[PATCH rtems-tools v1 2/7] TraceReader: Convert to C++
Ryan Long
ryan.long at oarcorp.com
Tue Sep 21 16:44:58 UTC 2021
tester/covoar/ObjdumpProcessor.cc | 4 +-
tester/covoar/ObjdumpProcessor.h | 2 +-
tester/covoar/TargetBase.cc | 6 +-
tester/covoar/TargetBase.h | 4 +-
tester/covoar/TraceReaderBase.h | 4 +-
tester/covoar/TraceReaderLogQEMU.cc | 113 +++++++++++++++---------------------
tester/covoar/TraceReaderLogQEMU.h | 2 +-
tester/covoar/qemu-log.h | 4 +-
8 files changed, 57 insertions(+), 82 deletions(-)
diff --git a/tester/covoar/ObjdumpProcessor.cc b/tester/covoar/ObjdumpProcessor.cc
index 4d1e306..c910046 100644
--- a/tester/covoar/ObjdumpProcessor.cc
+++ b/tester/covoar/ObjdumpProcessor.cc
@@ -188,9 +188,7 @@ namespace Coverage {
#undef METHOD
- bool ObjdumpProcessor::IsBranch(
- const char *instruction
+ bool ObjdumpProcessor::IsBranch( const std::string& instruction )
if ( !targetInfo_m ) {
fprintf(
diff --git a/tester/covoar/ObjdumpProcessor.h b/tester/covoar/ObjdumpProcessor.h
index 6a207dd..05a667f 100644
--- a/tester/covoar/ObjdumpProcessor.h
+++ b/tester/covoar/ObjdumpProcessor.h
@@ -143,7 +143,7 @@ namespace Coverage {
* an instruction that results in a code branch, otherwise
* it returns false.
- bool IsBranch( const char *instruction );
+ bool IsBranch( const std::string& instruction );
* This method returns true if the instruction from
diff --git a/tester/covoar/TargetBase.cc b/tester/covoar/TargetBase.cc
index 4474fad..7ee45b5 100644
--- a/tester/covoar/TargetBase.cc
+++ b/tester/covoar/TargetBase.cc
@@ -60,9 +60,7 @@ namespace Target {
return targetName_m.c_str();
- bool TargetBase::isBranch(
- const char* const instruction
+ bool TargetBase::isBranch( const std::string& instruction )
std::list <std::string>::iterator i;
@@ -76,7 +74,7 @@ namespace Target {
i = find(
conditionalBranchInstructions.begin(),
conditionalBranchInstructions.end(),
- instruction
+ instruction.c_str()
if ( i == conditionalBranchInstructions.end() )
return false;
diff --git a/tester/covoar/TargetBase.h b/tester/covoar/TargetBase.h
index 6db08f2..e5c143e 100644
--- a/tester/covoar/TargetBase.h
+++ b/tester/covoar/TargetBase.h
@@ -98,9 +98,7 @@ namespace Target {
* This method determines if the specified line from an
* objdump file is a branch instruction.
- bool isBranch(
+ bool isBranch( const std::string& instruction );
* This method returns the bit set by Qemu in the trace record
diff --git a/tester/covoar/TraceReaderBase.h b/tester/covoar/TraceReaderBase.h
index 3005c62..cbb9a62 100644
--- a/tester/covoar/TraceReaderBase.h
+++ b/tester/covoar/TraceReaderBase.h
@@ -7,6 +7,8 @@
#ifndef __TRACE_READER_BASE_H__
#define __TRACE_READER_BASE_H__
+#include <string>
#include "TraceList.h"
#include "ObjdumpProcessor.h"
@@ -47,7 +49,7 @@ namespace Trace {
* @return Returns TRUE if the method succeeded and FALSE if it failed.
virtual bool processFile(
- const char* const file,
+ const std::string& file,
Coverage::ObjdumpProcessor& objdumpProcessor
) = 0;
diff --git a/tester/covoar/TraceReaderLogQEMU.cc b/tester/covoar/TraceReaderLogQEMU.cc
index 57bcaa1..c303d08 100644
--- a/tester/covoar/TraceReaderLogQEMU.cc
+++ b/tester/covoar/TraceReaderLogQEMU.cc
@@ -40,6 +40,9 @@
#include <sys/stat.h>
+#include <iostream>
+#include <fstream>
#include "qemu-log.h"
#include "TraceReaderBase.h"
#include "TraceReaderLogQEMU.h"
@@ -48,28 +51,16 @@
#include "rld-process.h"
-#if HAVE_STAT64
-#define STAT stat64
-#else
-#define STAT stat
-#endif
-#if HAVE_OPEN64
-#define OPEN fopen64
-#else
-#define OPEN fopen
-#endif
-#define MAX_LINE_LENGTH 512
-bool ReadUntilFound( FILE *file, const char *line )
+bool ReadUntilFound( std::ifstream& file, const char* line )
char discardBuff[100];
size_t len = strlen( line );
do {
- if ( !fgets( discardBuff, 99, file ) )
+ file.read( discardBuff, 99 );
+ if ( file.fail() ) {
return false;
if ( strncmp( discardBuff, line, len ) == 0 )
return true;
@@ -87,7 +78,7 @@ namespace Trace {
bool TraceReaderLogQEMU::processFile(
@@ -96,42 +87,41 @@ namespace Trace {
QEMU_LOG_IN_Block_t last = { 0, "", "" };
QEMU_LOG_IN_Block_t nextExecuted = { 0, "", "" };
uint32_t nextlogical;
- struct STAT statbuf;
int status;
- FILE* logFile;
+ std::ifstream logFile;
int result;
- char inputBuffer[MAX_LINE_LENGTH];
+ int fileSize;
+ char ignore;
// Verify that the log file has a non-zero size.
