Kinsey
> On 9/20/2021 17:43, Kinsey Moore wrote:
> > This adds SMP support for AArch64 in cpukit and for the ZynqMP BSPs.
> >   bsps/aarch64/include/bsp/aarch64-mmu.h        | 13 ++-
> >   bsps/aarch64/shared/start/aarch64-smp.c       | 85 +++++++++++++++++++
> >   bsps/aarch64/shared/start/start.S             | 12 +--
> >   .../aarch64/xilinx-versal/start/bspstartmmu.c |  4 +-
> >   bsps/aarch64/xilinx-zynqmp/include/bsp.h      |  9 ++
> >   .../xilinx-zynqmp/start/bspstarthooks.c       | 40 ++++++++-
> >   .../aarch64/xilinx-zynqmp/start/bspstartmmu.c | 28 ++++--
> >   .../cpu/aarch64/aarch64-exception-interrupt.S |  6 +-
> >   cpukit/score/cpu/aarch64/cpu_asm.S            | 78 ++++++++++++++++-
> >   cpukit/score/cpu/aarch64/include/rtems/asm.h  |  5 ++
> >   .../cpu/aarch64/include/rtems/score/cpu.h     | 13 ++-
> >   .../cpu/aarch64/include/rtems/score/cpuimpl.h | 67 ++++++++++++++-
> >   spec/build/bsps/aarch64/xilinx-zynqmp/abi.yml |  2 +
> >   spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml |  2 +
> >   .../bsps/aarch64/xilinx-zynqmp/objsmp.yml     | 16 ++++
> >   spec/build/cpukit/optsmp.yml                  |  4 +
> >   testsuites/smptests/smpfatal08/init.c         |  2 +-
> >   17 files changed, 350 insertions(+), 36 deletions(-)
> >   create mode 100644 bsps/aarch64/shared/start/aarch64-smp.c
> >   create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/objsmp.yml
> > diff --git a/bsps/aarch64/include/bsp/aarch64-mmu.h b/bsps/aarch64/include/bsp/aarch64-mmu.h
> > index e82012576f..a5f6e846f3 100644
> > --- a/bsps/aarch64/include/bsp/aarch64-mmu.h
> > +++ b/bsps/aarch64/include/bsp/aarch64-mmu.h
> > @@ -385,17 +385,14 @@ BSP_START_TEXT_SECTION static inline void aarch64_mmu_setup_translation_table(
> > -aarch64_mmu_setup_translation_table_and_enable(
> > -  const aarch64_mmu_config_entry *config_table,
> > -  size_t config_count
> > +aarch64_mmu_enable( void )
> >     uint64_t sctlr;
> > -  aarch64_mmu_setup_translation_table(
> > -    config_table,
> > -    config_count
> > +  /* CPUECTLR_EL1.SMPEN is already set on ZynqMP and is not writable */
> > +  /* Invalidate cache */
> > +  rtems_cache_invalidate_entire_data();
> >     /* Enable MMU and cache */
> >     sctlr = _AArch64_Read_sctlr_el1();
> > diff --git a/bsps/aarch64/shared/start/aarch64-smp.c b/bsps/aarch64/shared/start/aarch64-smp.c
> > new file mode 100644
> > index 0000000000..5ec7babce7
> > --- /dev/null
> > +++ b/bsps/aarch64/shared/start/aarch64-smp.c
> > @@ -0,0 +1,85 @@
> > +/* SPDX-License-Identifier: BSD-2-Clause */
> > + * @file
> > + * @ingroup RTEMSBSPsAArch64Shared
> > + * @brief SMP startup and interop code.
> > + * Copyright (C) 2021 On-Line Applications Research Corporation (OAR)
> > + * Written by Kinsey Moore <kinsey.moore at oarcorp.com>
> > + * Redistribution and use in source and binary forms, with or without
> > + * modification, are permitted provided that the following conditions
> > + * are met:
> > + * 1. Redistributions of source code must retain the above copyright
> > + *    notice, this list of conditions and the following disclaimer.
> > + * 2. Redistributions in binary form must reproduce the above copyright
> > + *    notice, this list of conditions and the following disclaimer in the
> > + *    documentation and/or other materials provided with the distribution.
> > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> > + * POSSIBILITY OF SUCH DAMAGE.
