[PATCH rtems-tools v1 3/7] TraceWriter: Convert to C++
Ryan Long
ryan.long at oarcorp.com
Tue Sep 21 16:44:59 UTC 2021
tester/covoar/TraceWriterBase.h | 3 ++-
tester/covoar/TraceWriterQEMU.cc | 36 ++++++++++++------------------------
tester/covoar/TraceWriterQEMU.h | 2 +-
3 files changed, 15 insertions(+), 26 deletions(-)
diff --git a/tester/covoar/TraceWriterBase.h b/tester/covoar/TraceWriterBase.h
index 9e80dbc..a18c387 100644
--- a/tester/covoar/TraceWriterBase.h
+++ b/tester/covoar/TraceWriterBase.h
@@ -8,6 +8,7 @@
#define __TRACE_WRITER_BASE_H__
#include <stdint.h>
+#include <string>
#include "TraceReaderBase.h"
namespace Trace {
@@ -41,7 +42,7 @@ namespace Trace {
* @return Returns TRUE if the method succeeded and FALSE if it failed.
virtual bool writeFile(
- const char* const file,
+ const std::string& file,
Trace::TraceReaderBase *log,
bool verbose
) = 0;
diff --git a/tester/covoar/TraceWriterQEMU.cc b/tester/covoar/TraceWriterQEMU.cc
index 177b77f..577acab 100644
--- a/tester/covoar/TraceWriterQEMU.cc
+++ b/tester/covoar/TraceWriterQEMU.cc
@@ -38,6 +38,7 @@
#include <cstdio>
#include <iostream>
+#include <fstream>
#include <iomanip>
#include <rld-process.h>
@@ -47,18 +48,6 @@
#include "CoverageMap.h"
#include "qemu-traces.h"
-#if HAVE_STAT64
-#define STAT stat64
-#else
-#define STAT stat
-#endif
-#if HAVE_OPEN64
-#define OPEN fopen64
-#else
-#define OPEN fopen
-#endif
namespace Trace {
TraceWriterQEMU::TraceWriterQEMU():
@@ -71,14 +60,14 @@ namespace Trace {
bool TraceWriterQEMU::writeFile(
bool verbose
struct trace_header header;
int status;
- FILE* traceFile;
+ std::ofstream traceFile;
uint8_t taken;
uint8_t notTaken;
@@ -89,15 +78,16 @@ namespace Trace {
// Verify that the TraceList has a non-zero size.
if ( log->Trace.set.begin() == log->Trace.set.end() ){
- fprintf( stderr, "ERROR: Empty TraceList\n" );
+ std::cerr << "ERROR: Empty TraceList" << std::endl;
return false;
// Open the trace file.
- traceFile = ::OPEN( file, "w" );
- if (!traceFile) {
+ traceFile.open( file );
+ if ( !traceFile.is_open() ) {
std::ostringstream what;
std::cerr << "Unable to open " << file << std::endl;
return false;
@@ -113,10 +103,10 @@ namespace Trace {
header.big_endian = false;
header.machine[0] = 0; // XXX ??
header.machine[1] = 0; // XXX ??
- status = ::fwrite( &header, sizeof(trace_header), 1, traceFile );
- if (status != 1) {
+ traceFile.write( (char *) &header, sizeof( trace_header ) );
+ if ( traceFile.fail() ) {
std::cerr << "Unable to write header to " << file << std::endl;
- ::fclose( traceFile );
return false;
@@ -163,15 +153,13 @@ namespace Trace {
<< std::dec << std::setfill(' ')
<< std::endl;
- status = ::fwrite( &entry, sizeof(entry), 1, traceFile );
+ traceFile.write( (char *) &entry, sizeof( entry ) );
std::cerr << "Unable to write entry to " << file << std::endl;
return false;
return true;
diff --git a/tester/covoar/TraceWriterQEMU.h b/tester/covoar/TraceWriterQEMU.h
index 09c2ddf..aa89860 100644
--- a/tester/covoar/TraceWriterQEMU.h
+++ b/tester/covoar/TraceWriterQEMU.h
@@ -44,7 +44,7 @@ namespace Trace {
bool writeFile(
bool verbose
1.8.3.1
