[PATCH 6/8] testsuites/libtests/[p-z]*: Change license to BSD-2
Tue Apr 5 18:52:00 UTC 2022
Updates #3053.
 testsuites/libtests/putenvtest/init.c         | 25 ++++++++++++++++---
 testsuites/libtests/pwdgrp01/init.c           | 25 ++++++++++++++++---
 testsuites/libtests/pwdgrp02/init.c           | 25 ++++++++++++++++---
 testsuites/libtests/rbheap01/init.c           | 25 ++++++++++++++++---
 testsuites/libtests/rtmonuse/getall.c         | 25 ++++++++++++++++---
 testsuites/libtests/rtmonuse/init.c           | 25 ++++++++++++++++---
 testsuites/libtests/rtmonuse/system.h         | 25 ++++++++++++++++---
 testsuites/libtests/rtmonuse/task1.c          | 25 ++++++++++++++++---
 testsuites/libtests/sha/init.c                | 25 ++++++++++++++++---
 testsuites/libtests/shell01/init.c            | 25 ++++++++++++++++---
 testsuites/libtests/sparsedisk01/init.c       | 25 ++++++++++++++++---
 testsuites/libtests/spi01/init.c              | 25 ++++++++++++++++---
 testsuites/libtests/stackchk/blow.c           | 25 ++++++++++++++++---
 testsuites/libtests/stackchk/init.c           | 25 ++++++++++++++++---
 testsuites/libtests/stackchk/system.h         | 25 ++++++++++++++++---
 testsuites/libtests/stackchk/task1.c          | 25 ++++++++++++++++---
 testsuites/libtests/stackchk01/init.c         | 25 ++++++++++++++++---
 testsuites/libtests/stringto01/init.c         | 25 ++++++++++++++++---
 .../stringto01/stringto_test_template.h       | 25 ++++++++++++++++---
 testsuites/libtests/tar01/init.c              | 25 ++++++++++++++++---
 testsuites/libtests/tar02/init.c              | 25 ++++++++++++++++---
 testsuites/libtests/tar03/init.c              | 25 ++++++++++++++++---
 testsuites/libtests/termios01/init.c          | 25 ++++++++++++++++---
 .../libtests/termios01/termios_testdriver.c   | 25 ++++++++++++++++---
 .../libtests/termios01/termios_testdriver.h   | 25 ++++++++++++++++---
 testsuites/libtests/termios02/init.c          | 25 ++++++++++++++++---
 testsuites/libtests/termios03/init.c          | 25 ++++++++++++++++---
 .../termios03/termios_testdriver_polled.c     | 25 ++++++++++++++++---
 .../termios03/termios_testdriver_polled.h     | 25 ++++++++++++++++---
 testsuites/libtests/termios04/init.c          | 25 ++++++++++++++++---
 .../termios04/termios_testdriver_impl.h       | 25 ++++++++++++++++---
 .../termios04/termios_testdriver_intr.h       | 25 ++++++++++++++++---
 testsuites/libtests/termios05/init.c          | 25 ++++++++++++++++---
 testsuites/libtests/termios06/init.c          | 25 ++++++++++++++++---
 testsuites/libtests/termios06/test_pppd.c     | 25 ++++++++++++++++---
 testsuites/libtests/termios07/init.c          | 25 ++++++++++++++++---
 testsuites/libtests/termios08/init.c          | 25 ++++++++++++++++---
 testsuites/libtests/termios09/init.c          | 25 ++++++++++++++++---
 testsuites/libtests/top/init.c                | 25 ++++++++++++++++---
 testsuites/libtests/top/system.h              | 25 ++++++++++++++++---
 testsuites/libtests/top/task1.c               | 25 ++++++++++++++++---
 testsuites/libtests/top/task2.c               | 25 ++++++++++++++++---
 testsuites/libtests/top/task3.c               | 25 ++++++++++++++++---
 testsuites/libtests/tztest/init.c             | 25 ++++++++++++++++---
 testsuites/libtests/utf8proc01/init.c         | 25 ++++++++++++++++---
 45 files changed, 990 insertions(+), 135 deletions(-)
diff --git a/testsuites/libtests/putenvtest/init.c b/testsuites/libtests/putenvtest/init.c
index 74cd8de1a8..748b023908 100644
--- a/testsuites/libtests/putenvtest/init.c
+++ b/testsuites/libtests/putenvtest/init.c
@@ -1,3 +1,5 @@
 /*  Init
  *  This routine is the initialization task for this test program.