> > +#include <rtems/score/smpimpl.h>
> > +#include <bsp/irq.h>
> > +static void bsp_inter_processor_interrupt( void *arg )
> > +  _SMP_Inter_processor_interrupt_handler( _Per_CPU_Get() );
> > +uint32_t _CPU_SMP_Initialize( void )
> > +  return arm_gic_irq_processor_count();
> > +void _CPU_SMP_Finalize_initialization( uint32_t cpu_count )
> > +  if ( cpu_count > 0 ) {
> > +    rtems_status_code sc;
> > +    sc = rtems_interrupt_handler_install(
> > +      ARM_GIC_IRQ_SGI_0,
> > +      "IPI",
> > +      RTEMS_INTERRUPT_UNIQUE,
> > +      bsp_inter_processor_interrupt,
> > +      NULL
> > +    _Assert( sc == RTEMS_SUCCESSFUL );
> > +    (void) sc;
> > +#if defined( BSP_DATA_CACHE_ENABLED ) || \
> > +    defined( BSP_INSTRUCTION_CACHE_ENABLED )
> > +    /* Enable unified L2 cache */
> > +    rtems_cache_enable_data();
> > +#endif
> > +void _CPU_SMP_Prepare_start_multitasking( void )
> > +  /* Do nothing */
> > +void _CPU_SMP_Send_interrupt( uint32_t target_processor_index )
> > +  arm_gic_irq_generate_software_irq(
> > +    1U << target_processor_index
> > diff --git a/bsps/aarch64/shared/start/start.S b/bsps/aarch64/shared/start/start.S
> > index f4c39dacdf..bc6a855217 100644
> > --- a/bsps/aarch64/shared/start/start.S
> > +++ b/bsps/aarch64/shared/start/start.S
> > @@ -166,21 +166,21 @@ _el1_start:
> >   #ifdef RTEMS_SMP
> >     /* Read MPIDR and get current processor index */
> >     mrs x7, mpidr_el1
> > -  and x7, #0xff
> > +  and x7, x7, #0xff
> >   #endif
> >   #ifdef RTEMS_SMP
> >      * Get current per-CPU control and store it in PL1 only Thread ID
> > -   * Register (TPIDRPRW).
> > +   * Register (TPIDR_EL1).
> >   #ifdef AARCH64_MULTILIB_ARCH_V8_ILP32
> >     ldr w1, =_Per_CPU_Information
> >   #else
> >     ldr x1, =_Per_CPU_Information
> >   #endif
> > -  add x1, x1, x7, asl #PER_CPU_CONTROL_SIZE_LOG2
> > -  mcr p15, 0, x1, c13, c0, 4
> > +  add x1, x1, x7, lsl #PER_CPU_CONTROL_SIZE_LOG2
> > +  msr TPIDR_EL1, x1
> >   #endif
> > @@ -201,8 +201,8 @@ _el1_start:
> >   #endif
> >     add x3, x1, x2
> > -  /* Save original DAIF value */
> > -  mrs  x4, DAIF
> > +  /* Disable interrupts */
> > +  msr DAIFSet, #0x2
> >   #ifdef BSP_START_NEEDS_REGISTER_INITIALIZATION
> >     mov x8, XZR
> > diff --git a/bsps/aarch64/xilinx-versal/start/bspstartmmu.c b/bsps/aarch64/xilinx-versal/start/bspstartmmu.c
> > index 6ab33cc4f1..8b622aec7d 100644
> > --- a/bsps/aarch64/xilinx-versal/start/bspstartmmu.c
> > +++ b/bsps/aarch64/xilinx-versal/start/bspstartmmu.c
> > @@ -70,8 +70,10 @@ versal_setup_mmu_and_cache( void )
> >     aarch64_mmu_setup();
> > -  aarch64_mmu_setup_translation_table_and_enable(
> > +  aarch64_mmu_setup_translation_table(
> >       &versal_mmu_config_table[ 0 ],
> >       RTEMS_ARRAY_SIZE( versal_mmu_config_table )
> > +  aarch64_mmu_enable();
> > diff --git a/bsps/aarch64/xilinx-zynqmp/include/bsp.h b/bsps/aarch64/xilinx-zynqmp/include/bsp.h
> > index 6d49b9ad2a..c867fe1801 100644
> > --- a/bsps/aarch64/xilinx-zynqmp/include/bsp.h
> > +++ b/bsps/aarch64/xilinx-zynqmp/include/bsp.h
> > @@ -60,6 +60,7 @@ extern "C" {
> >   #define BSP_ARM_GIC_DIST_BASE 0xf9010000
> >   #define BSP_RESET_SMC
> > +#define BSP_CPU_ON_SMC
> >    * @brief Zynq UltraScale+ MPSoC specific set up of the MMU.
