[PATCH 5/8] testsuites/libtests/[d-o]*: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Tue Apr 5 18:51:59 UTC 2022
Updates #3053.
testsuites/libtests/debugger01/init.c | 25 ++++++++++++++++---
testsuites/libtests/debugger01/remote.c | 25 ++++++++++++++++---
testsuites/libtests/debugger01/system.h | 25 ++++++++++++++++---
testsuites/libtests/defaultconfig01/init.c | 25 ++++++++++++++++---
testsuites/libtests/devfs04/init.c | 25 ++++++++++++++++---
testsuites/libtests/devfs04/test_driver.c | 25 ++++++++++++++++---
testsuites/libtests/devfs04/test_driver.h | 25 ++++++++++++++++---
testsuites/libtests/deviceio01/init.c | 25 ++++++++++++++++---
testsuites/libtests/deviceio01/test_driver.c | 25 ++++++++++++++++---
testsuites/libtests/deviceio01/test_driver.h | 25 ++++++++++++++++---
testsuites/libtests/devnullfatal01/init.c | 25 ++++++++++++++++---
testsuites/libtests/dumpbuf01/init.c | 25 ++++++++++++++++---
testsuites/libtests/exit01/init.c | 25 ++++++++++++++++---
testsuites/libtests/exit02/init.c | 25 ++++++++++++++++---
testsuites/libtests/flashdisk01/init.c | 25 ++++++++++++++++---
.../libtests/flashdisk01/test-file-system.c | 25 ++++++++++++++++---
.../libtests/flashdisk01/test-file-system.h | 25 ++++++++++++++++---
testsuites/libtests/getentropy01/init.c | 25 ++++++++++++++++---
testsuites/libtests/heapwalk/init.c | 25 ++++++++++++++++---
testsuites/libtests/heapwalk/system.h | 25 ++++++++++++++++---
testsuites/libtests/i2c01/init.c | 25 ++++++++++++++++---
testsuites/libtests/libfdt01/init.c | 25 ++++++++++++++++---
testsuites/libtests/malloc02/init.c | 25 ++++++++++++++++---
testsuites/libtests/malloc03/init.c | 25 ++++++++++++++++---
testsuites/libtests/malloc04/init.c | 25 ++++++++++++++++---
testsuites/libtests/malloctest/init.c | 25 ++++++++++++++++---
testsuites/libtests/malloctest/system.h | 25 ++++++++++++++++---
testsuites/libtests/malloctest/task1.c | 25 ++++++++++++++++---
testsuites/libtests/math/init.c | 25 ++++++++++++++++---
testsuites/libtests/mathf/init.c | 25 ++++++++++++++++---
testsuites/libtests/mathl/init.c | 25 ++++++++++++++++---
testsuites/libtests/md501/init.c | 25 ++++++++++++++++---
testsuites/libtests/monitor/init.c | 25 ++++++++++++++++---
testsuites/libtests/monitor/system.h | 25 ++++++++++++++++---
testsuites/libtests/monitor02/init.c | 25 ++++++++++++++++---
testsuites/libtests/monitor02/system.h | 25 ++++++++++++++++---
testsuites/libtests/mouse01/init.c | 25 ++++++++++++++++---
testsuites/libtests/mouse01/msmouse.c | 25 ++++++++++++++++---
testsuites/libtests/newlib01/init.c | 25 ++++++++++++++++---
39 files changed, 858 insertions(+), 117 deletions(-)
diff --git a/testsuites/libtests/debugger01/init.c b/testsuites/libtests/debugger01/init.c
index 9fb85007de..7a4eecd965 100644
--- a/testsuites/libtests/debugger01/init.c
+++ b/testsuites/libtests/debugger01/init.c
@@ -1,11 +1,30 @@
* Debugger test.
* Copyright (c) 2016 Chris Johns (chrisj at rtems.org)
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#ifdef HAVE_CONFIG_H
diff --git a/testsuites/libtests/debugger01/remote.c b/testsuites/libtests/debugger01/remote.c
index 3b302284a8..f69442d8c1 100644
--- a/testsuites/libtests/debugger01/remote.c
+++ b/testsuites/libtests/debugger01/remote.c
@@ -1,11 +1,30 @@
* Debugger test remote.