- // NOTE: We prefer stat64 because some of the coverage files are HUGE!
- status = STAT( file, &statbuf );
- if (status == -1) {
- fprintf( stderr, "Unable to stat %s\n", file );
+ logFile.open( file, std::ifstream::in | std::ifstream::binary );
+ if ( !logFile.is_open() ) {
+ std::cerr << "Unable to open " << file << std::endl;
return false;
- if (statbuf.st_size == 0) {
- fprintf( stderr, "%s is 0 bytes long\n", file );
+ logFile.seekg( 0, std::ios::end );
+ fileSize = logFile.tellg();
+ if ( fileSize == 0 ) {
+ std::cerr << file << " is 0 bytes long" << std::endl;
return false;
+ logFile.close();
// Open the coverage file and discard the header.
- logFile = OPEN( file, "r" );
- if (!logFile) {
- fprintf( stderr, "Unable to open %s\n", file );
- return false;
+ logFile.open( file );
// Discard Header section
if (! ReadUntilFound( logFile, QEMU_LOG_SECTION_END ) ) {
- fprintf( stderr, "Unable to locate end of log file header\n" );
- fclose( logFile );
+ std::cerr << "Unable to locate end of log file header" << std::endl;
return false;
@@ -139,25 +129,22 @@ namespace Trace {
// Find first IN block
if (! ReadUntilFound( logFile, QEMU_LOG_IN_KEY )){
- fprintf(stderr,"Error: Unable to locate first IN: Block in Log file \n");
+ std::cerr << "Error: Unable to locate first IN: Block in Log file"
+ << std::endl;
return false;
// Read First Start Address
- fgets(inputBuffer, MAX_LINE_LENGTH, logFile );
- result = sscanf(
- inputBuffer,
- "0x%08lx: %s %s\n",
- &first.address,
- first.instruction,
- first.data
- if ( result < 2 )
- fprintf(stderr, "Error Unable to Read Initial First Block\n" );
+ logFile >> std::hex >> first.address >> std::dec
+ >> ignore
+ >> first.instruction
+ >> first.data;
+ if ( logFile.fail() ) {
+ std::cerr << "Error Unable to Read Initial First Block"
+ << std::endl;
done = true;
@@ -167,15 +154,11 @@ namespace Trace {
// Read until we get to the last instruction in the block.
do {
- result = sscanf(
- inputBuffer,
- &last.address,
- last.instruction,
- last.data
- } while( result > 1);
+ logFile >> std::hex >> last.address >> std::dec
+ >> ignore
+ >> last.instruction
+ >> last.data;
+ } while( !logFile.fail() );
nextlogical = objdumpProcessor.getAddressAfter(last.address);
@@ -183,17 +166,13 @@ namespace Trace {
done = true;
nextExecuted = last;
} else {
- result = sscanf(
- inputBuffer,
- &nextExecuted.address,
- nextExecuted.instruction,
- nextExecuted.data
- if ( result < 2 )
- fprintf(stderr, "Error Unable to Read First Block\n" );
+ logFile >> std::hex >> nextExecuted.address >> std::dec
+ >> ignore
+ >> nextExecuted.instruction
+ >> nextExecuted.data;
+ std::cerr << "Error Unable to Read First Block" << std::endl;
@@ -213,7 +192,7 @@ namespace Trace {
first = nextExecuted;
return true;
diff --git a/tester/covoar/TraceReaderLogQEMU.h b/tester/covoar/TraceReaderLogQEMU.h
index 8ee5651..59b5d23 100644
--- a/tester/covoar/TraceReaderLogQEMU.h
+++ b/tester/covoar/TraceReaderLogQEMU.h
@@ -43,7 +43,7 @@ namespace Trace {
diff --git a/tester/covoar/qemu-log.h b/tester/covoar/qemu-log.h
index cbca05e..e9c89dc 100644
--- a/tester/covoar/qemu-log.h
+++ b/tester/covoar/qemu-log.h
@@ -15,8 +15,8 @@
typedef struct {
unsigned long address;
- char instruction[10];
- char data[20];
+ std::string instruction;
+ std::string data;
} QEMU_LOG_IN_Block_t;
1.8.3.1
