[PATCH rtems-docs] eng: Add rules for attribution
Christian MAUDERER christian.mauderer at embedded-brains.de
Tue Sep 28 13:11:59 UTC 2021
Hello Joel,
Am 28.09.21 um 14:48 schrieb Joel Sherrill:
> On Tue, Sep 28, 2021, 1:40 AM Christian MAUDERER
> <christian.mauderer at embedded-brains.de
> <mailto:christian.mauderer at embedded-brains.de>> wrote:
>     Hello Joel,
>     Am 28.09.21 um 01:12 schrieb Joel Sherrill:
>      > The Microblaze port is interesting for attribution. I did initial
>     work
>      > on it. Hesham added to that and got Hello on a board. Alex is
>     close to
>      > submitting the port in a nice state.
>      > This is almost seven years across three developers.. The original
>     work
>      > predates source code reorganisation. Alex deleted the autoconf
>     support
>      > and created waf. Hesham and I agreed to convert to BSD-2.
>      > When submitted, we decided it was best for Alex to submit a Joel
>     patch,
>      > then Hesham, then Alex to finish it off. This keeps git blame
>     working.
>      > Not quite the same topic but related to credit due.
>     But maybe an important extension. Should we replace "sponsored" with
>     "sponsored or supported"? That would allow to mention anyone who helps
>     in any way, regardless whether it's financial, with information, with
>     hobby time or with whatever else.
> I usually use the word sponsored. Support implies commercial activities
> the way I/we tend to use it.
Seems that I picked the wrong word then. Maybe you can help me finding
the correct term:
The one case is clear: Someone pays that someone else develops for
example a driver. I think for that "sponsored" is a good term.
Another similar case could be the following: You get help with writing a
driver for example with information or some other form of help that
doesn't result in a copyright for that person or company. It doesn't
involve money or some other form of payment (T-shirts, pizza, ...) so
it's not really sponsoring. Despite that it might would be nice to
mention them if they want to be mentioned. I think the right location
would be the same place like the one we just discuss for sponsoring.
What would be a good term for that?
Best regards
Christian
>      > On Mon, Sep 27, 2021, 9:49 AM Christian Mauderer
>     <mailto:christian.mauderer at embedded-brains.de>>> wrote:
>      >     This adds some rules how an attribution for sponsored
>     development should
>      >     look like.
>      >     Note: This patch is more or less an early draft. See the
>     following
>      >     discussion
>      >     for more background:
>     https://lists.rtems.org/pipermail/devel/2021-September/069465.html
>     <https://lists.rtems.org/pipermail/devel/2021-September/069465.html>
>       <https://lists.rtems.org/pipermail/devel/2021-September/069465.html <https://lists.rtems.org/pipermail/devel/2021-September/069465.html>>
>      >     Points that need discussion:
>      >     * Are there some areas where we don't want to have
>     attribution lines
>      >     (Chris
>      >        asked about score in the linked discussion). From my point of
>      >     view: If there
>      >        is a big contribution and the sponsor wants his name in the
>      >     (changed) files,
>      >        that's OK.
>      >     * Do we want attributions in documentation sources? I'm not sure
>      >     whether they
>      >        might end in HTML comments in the distributed documentation.
>      > So far, not enough small has been submitted to matter.
>      > I'm happy with a master list
>     So for documentation it would be one SUPPORTERS file that isn't
>     processed in any way?
>      >     * What kind of format do we want in the documentation?
>     Restructured Text
>      >        documentation suggests that the two dots should be on a
>     separate
>      >     line to avoid
>      >        interpreting the comment as directive:
>     https://docutils.sourceforge.io/docs/ref/rst/restructuredtext.html#comments
>     <https://docutils.sourceforge.io/docs/ref/rst/restructuredtext.html#comments>
>       <https://docutils.sourceforge.io/docs/ref/rst/restructuredtext.html#comments <https://docutils.sourceforge.io/docs/ref/rst/restructuredtext.html#comments>>
>      >     * Do we need some kind of "signed off" from the sponsor (or
>     similar)
>      >     in the
>      >        commits that add attribution so that we can later tell who
>     said
>      >     that it is OK
>      >        that we mention the sponsor?
>      > We've done this on trust for a long time but wouldn't git blame
>     tell us
>      > the same? If it is a manager without git, then what?
>     Hm. Good questions.
>     What I wanted to tell is: Do we need to document who allowed us to
>     mention the company name?
>     "git blame" won't tell the same. It would only tell who added the line
>     "sponsored by Some Company". In most cases that will be the developer
>     working on it and not the one from "Some Company" who said that we can
>     add the name.
>     You are right that a manager without git has problems adding the signed
>     off line in the "official" git form. But git comments are free text
>     anyway. I think a "signed off" line is based on trust like everything
>     else in git. It more or less means: The one who pushes the patch has
>     some when asked the person whether the patch is OK. We can also add it
>     as a free text comment like "Some Company added with friendly
>     permission
>     by Some Person".
>     I'm not sure whether it's an advantage to add something like that or
>     whether it's unnecessary bureaucracy.
>     Best regards
>     Christian
>      >     I'm sure there are some more points. Please feel free to ask.
>     Again:
>      >     This is a
>      >     draft.