> > @@ -68,6 +69,14 @@ extern "C" {
> >   BSP_START_TEXT_SECTION void zynqmp_setup_mmu_and_cache(void);
> > + * @brief Zynq UltraScale+ MPSoC specific set up of the MMU for non-primary
> > + * cores.
> > + * Provide in the application to override the defaults in the BSP.
> > +BSP_START_TEXT_SECTION void zynqmp_setup_secondary_cpu_mmu_and_cache( void );
> >   void zynqmp_debug_console_flush(void);
> >   uint32_t zynqmp_clock_i2c0(void);
> > diff --git a/bsps/aarch64/xilinx-zynqmp/start/bspstarthooks.c b/bsps/aarch64/xilinx-zynqmp/start/bspstarthooks.c
> > index 7bd787592c..ad688088e5 100644
> > --- a/bsps/aarch64/xilinx-zynqmp/start/bspstarthooks.c
> > +++ b/bsps/aarch64/xilinx-zynqmp/start/bspstarthooks.c
> > @@ -38,12 +38,46 @@
> >   #include <bsp.h>
> >   #include <bsp/start.h>
> > -BSP_START_TEXT_SECTION void bsp_start_hook_0(void)
> > +#ifdef RTEMS_SMP
> > +#include <rtems/score/aarch64-system-registers.h>
> > +#include <bsp/irq-generic.h>
> > +#endif
> > +BSP_START_TEXT_SECTION void bsp_start_hook_0( void )
> > -  /* Do nothing */
> > +#ifdef RTEMS_SMP
> > +  uint32_t cpu_index_self;
> > +  cpu_index_self = _SMP_Get_current_processor();
> > +  if ( cpu_index_self != 0 ) {
> > +    if (
> > +      cpu_index_self >= rtems_configuration_get_maximum_processors()
> > +      || !_SMP_Should_start_processor( cpu_index_self )
> > +      while ( true ) {
> > +        _AARCH64_Wait_for_event();
> > +    /* Change the VBAR from the start to the normal vector table */
> > +    AArch64_start_set_vector_base();
> > +    zynqmp_setup_secondary_cpu_mmu_and_cache();
> > +    arm_gic_irq_initialize_secondary_cpu();
> > +    bsp_interrupt_vector_enable( ARM_GIC_IRQ_SGI_0 );
> > +    _SMP_Start_multitasking_on_secondary_processor(
> > +      _Per_CPU_Get_by_index( cpu_index_self )
> > +#endif
> > -BSP_START_TEXT_SECTION void bsp_start_hook_1(void)
> > +BSP_START_TEXT_SECTION void bsp_start_hook_1( void )
> >     bsp_start_copy_sections();
> > diff --git a/bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c b/bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c
> > index 8d302e97b5..09012c9db5 100644
> > --- a/bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c
> > +++ b/bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c
> > @@ -41,13 +41,6 @@
> >   BSP_START_DATA_SECTION static const aarch64_mmu_config_entry
> >   zynqmp_mmu_config_table[] = {
> >     AARCH64_MMU_DEFAULT_SECTIONS,
> > -#if defined( RTEMS_SMP )
> > -    .begin = 0xffff0000U,
> > -    .end = 0xffffffffU,
> > -    .flags = AARCH64_MMU_DEVICE
> > -#endif
> >       .begin = 0xf9000000U,
> >       .end = 0xf9100000U,
> > @@ -70,8 +63,27 @@ zynqmp_setup_mmu_and_cache( void )
> >       &zynqmp_mmu_config_table[ 0 ],
> >       RTEMS_ARRAY_SIZE( zynqmp_mmu_config_table )
> > + * Make weak and let the user override.