+ * are met:
diff --git a/testsuites/libtests/debugger01/system.h b/testsuites/libtests/debugger01/system.h
index 5ec19652f3..0ed05cd216 100644
--- a/testsuites/libtests/debugger01/system.h
+++ b/testsuites/libtests/debugger01/system.h
@@ -1,3 +1,5 @@
/* system.h
* This include file contains information that is included in every
@@ -6,9 +8,26 @@
* COPYRIGHT (c) 1989-1999.
* On-Line Applications Research Corporation (OAR).
+ * are met:
#include <bsp.h>
diff --git a/testsuites/libtests/defaultconfig01/init.c b/testsuites/libtests/defaultconfig01/init.c
index d80c1d1c49..1a5451fb09 100644
--- a/testsuites/libtests/defaultconfig01/init.c
+++ b/testsuites/libtests/defaultconfig01/init.c
@@ -1,9 +1,28 @@
* Copyright (c) 2014 embedded brains GmbH. All rights reserved.
+ * are met:
diff --git a/testsuites/libtests/devfs04/init.c b/testsuites/libtests/devfs04/init.c
index a7549abdad..ca5269dcdd 100644
--- a/testsuites/libtests/devfs04/init.c
+++ b/testsuites/libtests/devfs04/init.c
@@ -1,10 +1,29 @@
* COPYRIGHT (c) 1989-2012.
+ * are met:
diff --git a/testsuites/libtests/devfs04/test_driver.c b/testsuites/libtests/devfs04/test_driver.c
index bd4b40af9a..b3a8339d83 100644
--- a/testsuites/libtests/devfs04/test_driver.c
+++ b/testsuites/libtests/devfs04/test_driver.c
@@ -1,11 +1,30 @@
/* test_driver
* COPYRIGHT (c) 1989-2010.
+ * are met:
diff --git a/testsuites/libtests/devfs04/test_driver.h b/testsuites/libtests/devfs04/test_driver.h
index 245ac47a3c..aad3174b76 100644
--- a/testsuites/libtests/devfs04/test_driver.h
+++ b/testsuites/libtests/devfs04/test_driver.h
@@ -1,11 +1,30 @@
/* test_driver.h
+ * are met:
#ifndef __TEST_DRIVER_h
diff --git a/testsuites/libtests/deviceio01/init.c b/testsuites/libtests/deviceio01/init.c
index c27e345be5..009de219f3 100644
--- a/testsuites/libtests/deviceio01/init.c
+++ b/testsuites/libtests/deviceio01/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/libtests/deviceio01/test_driver.c b/testsuites/libtests/deviceio01/test_driver.c
index 0f80a27ef5..c56b40d63f 100644
--- a/testsuites/libtests/deviceio01/test_driver.c
+++ b/testsuites/libtests/deviceio01/test_driver.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/libtests/deviceio01/test_driver.h b/testsuites/libtests/deviceio01/test_driver.h
index d6409d2f32..1fd24b1679 100644
--- a/testsuites/libtests/deviceio01/test_driver.h
+++ b/testsuites/libtests/deviceio01/test_driver.h
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/libtests/devnullfatal01/init.c b/testsuites/libtests/devnullfatal01/init.c
index ecf63cfe51..2c7b9c0b4d 100644
--- a/testsuites/libtests/devnullfatal01/init.c
+++ b/testsuites/libtests/devnullfatal01/init.c
@@ -1,3 +1,5 @@
#include "config.h"
#endif
@@ -8,9 +10,26 @@
* COPYRIGHT (c) 1989-2010, 2017.
+ * are met:
#define FATAL_ERROR_TEST_NAME "/DEV/NULL 1"
diff --git a/testsuites/libtests/dumpbuf01/init.c b/testsuites/libtests/dumpbuf01/init.c
index 45cf0c2f5a..e103990176 100644
--- a/testsuites/libtests/dumpbuf01/init.c
+++ b/testsuites/libtests/dumpbuf01/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/libtests/exit01/init.c b/testsuites/libtests/exit01/init.c
index 219cf10398..df4beb15c3 100644
--- a/testsuites/libtests/exit01/init.c
+++ b/testsuites/libtests/exit01/init.c
@@ -1,9 +1,28 @@
* Copyright (c) 2013 embedded brains GmbH. All rights reserved.
+ * are met:
diff --git a/testsuites/libtests/exit02/init.c b/testsuites/libtests/exit02/init.c
index 9b05af09eb..652464ab9b 100644
--- a/testsuites/libtests/exit02/init.c
+++ b/testsuites/libtests/exit02/init.c
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/testsuites/libtests/flashdisk01/init.c b/testsuites/libtests/flashdisk01/init.c
index e469be80a3..0caeb4e181 100644
--- a/testsuites/libtests/flashdisk01/init.c
+++ b/testsuites/libtests/flashdisk01/init.c
@@ -1,9 +1,28 @@
* Copyright (c) 2012 embedded brains GmbH. All rights reserved.