@@ -14,9 +16,26 @@
  *  COPYRIGHT (c) 1989-1999.
  *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
 #ifdef HAVE_CONFIG_H
diff --git a/testsuites/libtests/pwdgrp01/init.c b/testsuites/libtests/pwdgrp01/init.c
index a6d22f7d93..3420c8eafa 100644
--- a/testsuites/libtests/pwdgrp01/init.c
+++ b/testsuites/libtests/pwdgrp01/init.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
+ * are met:
diff --git a/testsuites/libtests/pwdgrp02/init.c b/testsuites/libtests/pwdgrp02/init.c
index a0789c0e0c..8a67ec1f53 100644
--- a/testsuites/libtests/pwdgrp02/init.c
+++ b/testsuites/libtests/pwdgrp02/init.c
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/testsuites/libtests/rbheap01/init.c b/testsuites/libtests/rbheap01/init.c
index 0eb5d240b3..34e7aacbb5 100644
--- a/testsuites/libtests/rbheap01/init.c
+++ b/testsuites/libtests/rbheap01/init.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2012-2015 embedded brains GmbH.  All rights reserved.
+ * are met:
diff --git a/testsuites/libtests/rtmonuse/getall.c b/testsuites/libtests/rtmonuse/getall.c
index e9272f7b53..1965bd7c28 100644
--- a/testsuites/libtests/rtmonuse/getall.c
+++ b/testsuites/libtests/rtmonuse/getall.c
@@ -1,3 +1,5 @@
 /*  Get_all_counters
  *  This routine allows TA5 to atomically obtain the iteration counters.
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/testsuites/libtests/rtmonuse/init.c b/testsuites/libtests/rtmonuse/init.c
index a3f2ee10ca..bf7315e0d3 100644
--- a/testsuites/libtests/rtmonuse/init.c
+++ b/testsuites/libtests/rtmonuse/init.c
@@ -1,3 +1,5 @@
 /*  Init
@@ -14,9 +16,26 @@
  *  COPYRIGHT (c) 1989-2007.
+ * are met:
diff --git a/testsuites/libtests/rtmonuse/system.h b/testsuites/libtests/rtmonuse/system.h
index 7f344a47e3..a83a2a3a0d 100644
--- a/testsuites/libtests/rtmonuse/system.h
+++ b/testsuites/libtests/rtmonuse/system.h
@@ -1,3 +1,5 @@
 /*  system.h
  *  This include file contains information that is included in every
@@ -6,9 +8,26 @@
+ * are met:
 #include <tmacros.h>
diff --git a/testsuites/libtests/rtmonuse/task1.c b/testsuites/libtests/rtmonuse/task1.c
index b0db7fe4be..2d4baeb625 100644
--- a/testsuites/libtests/rtmonuse/task1.c
+++ b/testsuites/libtests/rtmonuse/task1.c
@@ -1,3 +1,5 @@
 /*  Task_1_through_5
  *  This routine serves as a test task for the period capabilities of the
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/libtests/sha/init.c b/testsuites/libtests/sha/init.c
index 79e53d0269..c65517253a 100644
--- a/testsuites/libtests/sha/init.c
+++ b/testsuites/libtests/sha/init.c
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/testsuites/libtests/shell01/init.c b/testsuites/libtests/shell01/init.c
index e5315757e4..0fc29b8936 100644
--- a/testsuites/libtests/shell01/init.c
+++ b/testsuites/libtests/shell01/init.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2014, 2019 embedded brains GmbH.  All rights reserved.
