[PATCH 14/14] bsp/stm32h7: bring all required changes into system_stm32h7xx for STM32H7B3I-DK BSP variant
Karel Gardas karel at functional.vision
Fri Apr 1 16:14:21 UTC 2022
The changes provided here are a result of a merge from various examples
system_stm32h7xx.c files provided by STMicroelectronics for the STM32H7B3I-DK
board with the original RTEMS file provided for the STM32H743I-EVAL2 board.
 bsps/arm/stm32h7/start/system_stm32h7xx.c | 51 +++++++++++++++++++----
 1 file changed, 44 insertions(+), 7 deletions(-)
diff --git a/bsps/arm/stm32h7/start/system_stm32h7xx.c b/bsps/arm/stm32h7/start/system_stm32h7xx.c
index 092d853720..1f0fd04dab 100644
--- a/bsps/arm/stm32h7/start/system_stm32h7xx.c
+++ b/bsps/arm/stm32h7/start/system_stm32h7xx.c
@@ -51,7 +51,11 @@
 #include <bsp/linker-symbols.h>
 #endif /* __rtems__ */
 #if !defined  (HSE_VALUE)
+#ifdef STM32H7B3xxQ
+#define HSE_VALUE    ((uint32_t)24000000) /*!< Value of the External oscillator in Hz */
+#else
 #define HSE_VALUE    ((uint32_t)25000000) /*!< Value of the External oscillator in Hz */
+#endif
 #endif /* HSE_VALUE */
 #if !defined  (CSI_VALUE)
@@ -147,9 +151,9 @@
 void SystemInit (void)
-#if defined (DATA_IN_D2_SRAM)
+#if defined (DATA_IN_D2_SRAM) || defined (DATA_IN_CD_AHB_SRAM)
  __IO uint32_t tmpreg;
-#endif /* DATA_IN_D2_SRAM */
+#endif /* DATA_IN_D2_SRAM || DATA_IN_CD_AHB_SRAM */
   /* FPU settings ------------------------------------------------------------*/
   #if (__FPU_PRESENT == 1) && (__FPU_USED == 1)
@@ -184,6 +188,26 @@ void SystemInit (void)
   /* Reset SRDCFGR register */
   RCC->SRDCFGR = 0x00000000;
 #endif
+  /* Reset PLLCKSELR register */
+  RCC->PLLCKSELR = 0x02020200;
+  /* Reset PLLCFGR register */
+  RCC->PLLCFGR = 0x01FF0000;
+  /* Reset PLL1DIVR register */
+  RCC->PLL1DIVR = 0x01010280;
+  /* Reset PLL1FRACR register */
+  RCC->PLL1FRACR = 0x00000000;
+  /* Reset PLL2DIVR register */
+  RCC->PLL2DIVR = 0x01010280;
+  /* Reset PLL2FRACR register */
+  RCC->PLL2FRACR = 0x00000000;
+  /* Reset PLL3DIVR register */
+  RCC->PLL3DIVR = 0x01010280;
+#else
   RCC->PLLCKSELR = 0x00000000;
@@ -202,7 +226,7 @@ void SystemInit (void)
   RCC->PLL3DIVR = 0x00000000;
+#endif
   /* Reset PLL3FRACR register */
   RCC->PLL3FRACR = 0x00000000;
@@ -222,25 +246,34 @@ void SystemInit (void)
 #endif
-#ifndef __rtems__
   /* in case of initialized data in D2 SRAM (AHB SRAM) , enable the D2 SRAM clock (AHB SRAM clock) */
 #if defined(RCC_AHB2ENR_D2SRAM3EN)
   RCC->AHB2ENR |= (RCC_AHB2ENR_D2SRAM1EN | RCC_AHB2ENR_D2SRAM2EN | RCC_AHB2ENR_D2SRAM3EN);
 #elif defined(RCC_AHB2ENR_D2SRAM2EN)
   RCC->AHB2ENR |= (RCC_AHB2ENR_D2SRAM1EN | RCC_AHB2ENR_D2SRAM2EN);
+#elif DATA_IN_CD_AHB_SRAM
+  /* in case of initialized data in CD AHB SRAM, enable the CD AHB SRAM clock */
+  RCC->AHB2ENR |= (RCC_AHB2ENR_AHBSRAM1EN | RCC_AHB2ENR_AHBSRAM2EN);
 #else
 #endif /* RCC_AHB2ENR_D2SRAM3EN */
+#endif /* DATA_IN_D2_SRAM */
+#ifndef __rtems__
   tmpreg = RCC->AHB2ENR;
   (void) tmpreg;
 #else /* __rtems__ */
-  RCC->AHB2ENR |= (RCC_AHB2ENR_D2SRAM1EN | RCC_AHB2ENR_D2SRAM2EN | RCC_AHB2ENR_D2SRAM3EN);
   RCC->AHB2ENR;
+   * Disable the FMC bank1 (enabled after reset).
+   * This, prevents CPU speculation access on this bank which blocks the use of FMC during
+   * 24us. During this time the others FMC master (such as LTDC) cannot use it!
+  FMC_Bank1_R->BTCR[0] = 0x000030D2;
+#endif
 #ifndef __rtems__
 #if defined(DUAL_CORE) && defined(CORE_CM4)
   /* Configure the Vector Table location add offset address for cortex-M4 ------------------*/
@@ -254,7 +287,11 @@ void SystemInit (void)
   /* Configure the Vector Table location add offset address for cortex-M7 ------------------*/
 #ifdef VECT_TAB_SRAM
+  SCB->VTOR = CD_AXISRAM1_BASE  | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal CD AXI-RAM */
+#else
   SCB->VTOR = D1_AXISRAM_BASE  | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal AXI-RAM */
+#endif
 #else
   SCB->VTOR = FLASH_BANK1_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal FLASH */
 #endif
2.25.1