> > +__attribute__ ( ( weak ) );
> > +  /* Perform basic MMU setup */
> > +  aarch64_mmu_setup();
> > +  /* Use the existing root page table already configured by CPU0 */
> > +  _AArch64_Write_ttbr0_el1( (uintptr_t) bsp_translation_table_base );
> > diff --git a/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S b/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
> > index cb0954a29b..b206f5764b 100644
> > --- a/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
> > +++ b/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
> > @@ -47,7 +47,11 @@
> >   .globl      _AArch64_Exception_interrupt_nest
> > -  #define SELF_CPU_CONTROL_GET_REG w19
> > +  #ifdef RTEMS_SMP
> > +    #define SELF_CPU_CONTROL_GET_REG x19
> > +  #else
> > +    #define SELF_CPU_CONTROL_GET_REG w19
> > +  #endif
> >   #else
> >   #endif
> > diff --git a/cpukit/score/cpu/aarch64/cpu_asm.S b/cpukit/score/cpu/aarch64/cpu_asm.S
> > index 9e609e06bd..2379698336 100644
> > --- a/cpukit/score/cpu/aarch64/cpu_asm.S
> > +++ b/cpukit/score/cpu/aarch64/cpu_asm.S
> > @@ -55,13 +55,22 @@
> > +DEFINE_FUNCTION_AARCH64(_CPU_Context_switch)
> > +     .globl  _CPU_Context_switch_no_return
> > +     .set    _CPU_Context_switch_no_return, _CPU_Context_switch
> > -#define reg_2 w2
> > +/* Sanitize inputs for ILP32 ABI */
> > +     mov w0, w0
> > +     mov w1, w1
> > +  #ifdef RTEMS_SMP
> > +    #define reg_2 x2
> > +  #else
> > +    #define reg_2 w2
> > +  #endif
> >   #else
> >   #define reg_2 x2
> >   #endif
> > -DEFINE_FUNCTION_AARCH64(_CPU_Context_switch)
> >   /* Start saving context */
> >       GET_SELF_CPU_CONTROL    reg_2
> >       ldr     w3, [x2, #PER_CPU_ISR_DISPATCH_DISABLE]
> > @@ -86,7 +95,30 @@ DEFINE_FUNCTION_AARCH64(_CPU_Context_switch)
> >       str     x3, [x0, #AARCH64_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE]
> >   #ifdef RTEMS_SMP
> > -#error SMP not yet supported
> > +      * The executing thread no longer executes on this processor.  Switch
> > +      * the stack to the temporary interrupt stack of this processor.  Mark
> > +      * the context of the executing thread as not executing.
> > +     dmb     SY
> > +     add     sp, x2, #(PER_CPU_INTERRUPT_FRAME_AREA + CPU_INTERRUPT_FRAME_SIZE)
> > +     mov     x3, #0
> > +     strb    w3, [x0, #AARCH64_CONTEXT_CONTROL_IS_EXECUTING_OFFSET]
> > +.L_check_is_executing:
> > +     /* Check the is executing indicator of the heir context */
> > +     add     x3, x1, #AARCH64_CONTEXT_CONTROL_IS_EXECUTING_OFFSET
> > +     ldaxrb  w4, [x3]
> > +     cmp     x4, #0
> > +     bne     .L_get_potential_new_heir
> > +     /* Try to update the is executing indicator of the heir context */
> > +     mov     x4, #1
> > +     stlxrb  w5, w4, [x3]
> > +     cmp     x5, #0
> > +     dmb     SY
> >   #endif
> >   /* Start restoring context */
> > @@ -129,6 +161,46 @@ DEFINE_FUNCTION_AARCH64(_CPU_Context_switch)
> >   DEFINE_FUNCTION_AARCH64(_CPU_Context_restore)
> > +#ifdef AARCH64_MULTILIB_ARCH_V8_ILP32
> > +/* Sanitize input for ILP32 ABI */
> > +     mov w0, w0
> > +#endif
> >           mov     x1, x0
> >           b       .L_restore
> > +#ifdef RTEMS_SMP
> > +.L_get_potential_new_heir:
> > +     /* We may have a new heir */
> > +     /* Read the executing and heir */
> > +     ldr     w4, [x2, #PER_CPU_OFFSET_EXECUTING]
> > +     ldr     w5, [x2, #PER_CPU_OFFSET_HEIR]
> > +#else
> > +     ldr     x4, [x2, #PER_CPU_OFFSET_EXECUTING]
> > +     ldr     x5, [x2, #PER_CPU_OFFSET_HEIR]
> > +#endif
> > +      * Update the executing only if necessary to avoid cache line
> > +      * monopolization.