+ * are met:
diff --git a/testsuites/libtests/sparsedisk01/init.c b/testsuites/libtests/sparsedisk01/init.c
index 97a94f5697..c756daa188 100644
--- a/testsuites/libtests/sparsedisk01/init.c
+++ b/testsuites/libtests/sparsedisk01/init.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2012 embedded brains GmbH.  All rights reserved.
+ * are met:
diff --git a/testsuites/libtests/spi01/init.c b/testsuites/libtests/spi01/init.c
index 6837402f70..aeabdc04d0 100644
--- a/testsuites/libtests/spi01/init.c
+++ b/testsuites/libtests/spi01/init.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2016 embedded brains GmbH.  All rights reserved.
+ * are met:
diff --git a/testsuites/libtests/stackchk/blow.c b/testsuites/libtests/stackchk/blow.c
index 3b8bb7842f..e394d7233d 100644
--- a/testsuites/libtests/stackchk/blow.c
+++ b/testsuites/libtests/stackchk/blow.c
@@ -1,3 +1,5 @@
 /*  task1.c
  *  This set of three tasks do some simple task switching for about
@@ -6,9 +8,26 @@
  *  COPYRIGHT (c) 1989-2012.
+ * are met:
diff --git a/testsuites/libtests/stackchk/init.c b/testsuites/libtests/stackchk/init.c
index da22a7ab50..b6f57f80fe 100644
--- a/testsuites/libtests/stackchk/init.c
+++ b/testsuites/libtests/stackchk/init.c
@@ -1,3 +1,5 @@
 /*  Init
@@ -14,9 +16,26 @@
+ * are met:
diff --git a/testsuites/libtests/stackchk/system.h b/testsuites/libtests/stackchk/system.h
index cdadb78c69..8f984e07d1 100644
--- a/testsuites/libtests/stackchk/system.h
+++ b/testsuites/libtests/stackchk/system.h
@@ -1,3 +1,5 @@
 /*  system.h
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/libtests/stackchk/task1.c b/testsuites/libtests/stackchk/task1.c
index 4e08d20819..8c495c3f69 100644
--- a/testsuites/libtests/stackchk/task1.c
+++ b/testsuites/libtests/stackchk/task1.c
@@ -1,3 +1,5 @@
 /*  task1.c
@@ -6,9 +8,26 @@
  *  COPYRIGHT (c) 1989-2009.
+ * are met:
diff --git a/testsuites/libtests/stackchk01/init.c b/testsuites/libtests/stackchk01/init.c
index 8e907e6d48..9e58409b17 100644
--- a/testsuites/libtests/stackchk01/init.c
+++ b/testsuites/libtests/stackchk01/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/libtests/stringto01/init.c b/testsuites/libtests/stringto01/init.c
index 02a9360604..594ba3f08d 100644
--- a/testsuites/libtests/stringto01/init.c
+++ b/testsuites/libtests/stringto01/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/libtests/stringto01/stringto_test_template.h b/testsuites/libtests/stringto01/stringto_test_template.h
index 1309b4bda4..44e6c5cff1 100644
--- a/testsuites/libtests/stringto01/stringto_test_template.h
+++ b/testsuites/libtests/stringto01/stringto_test_template.h
@@ -1,10 +1,29 @@
+ * are met:
 #if defined(STRING_TO_POINTER)
diff --git a/testsuites/libtests/tar01/init.c b/testsuites/libtests/tar01/init.c
index 2deff3a482..00a723656a 100644
--- a/testsuites/libtests/tar01/init.c
+++ b/testsuites/libtests/tar01/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/libtests/tar02/init.c b/testsuites/libtests/tar02/init.c
index 809923719b..f25c78ece6 100644
--- a/testsuites/libtests/tar02/init.c
+++ b/testsuites/libtests/tar02/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/libtests/tar03/init.c b/testsuites/libtests/tar03/init.c
index 142cdecfdf..50aee936bc 100644
--- a/testsuites/libtests/tar03/init.c
+++ b/testsuites/libtests/tar03/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/libtests/termios01/init.c b/testsuites/libtests/termios01/init.c
index 09be07bbcc..13c28490e1 100644
--- a/testsuites/libtests/termios01/init.c
+++ b/testsuites/libtests/termios01/init.c
@@ -1,10 +1,29 @@
  *  COPYRIGHT (c) 1989-2010.