+ * are met:
diff --git a/testsuites/libtests/flashdisk01/test-file-system.c b/testsuites/libtests/flashdisk01/test-file-system.c
index 9d346edefb..66b18de273 100644
--- a/testsuites/libtests/flashdisk01/test-file-system.c
+++ b/testsuites/libtests/flashdisk01/test-file-system.c
@@ -1,9 +1,28 @@
* Copyright (c) 2010-2012 embedded brains GmbH. All rights reserved.
+ * are met:
#include "test-file-system.h"
diff --git a/testsuites/libtests/flashdisk01/test-file-system.h b/testsuites/libtests/flashdisk01/test-file-system.h
index e7b04034f0..5bb5064246 100644
--- a/testsuites/libtests/flashdisk01/test-file-system.h
+++ b/testsuites/libtests/flashdisk01/test-file-system.h
@@ -1,9 +1,28 @@
+ * are met:
#ifndef TEST_FILE_SYSTEM_H
diff --git a/testsuites/libtests/getentropy01/init.c b/testsuites/libtests/getentropy01/init.c
index 88c932b318..12f9741665 100644
--- a/testsuites/libtests/getentropy01/init.c
+++ b/testsuites/libtests/getentropy01/init.c
@@ -1,9 +1,28 @@
* Copyright (c) 2017 embedded brains GmbH. All rights reserved.
+ * are met:
diff --git a/testsuites/libtests/heapwalk/init.c b/testsuites/libtests/heapwalk/init.c
index cd5caaa852..d7f0302b0f 100644
--- a/testsuites/libtests/heapwalk/init.c
+++ b/testsuites/libtests/heapwalk/init.c
@@ -1,3 +1,5 @@
* Test of Heap Walker
@@ -6,9 +8,26 @@
* Copyright (c) 2009 embedded brains GmbH.
+ * are met:
diff --git a/testsuites/libtests/heapwalk/system.h b/testsuites/libtests/heapwalk/system.h
index 53a13fc1d6..adf3f4a678 100644
--- a/testsuites/libtests/heapwalk/system.h
+++ b/testsuites/libtests/heapwalk/system.h
@@ -1,3 +1,5 @@
/* system.h
@@ -6,9 +8,26 @@
+ * are met:
#include <tmacros.h>
diff --git a/testsuites/libtests/i2c01/init.c b/testsuites/libtests/i2c01/init.c
index 873db1a9d5..b6480fb99e 100644
--- a/testsuites/libtests/i2c01/init.c
+++ b/testsuites/libtests/i2c01/init.c
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/testsuites/libtests/libfdt01/init.c b/testsuites/libtests/libfdt01/init.c
index 7879593379..80a8361339 100644
--- a/testsuites/libtests/libfdt01/init.c
+++ b/testsuites/libtests/libfdt01/init.c
@@ -1,9 +1,28 @@
* Copyright (c) 2015 embedded brains GmbH. All rights reserved.
+ * are met:
diff --git a/testsuites/libtests/malloc02/init.c b/testsuites/libtests/malloc02/init.c
index 6db32478e7..bce3c9b5a1 100644
--- a/testsuites/libtests/malloc02/init.c
+++ b/testsuites/libtests/malloc02/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/libtests/malloc03/init.c b/testsuites/libtests/malloc03/init.c
index 89c147b1b6..8ada7ba4b3 100644
--- a/testsuites/libtests/malloc03/init.c
+++ b/testsuites/libtests/malloc03/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/libtests/malloc04/init.c b/testsuites/libtests/malloc04/init.c
index 8f05c63a79..a9894d59fd 100644
--- a/testsuites/libtests/malloc04/init.c
+++ b/testsuites/libtests/malloc04/init.c
@@ -1,10 +1,29 @@
* COPYRIGHT (c) 1989-2011.
+ * are met:
diff --git a/testsuites/libtests/malloctest/init.c b/testsuites/libtests/malloctest/init.c
index a33764177d..7d03a2deab 100644
--- a/testsuites/libtests/malloctest/init.c
+++ b/testsuites/libtests/malloctest/init.c
@@ -1,12 +1,31 @@
* COPYRIGHT (c) 1989-2011, 2014.
