GMP error when building aarch64-rtems-gcc on Mingw64
zhengxiaojun
jameszxj at gmail.com
Fri Apr 1 15:06:36 UTC 2022
> On Fri, Apr 1, 2022 at 3:37 AM jameszxj <jameszxj at gmail.com> wrote:
> It has been there for a while. It is caused by the gmp configure parameter (in gcc/makefile.in line 12644 )
> So the patch you posted fixes this?
Sorry for making you confuse. That patch fixed a rtems-tools error.
Send a patch file as attachment is accepted?
> This should be the ticket https://devel.rtems.org/ticket/4208
> Ryan.. the patch he posted got turned into HTML and can't be applied. Can
> you try to make the change and verify it.
I am not sure it is the right/good way to fix this, so I do not send a patch.
> https://lists.rtems.org/pipermail/devel/2022-April/071042.html
> Please give him authorship credit when you commit it.
> devel mailing list
> devel at rtems.org
> http://lists.rtems.org/mailman/listinfo/devel</jameszxj@gmail.com>