+ * are met:
diff --git a/testsuites/libtests/termios01/termios_testdriver.c b/testsuites/libtests/termios01/termios_testdriver.c
index bd5c7a12d2..d0a9534b52 100644
--- a/testsuites/libtests/termios01/termios_testdriver.c
+++ b/testsuites/libtests/termios01/termios_testdriver.c
@@ -1,3 +1,5 @@
  *  @file
@@ -8,9 +10,26 @@
+ * are met:
diff --git a/testsuites/libtests/termios01/termios_testdriver.h b/testsuites/libtests/termios01/termios_testdriver.h
index f7f1241e9d..ba26a0485c 100644
--- a/testsuites/libtests/termios01/termios_testdriver.h
+++ b/testsuites/libtests/termios01/termios_testdriver.h
@@ -1,3 +1,5 @@
  * @file termios_testdriver.h
@@ -6,9 +8,26 @@
+ * are met:
 #ifndef _TERMIOS_TESTDRIVER_H
diff --git a/testsuites/libtests/termios02/init.c b/testsuites/libtests/termios02/init.c
index fe16150513..06869bc4a5 100644
--- a/testsuites/libtests/termios02/init.c
+++ b/testsuites/libtests/termios02/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/libtests/termios03/init.c b/testsuites/libtests/termios03/init.c
index 6f602f4df9..5600d2584a 100644
--- a/testsuites/libtests/termios03/init.c
+++ b/testsuites/libtests/termios03/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/libtests/termios03/termios_testdriver_polled.c b/testsuites/libtests/termios03/termios_testdriver_polled.c
index 676c3aacbd..a852fe1f20 100644
--- a/testsuites/libtests/termios03/termios_testdriver_polled.c
+++ b/testsuites/libtests/termios03/termios_testdriver_polled.c
@@ -1,3 +1,5 @@
  *  @file
@@ -8,9 +10,26 @@
+ * are met:
diff --git a/testsuites/libtests/termios03/termios_testdriver_polled.h b/testsuites/libtests/termios03/termios_testdriver_polled.h
index 6288a09a41..d804a2107f 100644
--- a/testsuites/libtests/termios03/termios_testdriver_polled.h
+++ b/testsuites/libtests/termios03/termios_testdriver_polled.h
@@ -1,3 +1,5 @@
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/libtests/termios04/init.c b/testsuites/libtests/termios04/init.c
index fe2adeb40d..4bee57def2 100644
--- a/testsuites/libtests/termios04/init.c
+++ b/testsuites/libtests/termios04/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/libtests/termios04/termios_testdriver_impl.h b/testsuites/libtests/termios04/termios_testdriver_impl.h
index 53764fb9da..cfe9ebedf4 100644
--- a/testsuites/libtests/termios04/termios_testdriver_impl.h
+++ b/testsuites/libtests/termios04/termios_testdriver_impl.h
@@ -1,3 +1,5 @@
  *  @file
@@ -8,9 +10,26 @@
+ * are met:
diff --git a/testsuites/libtests/termios04/termios_testdriver_intr.h b/testsuites/libtests/termios04/termios_testdriver_intr.h
index f4ebb59e53..f3f1815740 100644
--- a/testsuites/libtests/termios04/termios_testdriver_intr.h
+++ b/testsuites/libtests/termios04/termios_testdriver_intr.h
@@ -1,3 +1,5 @@
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/libtests/termios05/init.c b/testsuites/libtests/termios05/init.c
index 1cd5c7371d..8f40ed5007 100644
--- a/testsuites/libtests/termios05/init.c
+++ b/testsuites/libtests/termios05/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/libtests/termios06/init.c b/testsuites/libtests/termios06/init.c
index 5104d1b724..5705ecb35f 100644
--- a/testsuites/libtests/termios06/init.c