>      >     Best regards
>      >     Christian
>      >       eng/coding-file-hdr.rst | 48
>      >       1 file changed, 48 insertions(+)
>      >     diff --git a/eng/coding-file-hdr.rst b/eng/coding-file-hdr.rst
>      >     index 3167670..da6f702 100644
>      >     --- a/eng/coding-file-hdr.rst
>      >     +++ b/eng/coding-file-hdr.rst
>      >     @@ -2,6 +2,7 @@
>      >       .. Copyright (C) 2018, 2020 embedded brains GmbH
>      >     (http://www.embedded-brains.de
>     <http://www.embedded-brains.de> <http://www.embedded-brains.de
>     <http://www.embedded-brains.de>>)
>      >       .. Copyright (C) 2018, 2020 Sebastian Huber
>      >     +.. Copyright (C) 2021 Christian Mauderer
>      >       .. _FileTemplates:
>      >     @@ -74,6 +75,28 @@ Check the top-level :file:`COPYING` file
>     of the
>      >     repository.  If you are a new
>      >       copyright holder, then add yourself to the top of the list.  If
>      >     your last year
>      >       of a substantial contribution changed, then please update your
>      >     copyright line.
>      >     +.. _FileAttributionSponsor:
>      >     +Attribution for Sponsored Development
>      >     +A lot of development in RTEMS is sponsored by some users. If the
>      >     sponsor wants
>      >     +to be mentioned in the code, apply the following rules:
>      >     +* The attribution has to be a separate comment block below the
>      >     copyright block.
>      >     +* Only the name of the sponsoring company / person should be
>      >     mentioned. No
>      >     +  contact details like URLs, email, phone numbers or street
>      >     addresses should be
>      >     +  added.
>      >     +* To avoid unnecessary commits, the name of a sponsor is not
>      >     updated if (for
>      >     +  example) the name of a company changes. The only reasonable
>      >     change would be if
>      >     +  a sponsor continues to pay for bigger changes in that file
>     anyway.
>      >     +* Sponsor names are only added to files which contain relevant
>      >     amounts of
>      >     +  sponsored work. As a rule of thumb: If the work justifies
>     adding
>      >     a copyright
>      >     +  line, it also justifies adding a sponsor line.
>      >       .. _CCXXHeaderFileTemplate:
>      >       C/C++ Header File Template
>      >     @@ -96,6 +119,8 @@ Use the following guidelines and template
>     for C
>      >     and C++ header files (here
>      >       * Separate the Doxygen comment block from the copyright and
>      >     license, so that
>      >         the copyright and license information is not included in the
>      >     Doxygen output.
>      >     +* If there is a sponsor: Add it as a separate comment block.
>      >       * For C++ header files discard the ``extern "C"`` start and end
>      >     sections.
>      >       .. code-block:: c
>      >     @@ -137,6 +162,12 @@ Use the following guidelines and
>     template for C
>      >            * POSSIBILITY OF SUCH DAMAGE.
>      >     +     * Initial foo bar implementation sponsored by Example Inc.
>      >     +     * Baz feature sponsored by Some LLC.
>      >           #ifndef _FOO_BAR_BAZ_H
>      >           #define _FOO_BAR_BAZ_H
>      >     @@ -204,6 +235,12 @@ and <COPYRIGHT HOLDER> placeholders see
>      >     :ref:`FileHeaderCopyright`.
>      >           #ifdef HAVE_CONFIG_H
>      >           #include "config.h"
>      >           #endif
>      >     @@ -251,6 +288,10 @@ block. RTEMS uses ``"""`` for Python
>     docstrings.
>      >           # ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
>     EVEN IF
>      >     ADVISED OF THE
>      >           # POSSIBILITY OF SUCH DAMAGE.
>      >     +    # Initial foo bar implementation sponsored by Example Inc.
>      >     +    # Baz feature sponsored by Some LLC.
>      >       If the Python source file is a command line command add the
>      >     following as the
>      >       first line of the file:
>      >     @@ -302,6 +343,10 @@ accept a ``#``-style comment block. For the
>      >     <FIRST YEAR>, <LAST YEAR>, and
>     EVEN IF
>      >     ADVISED OF THE
>      >       reStructuredText File Template
>      >     @@ -314,3 +359,6 @@ Use the following template for
>     reStructuredText
>      >     (reST) source files.  For the
>      >           .. SPDX-License-Identifier: CC-BY-SA-4.0
>      >           .. Copyright (C) <FIRST YEAR>, <LAST YEAR> <COPYRIGHT
>     HOLDER>
>      >     +       Documentation of foo bar feature sponsored by Example
>     Inc.
>      >     2.31.1
>      >     _______________________________________________
>      >     devel mailing list
>      > devel at rtems.org <mailto:devel at rtems.org> <mailto:devel at rtems.org
>     <mailto:devel at rtems.org>>
>      > http://lists.rtems.org/mailman/listinfo/devel
>     <http://lists.rtems.org/mailman/listinfo/devel>
>     <http://lists.rtems.org/mailman/listinfo/devel>>
>     Herr Christian MAUDERER
>     Dornierstr. 4
>     82178 Puchheim
>     Germany
>     email: christian.mauderer at embedded-brains.de
>     phone: +49-89-18 94 741 - 18
>     fax:   +49-89-18 94 741 - 08
>     Registergericht: Amtsgericht München
>     Registernummer: HRB 157899
>     Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>     Unsere Datenschutzerklärung finden Sie hier:
>     https://embedded-brains.de/datenschutzerklaerung/
>     <https://embedded-brains.de/datenschutzerklaerung/>
Dornierstr. 4
82178 Puchheim
Germany
