[PATCH rtems-tools 3/3] tester/mvme2307: Add support for the MVME2307 (MVME2700) BSP
Gedare Bloom
gedare at rtems.org
Wed Sep 22 13:36:52 UTC 2021
ok
On Tue, Sep 21, 2021 at 1:42 AM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
> - Assumes a stand alone TFTP server
> tester/rtems/testing/bsps/mvme2307.ini | 59 ++++++++++++++++++++++++++
> 1 file changed, 59 insertions(+)
> create mode 100644 tester/rtems/testing/bsps/mvme2307.ini
> diff --git a/tester/rtems/testing/bsps/mvme2307.ini b/tester/rtems/testing/bsps/mvme2307.ini
> new file mode 100644
> index 0000000..b142aa9
> --- /dev/null
> +++ b/tester/rtems/testing/bsps/mvme2307.ini
> @@ -0,0 +1,59 @@
> +# RTEMS Tools Project (http://www.rtems.org/)
> +# Copyright 2021 Chris Johns (chrisj at rtems.org)
> +# All rights reserved.
> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
> +# Redistribution and use in source and binary forms, with or without
> +# modification, are permitted provided that the following conditions are met:
> +# 1. Redistributions of source code must retain the above copyright notice,
> +# this list of conditions and the following disclaimer.
> +# 2. Redistributions in binary form must reproduce the above copyright notice,
> +# this list of conditions and the following disclaimer in the documentation
> +# and/or other materials provided with the distribution.
> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> +# POSSIBILITY OF SUCH DAMAGE.
> +# The MVME2307 BSP
> +# This BSP uses the bootloader's network autoboot to boot the board. It
> +# does nothing but sleep for the test's timeout period.
> +# You need to:
> +# 1. Set up a TFTP server and provide a suitable path to copy the
> +# bootable image to.
> +# 2. Use the `env` command to enable network autoboot:
> +# Network Auto Boot Enable [Y/N] = N? y
> +# 3. Provide a script to power cycle the board
> +# 4. Provide a telnet connection to the serial port
> +# 5. Create a script that converts the executable to the
> +# bootable image and copy the image to the TFTP server.
> +[mvme2307]
> +bsp = mvme2307
> +arch = powerpc
> +jobs = 1
> +test_restarts = 3
> +tester = %{_rtscripts}/wait.cfg
> +target_start_regex = ^Copyright Motorola Inc.*, All Rights Reserved
> +requires = target_on_command, target_off_command, target_reset_command, bsp_tty_dev
> 2.24.1
> devel mailing list
> devel at rtems.org
