[PATCH] score: Simplify _Thread_Try_initialize()
Sebastian Huber
Tue Sep 21 11:24:53 UTC 2021
Move a code block to its own new function
_Thread_Initialize_scheduler_and_wait_nodes(). Add comments.
cpukit/score/src/threadinitialize.c | 180 +++++++++++++++++-----------
1 file changed, 108 insertions(+), 72 deletions(-)
diff --git a/cpukit/score/src/threadinitialize.c b/cpukit/score/src/threadinitialize.c
index 9c1b809c3a..e10eb1af88 100644
--- a/cpukit/score/src/threadinitialize.c
+++ b/cpukit/score/src/threadinitialize.c
@@ -96,6 +96,113 @@ void _Thread_Free(
_Objects_Free( &information->Objects, &the_thread->Object );
+static void _Thread_Initialize_scheduler_and_wait_nodes(
+ Thread_Control *the_thread,
+ const Thread_Configuration *config
+ Scheduler_Node *scheduler_node;
+#if defined(RTEMS_SMP)
+ Scheduler_Node *scheduler_node_for_index;
+ const Scheduler_Control *scheduler_for_index;
+ size_t scheduler_index;
+#endif
+ scheduler_node = NULL;
+ scheduler_node_for_index = the_thread->Scheduler.nodes;
+ scheduler_for_index = &_Scheduler_Table[ 0 ];
+ scheduler_index = 0;
+ * In SMP configurations, the thread has exactly one scheduler node for each
+ * configured scheduler. Initialize the scheduler nodes of each scheduler.
+ * The application configuration ensures that we have at least one scheduler
+ * configured.
+ while ( scheduler_index < _Scheduler_Count ) {
+ Priority_Control priority_for_index;
+ if ( scheduler_for_index == config->scheduler ) {
+ priority_for_index = config->priority;
+ scheduler_node = scheduler_node_for_index;
+ } else {
+ * Use the idle thread priority for the non-home scheduler instances by
+ * default.
+ priority_for_index = _Scheduler_Map_priority(
+ scheduler_for_index,
+ scheduler_for_index->maximum_priority
+ _Scheduler_Node_initialize(
+ scheduler_node_for_index,
+ the_thread,
+ * Since the size of a scheduler node depends on the application
+ * configuration, the _Scheduler_Node_size constant is used to get the next
+ * scheduler node. Using sizeof( Scheduler_Node ) would be wrong.
+ scheduler_node_for_index = (Scheduler_Node *)
+ ( (uintptr_t) scheduler_node_for_index + _Scheduler_Node_size );
+ ++scheduler_for_index;
+ ++scheduler_index;
+ * The thread is initialized to use exactly one scheduler node which is
+ * provided by its home scheduler.
+ _Assert( scheduler_node != NULL );
+ _Chain_Initialize_one(
+ &the_thread->Scheduler.Wait_nodes,
+ &scheduler_node->Thread.Wait_node
+ &the_thread->Scheduler.Scheduler_nodes,
+ &scheduler_node->Thread.Scheduler_node.Chain
+#else
+ * In uniprocessor configurations, the thread has exactly one scheduler node.
+ scheduler_node = _Thread_Scheduler_get_home_node( the_thread );
+ config->scheduler,
+ scheduler_node,
+ the_thread,
+ config->priority
+#endif
+ * The current priority of the thread is initialized to exactly the real
+ * priority of the thread. During the lifetime of the thread, it may gain
+ * more priority nodes, for example through locking protocols such as
+ * priority inheritance or priority ceiling.