* Copyright (c) 2009, 2016 embedded brains GmbH.
+ * are met:
diff --git a/testsuites/libtests/malloctest/system.h b/testsuites/libtests/malloctest/system.h
--- a/testsuites/libtests/malloctest/system.h
+++ b/testsuites/libtests/malloctest/system.h
@@ -1,3 +1,5 @@
/* system.h
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/libtests/malloctest/task1.c b/testsuites/libtests/malloctest/task1.c
index 4f0309af5a..4feb338b87 100644
--- a/testsuites/libtests/malloctest/task1.c
+++ b/testsuites/libtests/malloctest/task1.c
@@ -1,3 +1,5 @@
/* task1.c
* This set of three tasks do some simple task switching for about
@@ -6,9 +8,26 @@
* COPYRIGHT (c) 1989-2009.
+ * are met:
diff --git a/testsuites/libtests/math/init.c b/testsuites/libtests/math/init.c
index a5f6802b00..3fedb5546a 100644
--- a/testsuites/libtests/math/init.c
+++ b/testsuites/libtests/math/init.c
@@ -1,3 +1,5 @@
/* Init
* This routine is the initialization task for this test program.
@@ -13,9 +15,26 @@
+ * are met:
diff --git a/testsuites/libtests/mathf/init.c b/testsuites/libtests/mathf/init.c
index 143ac63f1a..d63509dbc3 100644
--- a/testsuites/libtests/mathf/init.c
+++ b/testsuites/libtests/mathf/init.c
@@ -1,3 +1,5 @@
/* Init
@@ -13,9 +15,26 @@
+ * are met:
diff --git a/testsuites/libtests/mathl/init.c b/testsuites/libtests/mathl/init.c
index fb390bb2c2..2605fdb8e3 100644
--- a/testsuites/libtests/mathl/init.c
+++ b/testsuites/libtests/mathl/init.c
@@ -1,3 +1,5 @@
/* Init
@@ -13,9 +15,26 @@
+ * are met:
diff --git a/testsuites/libtests/md501/init.c b/testsuites/libtests/md501/init.c
index 12100b3d39..00941acd85 100644
--- a/testsuites/libtests/md501/init.c
+++ b/testsuites/libtests/md501/init.c
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/testsuites/libtests/monitor/init.c b/testsuites/libtests/monitor/init.c
index 6fe78a144f..fcdea9d144 100644
--- a/testsuites/libtests/monitor/init.c
+++ b/testsuites/libtests/monitor/init.c
@@ -1,3 +1,5 @@
* This is a simple test whose only purpose is to start the Monitor
* task. The Monitor task can be used to obtain information about
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/libtests/monitor/system.h b/testsuites/libtests/monitor/system.h
index 7e23bd2d40..dc9224731a 100644
--- a/testsuites/libtests/monitor/system.h
+++ b/testsuites/libtests/monitor/system.h
@@ -1,3 +1,5 @@
/* system.h
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/libtests/monitor02/init.c b/testsuites/libtests/monitor02/init.c
index 22818cc441..d5e5d930a1 100644
--- a/testsuites/libtests/monitor02/init.c
+++ b/testsuites/libtests/monitor02/init.c
@@ -1,3 +1,5 @@
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/libtests/monitor02/system.h b/testsuites/libtests/monitor02/system.h
index 3d05473c57..f16167eb22 100644
--- a/testsuites/libtests/monitor02/system.h
+++ b/testsuites/libtests/monitor02/system.h
@@ -1,3 +1,5 @@
/* system.h
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/libtests/mouse01/init.c b/testsuites/libtests/mouse01/init.c
index 5f9ed18161..a26fa6e2e3 100644
--- a/testsuites/libtests/mouse01/init.c
+++ b/testsuites/libtests/mouse01/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/libtests/mouse01/msmouse.c b/testsuites/libtests/mouse01/msmouse.c
index 838cbcf084..82701c0956 100644
--- a/testsuites/libtests/mouse01/msmouse.c
+++ b/testsuites/libtests/mouse01/msmouse.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/libtests/newlib01/init.c b/testsuites/libtests/newlib01/init.c
index d0a8d16a48..8975a72fad 100644
--- a/testsuites/libtests/newlib01/init.c
+++ b/testsuites/libtests/newlib01/init.c
@@ -1,9 +1,28 @@
* Copyright (c) 2014, 2022 embedded brains GmbH. All rights reserved.
+ * are met:
2.24.4
