GMP error when building aarch64-rtems-gcc on Mingw64
Fri Apr 1 13:24:07 UTC 2022
On Fri, Apr 1, 2022 at 3:37 AM jameszxj <jameszxj at gmail.com> wrote:
> It has been there for a while. It is caused by the gmp
> configure parameter (in gcc/makefile.in line 12644 )
So the patch you posted fixes this?
This should be the ticket https://devel.rtems.org/ticket/4208
Ryan.. the patch he posted got turned into HTML and can't be applied. Can
you try to make the change and verify it.
https://lists.rtems.org/pipermail/devel/2022-April/071042.html
Please give him authorship credit when you commit it.
> I change "--host=none-${host_vendor}-${host_os}
> --target=none-${host_vendor}-${host_os}"
> to "--host=${host_alias} --target=${host_alias}", the
> building succeeds.
> ------------------ Original ------------------
> From:
>                                                   "Ryan Long"
> ryan.long at oarcorp.com>;
> Date: Tue, Mar 22, 2022 05:33 AM
> To: "devel"<devel at rtems.org>;
> Subject: GMP error when building aarch64-rtems-gcc on Mingw64
> While building gcc, arg3nexwm1 fails. The error follows
> In file included from ../../../gnu-mirror-gcc-348fb9d/gmp/gmp-impl.h:146,
> from fib_table.c:4:
> ../fib_table.h:4:1: warning: data definition has no type or storage class
>     4 | Error, error, this data is for 32 bits
> ../fib_table.h:4:1: warning: type defaults to 'int' in declaration of
> 'Error' [-Wimplicit-int]
> ../fib_table.h:4:8: warning: type defaults to 'int' in declaration of
> 'error' [-Wimplicit-int]
> ../fib_table.h:4:20: error: expected '=', ',', ';', 'asm' or
> '__attribute__' before 'data'
> fib_table.c:7:1: warning: data definition has no type or storage class
>     7 | Error, error, this data is for 32 bits
> fib_table.c:7:1: warning: type defaults to 'int' in declaration of
> fib_table.c:7:8: warning: type defaults to 'int' in declaration of
> fib_table.c:7:20: error: expected '=', ',', ';', 'asm' or
> This is due to GMP_NUMB_BITS not being equal to 32. Has anyone
> encountered this?
> Thanks,
> Ryan
> devel mailing list
> devel at rtems.org
> devel mailing list
> devel at rtems.org