+++ b/testsuites/libtests/termios06/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/libtests/termios06/test_pppd.c b/testsuites/libtests/termios06/test_pppd.c
index d674e7b5e4..13b5fe2ee8 100644
--- a/testsuites/libtests/termios06/test_pppd.c
+++ b/testsuites/libtests/termios06/test_pppd.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/libtests/termios07/init.c b/testsuites/libtests/termios07/init.c
index 1dd5315126..53486912f4 100644
--- a/testsuites/libtests/termios07/init.c
+++ b/testsuites/libtests/termios07/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/libtests/termios08/init.c b/testsuites/libtests/termios08/init.c
index 4f237fb367..e3f5d236db 100644
--- a/testsuites/libtests/termios08/init.c
+++ b/testsuites/libtests/termios08/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/libtests/termios09/init.c b/testsuites/libtests/termios09/init.c
index dc785cf99a..3cb71fb267 100644
--- a/testsuites/libtests/termios09/init.c
+++ b/testsuites/libtests/termios09/init.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2017 embedded brains GmbH.  All rights reserved.
+ * are met:
diff --git a/testsuites/libtests/top/init.c b/testsuites/libtests/top/init.c
index 8a824ae194..34ce3e5291 100644
--- a/testsuites/libtests/top/init.c
+++ b/testsuites/libtests/top/init.c
@@ -1,3 +1,5 @@
  *  This test checks rtems_cpu_usage_top command with
  *  30 tasks being created and deleted.  The command
@@ -12,9 +14,26 @@
  *  COPYRIGHT (c) 2014.
+ * are met:
diff --git a/testsuites/libtests/top/system.h b/testsuites/libtests/top/system.h
index 945fbcabca..9abcf0d555 100644
--- a/testsuites/libtests/top/system.h
+++ b/testsuites/libtests/top/system.h
@@ -1,3 +1,5 @@
 /*  system.h
@@ -6,9 +8,26 @@
+ * are met:
 #include <bsp.h>
diff --git a/testsuites/libtests/top/task1.c b/testsuites/libtests/top/task1.c
index c9e62dffb6..8fcf23fc34 100644
--- a/testsuites/libtests/top/task1.c
+++ b/testsuites/libtests/top/task1.c
@@ -1,3 +1,5 @@
 /*  Task_1
  *  This test serves as a test task.  It creates and deletes
@@ -13,9 +15,26 @@
+ * are met:
diff --git a/testsuites/libtests/top/task2.c b/testsuites/libtests/top/task2.c
index 5435d5b66a..e4fbaff812 100644
--- a/testsuites/libtests/top/task2.c
+++ b/testsuites/libtests/top/task2.c
@@ -1,3 +1,5 @@
 /*  Task_2
  *  This routine serves as a test task.  It calls the
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/libtests/top/task3.c b/testsuites/libtests/top/task3.c
index 891351bad9..2a22a17b39 100644
--- a/testsuites/libtests/top/task3.c
+++ b/testsuites/libtests/top/task3.c
@@ -1,3 +1,5 @@
 /*  Task_3
  *  This routine serves as a test task.  It receives a task
@@ -12,9 +14,26 @@
+ * are met:
diff --git a/testsuites/libtests/tztest/init.c b/testsuites/libtests/tztest/init.c
index f3085078ed..c88472da04 100644
--- a/testsuites/libtests/tztest/init.c
+++ b/testsuites/libtests/tztest/init.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
  *  COPYRIGHT (c) 2007-2012.
+ * are met:
diff --git a/testsuites/libtests/utf8proc01/init.c b/testsuites/libtests/utf8proc01/init.c
index a8c805eb67..660459ae24 100644
--- a/testsuites/libtests/utf8proc01/init.c
+++ b/testsuites/libtests/utf8proc01/init.c
@@ -1,9 +1,28 @@
+ * are met:
2.24.4
