[PATCH] score: Improve variable names in thread init
Gedare Bloom
gedare at rtems.org
Wed Sep 22 13:32:42 UTC 2021
ok
On Tue, Sep 21, 2021 at 5:36 AM Sebastian Huber
> cpukit/score/src/threadinitialize.c | 50 ++++++++++++++---------------
> 1 file changed, 25 insertions(+), 25 deletions(-)
> diff --git a/cpukit/score/src/threadinitialize.c b/cpukit/score/src/threadinitialize.c
> index e10eb1af88..81199a7044 100644
> --- a/cpukit/score/src/threadinitialize.c
> +++ b/cpukit/score/src/threadinitialize.c
> @@ -101,17 +101,17 @@ static void _Thread_Initialize_scheduler_and_wait_nodes(
> const Thread_Configuration *config
> - Scheduler_Node *scheduler_node;
> + Scheduler_Node *home_scheduler_node;
> #if defined(RTEMS_SMP)
> - Scheduler_Node *scheduler_node_for_index;
> - const Scheduler_Control *scheduler_for_index;
> + Scheduler_Node *scheduler_node;
> + const Scheduler_Control *scheduler;
> size_t scheduler_index;
> #endif
> - scheduler_node = NULL;
> - scheduler_node_for_index = the_thread->Scheduler.nodes;
> - scheduler_for_index = &_Scheduler_Table[ 0 ];
> + home_scheduler_node = NULL;
> + scheduler_node = the_thread->Scheduler.nodes;
> + scheduler = &_Scheduler_Table[ 0 ];
> scheduler_index = 0;
> @@ -121,27 +121,27 @@ static void _Thread_Initialize_scheduler_and_wait_nodes(
> * configured.
> while ( scheduler_index < _Scheduler_Count ) {
> - Priority_Control priority_for_index;
> + Priority_Control priority;
> - if ( scheduler_for_index == config->scheduler ) {
> - priority_for_index = config->priority;
> - scheduler_node = scheduler_node_for_index;
> + if ( scheduler == config->scheduler ) {
> + priority = config->priority;
> + home_scheduler_node = scheduler_node;
> } else {
> * Use the idle thread priority for the non-home scheduler instances by
> * default.
> - priority_for_index = _Scheduler_Map_priority(
> - scheduler_for_index,
> - scheduler_for_index->maximum_priority
> + priority = _Scheduler_Map_priority(
> + scheduler,
> + scheduler->maximum_priority
> _Scheduler_Node_initialize(
> - scheduler_node_for_index,
> + scheduler,
> + scheduler_node,
> the_thread,
> + priority
> @@ -149,9 +149,9 @@ static void _Thread_Initialize_scheduler_and_wait_nodes(
> * configuration, the _Scheduler_Node_size constant is used to get the next
> * scheduler node. Using sizeof( Scheduler_Node ) would be wrong.
> - scheduler_node_for_index = (Scheduler_Node *)
> - ( (uintptr_t) scheduler_node_for_index + _Scheduler_Node_size );
> - ++scheduler_for_index;
> + scheduler_node = (Scheduler_Node *)
> + ( (uintptr_t) scheduler_node + _Scheduler_Node_size );
> + ++scheduler;
> ++scheduler_index;
> @@ -159,23 +159,23 @@ static void _Thread_Initialize_scheduler_and_wait_nodes(
> * The thread is initialized to use exactly one scheduler node which is
> * provided by its home scheduler.
> - _Assert( scheduler_node != NULL );
> + _Assert( home_scheduler_node != NULL );
> _Chain_Initialize_one(
> &the_thread->Scheduler.Wait_nodes,
> - &scheduler_node->Thread.Wait_node
> + &home_scheduler_node->Thread.Wait_node
> &the_thread->Scheduler.Scheduler_nodes,
> - &scheduler_node->Thread.Scheduler_node.Chain
> + &home_scheduler_node->Thread.Scheduler_node.Chain
> #else
> * In uniprocessor configurations, the thread has exactly one scheduler node.
> - scheduler_node = _Thread_Scheduler_get_home_node( the_thread );
> + home_scheduler_node = _Thread_Scheduler_get_home_node( the_thread );
> config->scheduler,
> - scheduler_node,
> + home_scheduler_node,
> the_thread,
> config->priority
> @@ -189,7 +189,7 @@ static void _Thread_Initialize_scheduler_and_wait_nodes(
> _Priority_Node_initialize( &the_thread->Real_priority, config->priority );
> _Priority_Initialize_one(
> - &scheduler_node->Wait.Priority,
> + &home_scheduler_node->Wait.Priority,
> 2.31.1
> devel mailing list
> devel at rtems.org
