[PATCH 7/8] testsuites/fstests/*: Change license to BSD-2
Tue Apr 5 18:52:01 UTC 2022
Updates #3053.
 testsuites/fstests/fsbdpart01/init.c          | 25 ++++++++++++++++---
 testsuites/fstests/fsdosfsformat01/init.c     |  2 ++
 .../fsdosfsname01/image_bin_le_multibyte.h    | 25 ++++++++++++++++---
 .../fsdosfsname01/image_bin_le_singlebyte.h   | 25 ++++++++++++++++---
 testsuites/fstests/fsdosfsname01/init.c       | 25 ++++++++++++++++---
 testsuites/fstests/fsdosfsname02/init.c       | 25 ++++++++++++++++---
 testsuites/fstests/fsdosfssync01/init.c       | 25 ++++++++++++++++---
 testsuites/fstests/fsdosfswrite01/init.c      | 25 ++++++++++++++++---
 testsuites/fstests/fserror/test.c             | 25 ++++++++++++++++---
 testsuites/fstests/fsfseeko01/init.c          | 25 ++++++++++++++++---
 testsuites/fstests/fsimfsconfig01/init.c      | 25 ++++++++++++++++---
 testsuites/fstests/fsimfsconfig02/init.c      | 25 ++++++++++++++++---
 testsuites/fstests/fsimfsconfig03/init.c      | 25 ++++++++++++++++---
 testsuites/fstests/fsimfsgeneric01/init.c     | 25 ++++++++++++++++---
 testsuites/fstests/fsjffs2gc01/init.c         | 25 ++++++++++++++++---
 testsuites/fstests/fslink/test.c              | 25 ++++++++++++++++---
 testsuites/fstests/fsnofs01/init.c            | 25 ++++++++++++++++---
 testsuites/fstests/fspatheval/test.c          | 25 ++++++++++++++++---
 testsuites/fstests/fspermission/test.c        | 25 ++++++++++++++++---
 testsuites/fstests/fsrdwr/init.c              | 25 ++++++++++++++++---
 testsuites/fstests/fsrfsbitmap01/test.c       | 25 ++++++++++++++++---
 testsuites/fstests/fsrofs01/init.c            | 25 ++++++++++++++++---
 testsuites/fstests/fsscandir01/init.c         | 25 ++++++++++++++++---
 testsuites/fstests/fssymlink/test.c           | 25 ++++++++++++++++---
 testsuites/fstests/fstime/test.c              | 25 ++++++++++++++++---
 testsuites/fstests/imfs_support/fs_config.h   | 25 ++++++++++++++++---
 testsuites/fstests/imfs_support/fs_support.c  | 25 ++++++++++++++++---
 testsuites/fstests/jffs2_support/fs_config.h  | 25 ++++++++++++++++---
 testsuites/fstests/jffs2_support/fs_support.c | 25 ++++++++++++++++---
 testsuites/fstests/mdosfs_support/fs_config.h | 25 ++++++++++++++++---
 .../fstests/mdosfs_support/fs_support.c       | 25 ++++++++++++++++---
 testsuites/fstests/mimfs_support/fs_config.h  | 25 ++++++++++++++++---
 testsuites/fstests/mimfs_support/fs_support.c | 25 ++++++++++++++++---
 testsuites/fstests/mrfs_support/fs_config.h   | 25 ++++++++++++++++---
 testsuites/fstests/mrfs_support/fs_support.c  | 25 ++++++++++++++++---
 testsuites/fstests/support/fstest.h           | 25 ++++++++++++++++---
 testsuites/fstests/support/fstest_support.c   | 25 ++++++++++++++++---
 testsuites/fstests/support/fstest_support.h   | 25 ++++++++++++++++---
 testsuites/fstests/support/ramdisk_support.c  | 25 ++++++++++++++++---
 testsuites/fstests/support/ramdisk_support.h  | 25 ++++++++++++++++---
 40 files changed, 860 insertions(+), 117 deletions(-)
diff --git a/testsuites/fstests/fsbdpart01/init.c b/testsuites/fstests/fsbdpart01/init.c
index 6a4b96e812..1133e7b1c9 100644
--- a/testsuites/fstests/fsbdpart01/init.c
+++ b/testsuites/fstests/fsbdpart01/init.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2012 embedded brains GmbH.  All rights reserved.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
 #ifdef HAVE_CONFIG_H
diff --git a/testsuites/fstests/fsdosfsformat01/init.c b/testsuites/fstests/fsdosfsformat01/init.c
index 6784c2ff98..8f62960976 100644
--- a/testsuites/fstests/fsdosfsformat01/init.c
+++ b/testsuites/fstests/fsdosfsformat01/init.c
@@ -1,3 +1,5 @@
diff --git a/testsuites/fstests/fsdosfsname01/image_bin_le_multibyte.h b/testsuites/fstests/fsdosfsname01/image_bin_le_multibyte.h
index d0e070b064..7b9e931528 100644
--- a/testsuites/fstests/fsdosfsname01/image_bin_le_multibyte.h
+++ b/testsuites/fstests/fsdosfsname01/image_bin_le_multibyte.h
@@ -1,3 +1,5 @@
  * @file image_bin_le_multibyte.h
@@ -9,9 +11,26 @@
  * Copyright (c) 2013 embedded brains GmbH.  All rights reserved.