+ _Priority_Node_initialize( &the_thread->Real_priority, config->priority );
+ _Priority_Initialize_one(
+ &scheduler_node->Wait.Priority,
+ &the_thread->Real_priority
+ RTEMS_STATIC_ASSERT( THREAD_SCHEDULER_BLOCKED == 0, Scheduler_state );
+ the_thread->Scheduler.home_scheduler = config->scheduler;
+ _ISR_lock_Initialize( &the_thread->Scheduler.Lock, "Thread Scheduler" );
+ _ISR_lock_Initialize( &the_thread->Wait.Lock.Default, "Thread Wait Default" );
+ _Thread_queue_Gate_open( &the_thread->Wait.Lock.Tranquilizer );
+ _RBTree_Initialize_node( &the_thread->Wait.Link.Registry_node );
+#endif
static bool _Thread_Try_initialize(
Thread_Information *information,
@@ -107,12 +214,6 @@ static bool _Thread_Try_initialize(
char *stack_begin;
char *stack_end;
uintptr_t stack_align;
- Scheduler_Node *scheduler_node;
-#if defined(RTEMS_SMP)
- Scheduler_Node *scheduler_node_for_index;
- const Scheduler_Control *scheduler_for_index;
- size_t scheduler_index;
-#endif
Per_CPU_Control *cpu = _Per_CPU_Get_by_index( 0 );
memset(
@@ -182,78 +283,13 @@ static bool _Thread_Try_initialize(
the_thread->Start.stack_free = config->stack_free;
_Thread_Timer_initialize( &the_thread->Timer, cpu );
+ _Thread_Initialize_scheduler_and_wait_nodes( the_thread, config );
- scheduler_node = NULL;
- scheduler_node_for_index = the_thread->Scheduler.nodes;
- scheduler_for_index = &_Scheduler_Table[ 0 ];
- scheduler_index = 0;
- while ( scheduler_index < _Scheduler_Count ) {
- Priority_Control priority_for_index;
- if ( scheduler_for_index == config->scheduler ) {
- priority_for_index = config->priority;
- scheduler_node = scheduler_node_for_index;
- } else {
- * Use the idle thread priority for the non-home scheduler instances by
- * default.
- priority_for_index = _Scheduler_Map_priority(
- scheduler_for_index,
- scheduler_for_index->maximum_priority
- _Scheduler_Node_initialize(
- scheduler_node_for_index,
- the_thread,
- scheduler_node_for_index = (Scheduler_Node *)
- ( (uintptr_t) scheduler_node_for_index + _Scheduler_Node_size );
- ++scheduler_for_index;
- ++scheduler_index;
- _Assert( scheduler_node != NULL );
- _Chain_Initialize_one(
- &the_thread->Scheduler.Wait_nodes,
- &scheduler_node->Thread.Wait_node
- &the_thread->Scheduler.Scheduler_nodes,
- &scheduler_node->Thread.Scheduler_node.Chain
-#else
- scheduler_node = _Thread_Scheduler_get_home_node( the_thread );
- config->scheduler,
- scheduler_node,
- the_thread,
- config->priority
-#endif
- _Priority_Node_initialize( &the_thread->Real_priority, config->priority );
- _Priority_Initialize_one(
- &scheduler_node->Wait.Priority,
- &the_thread->Real_priority
- RTEMS_STATIC_ASSERT( THREAD_SCHEDULER_BLOCKED == 0, Scheduler_state );
- the_thread->Scheduler.home_scheduler = config->scheduler;
- _ISR_lock_Initialize( &the_thread->Scheduler.Lock, "Thread Scheduler" );
_Processor_mask_Assign(
&the_thread->Scheduler.Affinity,
_SMP_Get_online_processors()
- _ISR_lock_Initialize( &the_thread->Wait.Lock.Default, "Thread Wait Default" );
- _Thread_queue_Gate_open( &the_thread->Wait.Lock.Tranquilizer );
- _RBTree_Initialize_node( &the_thread->Wait.Link.Registry_node );
_SMP_lock_Stats_initialize( &the_thread->Potpourri_stats, "Thread Potpourri" );
_SMP_lock_Stats_initialize( &the_thread->Join_queue.Lock_stats, "Thread State" );
#endif
2.31.1
