[PATCH] score: Improve variable names in thread init
Sebastian Huber
Tue Sep 21 11:36:05 UTC 2021
cpukit/score/src/threadinitialize.c | 50 ++++++++++++++---------------
1 file changed, 25 insertions(+), 25 deletions(-)
diff --git a/cpukit/score/src/threadinitialize.c b/cpukit/score/src/threadinitialize.c
index e10eb1af88..81199a7044 100644
--- a/cpukit/score/src/threadinitialize.c
+++ b/cpukit/score/src/threadinitialize.c
@@ -101,17 +101,17 @@ static void _Thread_Initialize_scheduler_and_wait_nodes(
const Thread_Configuration *config
- Scheduler_Node *scheduler_node;
+ Scheduler_Node *home_scheduler_node;
#if defined(RTEMS_SMP)
- Scheduler_Node *scheduler_node_for_index;
- const Scheduler_Control *scheduler_for_index;
+ Scheduler_Node *scheduler_node;
+ const Scheduler_Control *scheduler;
size_t scheduler_index;
#endif
- scheduler_node = NULL;
- scheduler_node_for_index = the_thread->Scheduler.nodes;
- scheduler_for_index = &_Scheduler_Table[ 0 ];
+ home_scheduler_node = NULL;
+ scheduler_node = the_thread->Scheduler.nodes;
+ scheduler = &_Scheduler_Table[ 0 ];
scheduler_index = 0;
@@ -121,27 +121,27 @@ static void _Thread_Initialize_scheduler_and_wait_nodes(
* configured.
while ( scheduler_index < _Scheduler_Count ) {
- Priority_Control priority_for_index;
+ Priority_Control priority;
- if ( scheduler_for_index == config->scheduler ) {
- priority_for_index = config->priority;
- scheduler_node = scheduler_node_for_index;
+ if ( scheduler == config->scheduler ) {
+ priority = config->priority;
+ home_scheduler_node = scheduler_node;
} else {
* Use the idle thread priority for the non-home scheduler instances by
* default.
- priority_for_index = _Scheduler_Map_priority(
- scheduler_for_index,
- scheduler_for_index->maximum_priority
+ priority = _Scheduler_Map_priority(
+ scheduler,
+ scheduler->maximum_priority
_Scheduler_Node_initialize(
- scheduler_node_for_index,
+ scheduler,
+ scheduler_node,
the_thread,
+ priority
@@ -149,9 +149,9 @@ static void _Thread_Initialize_scheduler_and_wait_nodes(
* configuration, the _Scheduler_Node_size constant is used to get the next
* scheduler node. Using sizeof( Scheduler_Node ) would be wrong.
- scheduler_node_for_index = (Scheduler_Node *)
- ( (uintptr_t) scheduler_node_for_index + _Scheduler_Node_size );
- ++scheduler_for_index;
+ scheduler_node = (Scheduler_Node *)
+ ( (uintptr_t) scheduler_node + _Scheduler_Node_size );
+ ++scheduler;
++scheduler_index;
@@ -159,23 +159,23 @@ static void _Thread_Initialize_scheduler_and_wait_nodes(
* The thread is initialized to use exactly one scheduler node which is
* provided by its home scheduler.
- _Assert( scheduler_node != NULL );
+ _Assert( home_scheduler_node != NULL );
_Chain_Initialize_one(
&the_thread->Scheduler.Wait_nodes,
- &scheduler_node->Thread.Wait_node
+ &home_scheduler_node->Thread.Wait_node
&the_thread->Scheduler.Scheduler_nodes,
- &scheduler_node->Thread.Scheduler_node.Chain
+ &home_scheduler_node->Thread.Scheduler_node.Chain
#else
* In uniprocessor configurations, the thread has exactly one scheduler node.
- scheduler_node = _Thread_Scheduler_get_home_node( the_thread );
+ home_scheduler_node = _Thread_Scheduler_get_home_node( the_thread );
config->scheduler,
- scheduler_node,
+ home_scheduler_node,
the_thread,
config->priority
@@ -189,7 +189,7 @@ static void _Thread_Initialize_scheduler_and_wait_nodes(
_Priority_Node_initialize( &the_thread->Real_priority, config->priority );
_Priority_Initialize_one(
- &scheduler_node->Wait.Priority,
+ &home_scheduler_node->Wait.Priority,
2.31.1