> > +     cmp     x4, x5
> > +     beq     .L_check_is_executing
> > +     /* Calculate the heir context pointer */
> > +     sub     x4, x1, x4
> > +     add     x1, x5, x4
> > +     /* Update the executing */
> > +     str     w5, [x2, #PER_CPU_OFFSET_EXECUTING]
> > +#else
> > +     str     x5, [x2, #PER_CPU_OFFSET_EXECUTING]
> > +#endif
> > +     b       .L_check_is_executing
> > +#endif
> > diff --git a/cpukit/score/cpu/aarch64/include/rtems/asm.h b/cpukit/score/cpu/aarch64/include/rtems/asm.h
> > index 35bf533c8a..fa53e08291 100644
> > --- a/cpukit/score/cpu/aarch64/include/rtems/asm.h
> > +++ b/cpukit/score/cpu/aarch64/include/rtems/asm.h
> > @@ -81,7 +81,12 @@
> >     .align 8 ; .globl name ; name: ; .globl name ## _aarch64 ; name ## _aarch64:
> >   .macro GET_SELF_CPU_CONTROL REG
> > +#ifdef RTEMS_SMP
> > +     /* Use Thread ID Register (TPIDR_EL1) */
> > +     mrs     \REG, TPIDR_EL1
> > +#else
> >       ldr     \REG, =_Per_CPU_Information
> > +#endif
> >   .endm
> > diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
> > index dacc18638e..82f74193a2 100644
> > --- a/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
> > +++ b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
> > @@ -134,9 +134,9 @@
> >   #ifdef RTEMS_SMP
> >     #if defined(AARCH64_MULTILIB_VFP)
> > -    #define AARCH64_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 0x70
> > +    #define AARCH64_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 0xb8
> >     #else
> > -    #define AARCH64_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 0x30
> > +    #define AARCH64_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 0x78
> >     #endif
> >   #endif
> > @@ -191,12 +191,12 @@ typedef struct {
> >   static inline void _AARCH64_Data_memory_barrier( void )
> > -  __asm__ volatile ( "dmb LD" : : : "memory" );
> > +  __asm__ volatile ( "dmb SY" : : : "memory" );
> >   static inline void _AARCH64_Data_synchronization_barrier( void )
> > -  __asm__ volatile ( "dsb LD" : : : "memory" );
> > +  __asm__ volatile ( "dsb SY" : : : "memory" );
> >   static inline void _AARCH64_Instruction_synchronization_barrier( void )
> > @@ -313,6 +313,11 @@ void _CPU_ISR_install_vector(
> >   void _CPU_Context_switch( Context_Control *run, Context_Control *heir );
> > +RTEMS_NO_RETURN void _CPU_Context_switch_no_return(
> > +  Context_Control *executing,
> > +  Context_Control *heir
> >   RTEMS_NO_RETURN void _CPU_Context_restore( Context_Control *new_context );
> >   #ifdef RTEMS_SMP
> > diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
> > index 0536ecd860..90fd48ad4e 100644
> > --- a/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
> > +++ b/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
> > @@ -50,7 +50,7 @@
> >   #define CPU_PER_CPU_CONTROL_SIZE 0
> > -#define CPU_INTERRUPT_FRAME_SIZE 240
> > +#define CPU_INTERRUPT_FRAME_SIZE 0x2E0
> >   #ifndef ASM
> > @@ -60,6 +60,71 @@ extern "C" {
> >   RTEMS_NO_RETURN void _CPU_Fatal_halt( uint32_t source, CPU_Uint32ptr error );
> > +typedef struct {
> > +  uint64_t x0;
> > +  uint64_t register_lr_original;
> > +  uint64_t register_lr;
> > +  uint64_t x1;
> > +  uint64_t x2;
> > +  uint64_t x3;
> > +  uint64_t x4;
> > +  uint64_t x5;
> > +  uint64_t x6;
> > +  uint64_t x7;
> > +  uint64_t x8;
> > +  uint64_t x9;
> > +  uint64_t x10;
> > +  uint64_t x11;
> > +  uint64_t x12;
> > +  uint64_t x13;
> > +  uint64_t x14;
> > +  uint64_t x15;
> > +  uint64_t x16;
> > +  uint64_t x17;
> > +  uint64_t x18;
> > +  uint64_t x19;
> > +  uint64_t x20;
> > +  uint64_t x21;
> > +#ifdef AARCH64_MULTILIB_VFP
> > +  uint128_t q0;
> > +  uint128_t q1;
> > +  uint128_t q2;
> > +  uint128_t q3;
> > +  uint128_t q4;
> > +  uint128_t q5;
> > +  uint128_t q6;
> > +  uint128_t q7;
