[PATCH rtems-docs] posix.rst: Add info for FreeBSD 13
Chris Johns
chrisj at rtems.org
Tue Sep 21 22:59:54 UTC 2021
On 22/9/21 4:05 am, Ryan Long wrote:
> Add list of additional packages needed to build RTEMS environment for
> FreeBSD 13.
> user/hosts/posix.rst | 10 ++++++++++
> 1 file changed, 10 insertions(+)
> diff --git a/user/hosts/posix.rst b/user/hosts/posix.rst
> index 6686fc9..284df48 100644
> --- a/user/hosts/posix.rst
> +++ b/user/hosts/posix.rst
> @@ -195,6 +195,16 @@ The RTEMS Source Builder has been tested on FreeBSD 9.1, 10.3, 11 and
> # pkg install -y python
> # pkg install -y gsed
> +For FreeBSD 13, you will need to install the packages listed above, as well as
> +the following additional ones. They are:
> +.. code-block:: none
> + # pkg install -y bison
> + # pkg install -y texinfo
> + # pkg install -y gmake
> + # pkg install -y binutils
If we use this in the documenation:
# pkg install -y bison texinfo gmake binutils
it is a simple one line copy and paste to use :)
Thanks
