[PATCH rtems-docs] posix.rst: Add info for FreeBSD 13
Ryan Long
ryan.long at oarcorp.com
Tue Sep 21 18:05:22 UTC 2021
Add list of additional packages needed to build RTEMS environment for
FreeBSD 13.
user/hosts/posix.rst | 10 ++++++++++
1 file changed, 10 insertions(+)
diff --git a/user/hosts/posix.rst b/user/hosts/posix.rst
index 6686fc9..284df48 100644
--- a/user/hosts/posix.rst
+++ b/user/hosts/posix.rst
@@ -195,6 +195,16 @@ The RTEMS Source Builder has been tested on FreeBSD 9.1, 10.3, 11 and
# pkg install -y python
# pkg install -y gsed
+For FreeBSD 13, you will need to install the packages listed above, as well as
+the following additional ones. They are:
+.. code-block:: none
+ # pkg install -y bison
+ # pkg install -y texinfo
+ # pkg install -y gmake
+ # pkg install -y binutils
FreeBSD's default C compiler is LLVM and installing the host's GCC compiler
package may break building GCC. We recommend you do not install the GCC
package and you use the default C compiler.
1.8.3.1