> > +  uint128_t q8;
> > +  uint128_t q9;
> > +  uint128_t q10;
> > +  uint128_t q11;
> > +  uint128_t q12;
> > +  uint128_t q13;
> > +  uint128_t q14;
> > +  uint128_t q15;
> > +  uint128_t q16;
> > +  uint128_t q17;
> > +  uint128_t q18;
> > +  uint128_t q19;
> > +  uint128_t q20;
> > +  uint128_t q21;
> > +  uint128_t q22;
> > +  uint128_t q23;
> > +  uint128_t q24;
> > +  uint128_t q25;
> > +  uint128_t q26;
> > +  uint128_t q27;
> > +  uint128_t q28;
> > +  uint128_t q29;
> > +  uint128_t q30;
> > +  uint128_t q31;
> > +#endif /* AARCH64_MULTILIB_VFP */
> > +  uint64_t register_elr;
> > +  uint64_t register_spsr;
> > +  uint64_t register_fpsr;
> > +  uint64_t register_fpcr;
> > +} CPU_Interrupt_frame;
> >   void _CPU_Context_volatile_clobber( uintptr_t pattern );
> >   void _CPU_Context_validate( uintptr_t pattern );
> > diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/abi.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/abi.yml
> > index 56c7694f35..59b5f922d4 100644
> > --- a/spec/build/bsps/aarch64/xilinx-zynqmp/abi.yml
> > +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/abi.yml
> > @@ -8,9 +8,11 @@ copyrights:
> >   - Copyright (C) 2020 On-Line Applications Research (OAR)
> >   default:
> >   - -mcpu=cortex-a53
> > +- -mno-outline-atomics
> >   default-by-variant:
> >   - value:
> >     - -mcpu=cortex-a53
> > +  - -mno-outline-atomics
> >     - -mabi=ilp32
> >     variants:
> >     - aarch64/xilinx_zynqmp_ilp32_qemu
> > diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml
> > index 1a356903cd..9d4fe505c3 100644
> > --- a/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml
> > +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml
> > @@ -19,6 +19,8 @@ links:
> >     uid: abi
> >   - role: build-dependency
> >     uid: obj
> > +- role: build-dependency
> > +  uid: objsmp
> >     uid: optloadoff
> > diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/objsmp.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/objsmp.yml
> > index 0000000000..752e6622c6
> > --- /dev/null
> > +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/objsmp.yml
> > @@ -0,0 +1,16 @@
> > +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> > +build-type: objects
> > +cflags: []
> > +copyrights:
> > +- Copyright (C) 2021 On-Line Applications Research (OAR)
> > +cppflags: []
> > +cxxflags: []
> > +enabled-by:
> > +- RTEMS_SMP
> > +includes: []
> > +install: []
> > +links: []
> > +source:
> > +- bsps/aarch64/shared/start/aarch64-smp.c
> > +- bsps/shared/start/bspsmp-arm-psci.c
> > +type: build
> > diff --git a/spec/build/cpukit/optsmp.yml b/spec/build/cpukit/optsmp.yml
> > index eefeef44aa..b4a2d2c771 100644
> > --- a/spec/build/cpukit/optsmp.yml
> > +++ b/spec/build/cpukit/optsmp.yml
> > @@ -11,6 +11,10 @@ default-by-variant: []
> >   description: |
> >     Enable the Symmetric Multiprocessing (SMP) support
> >   enabled-by:
> > +- aarch64/xilinx_zynqmp_ilp32_qemu
> > +- aarch64/xilinx_zynqmp_ilp32_zu3eg
> > +- aarch64/xilinx_zynqmp_lp64_qemu
> > +- aarch64/xilinx_zynqmp_lp64_zu3eg
> >   - arm/altcycv_devkit
> >   - arm/fvp_cortex_r52
> >   - arm/imx7
> > diff --git a/testsuites/smptests/smpfatal08/init.c b/testsuites/smptests/smpfatal08/init.c
> > index bcfb3b72be..0964a6047c 100644
> > --- a/testsuites/smptests/smpfatal08/init.c
> > +++ b/testsuites/smptests/smpfatal08/init.c
> > @@ -76,7 +76,7 @@ void _CPU_SMP_Prepare_start_multitasking(void)
> >   #if defined(RTEMS_PARAVIRT) \
> >     || (!defined(__leon__) && !defined(__PPC__) \
> > -    && !defined(__arm__) && !defined(__riscv))
> > +    && !defined(__arm__) && !defined(__riscv) && !defined(__aarch64__))
> >   uint32_t _CPU_SMP_Get_current_processor(void)
> >     return 0;
> devel mailing list
> devel at rtems.org