+ * are met:
diff --git a/testsuites/fstests/fsdosfsname01/image_bin_le_singlebyte.h b/testsuites/fstests/fsdosfsname01/image_bin_le_singlebyte.h
index 22d9229d17..0e089d7f6d 100644
--- a/testsuites/fstests/fsdosfsname01/image_bin_le_singlebyte.h
+++ b/testsuites/fstests/fsdosfsname01/image_bin_le_singlebyte.h
@@ -1,3 +1,5 @@
  * @file image_bin_le_singlebyte.h
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/testsuites/fstests/fsdosfsname01/init.c b/testsuites/fstests/fsdosfsname01/init.c
index 7abf4d47ae..75854dee17 100644
--- a/testsuites/fstests/fsdosfsname01/init.c
+++ b/testsuites/fstests/fsdosfsname01/init.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2012, 2013 embedded brains GmbH.  All rights reserved.
+ * are met:
diff --git a/testsuites/fstests/fsdosfsname02/init.c b/testsuites/fstests/fsdosfsname02/init.c
index 30b2cf3ff2..9a8256c9a6 100644
--- a/testsuites/fstests/fsdosfsname02/init.c
+++ b/testsuites/fstests/fsdosfsname02/init.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2017 embedded brains GmbH.  All rights reserved.
+ * are met:
diff --git a/testsuites/fstests/fsdosfssync01/init.c b/testsuites/fstests/fsdosfssync01/init.c
index d851bf3b67..1fe8177fba 100644
--- a/testsuites/fstests/fsdosfssync01/init.c
+++ b/testsuites/fstests/fsdosfssync01/init.c
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/testsuites/fstests/fsdosfswrite01/init.c b/testsuites/fstests/fsdosfswrite01/init.c
index fb3832b508..54089835f7 100644
--- a/testsuites/fstests/fsdosfswrite01/init.c
+++ b/testsuites/fstests/fsdosfswrite01/init.c
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/testsuites/fstests/fserror/test.c b/testsuites/fstests/fserror/test.c
index cd31a18bb2..60b7b08584 100644
--- a/testsuites/fstests/fserror/test.c
+++ b/testsuites/fstests/fserror/test.c
@@ -1,10 +1,29 @@
  *  COPYRIGHT (c) 1989-2011.
  *  On-Line Applications Research Corporation (OAR).
+ * are met:
diff --git a/testsuites/fstests/fsfseeko01/init.c b/testsuites/fstests/fsfseeko01/init.c
index 8749ad2ff2..3aef821d39 100644
--- a/testsuites/fstests/fsfseeko01/init.c
+++ b/testsuites/fstests/fsfseeko01/init.c
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/testsuites/fstests/fsimfsconfig01/init.c b/testsuites/fstests/fsimfsconfig01/init.c
index c1531273fd..04acdd2b79 100644
--- a/testsuites/fstests/fsimfsconfig01/init.c
+++ b/testsuites/fstests/fsimfsconfig01/init.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2015 embedded brains GmbH.  All rights reserved.
+ * are met:
diff --git a/testsuites/fstests/fsimfsconfig02/init.c b/testsuites/fstests/fsimfsconfig02/init.c
index bbcd81c234..ce36292119 100644
--- a/testsuites/fstests/fsimfsconfig02/init.c
+++ b/testsuites/fstests/fsimfsconfig02/init.c
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/testsuites/fstests/fsimfsconfig03/init.c b/testsuites/fstests/fsimfsconfig03/init.c
index b89c6df874..d5a5485d1a 100644
--- a/testsuites/fstests/fsimfsconfig03/init.c
+++ b/testsuites/fstests/fsimfsconfig03/init.c
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/testsuites/fstests/fsimfsgeneric01/init.c b/testsuites/fstests/fsimfsgeneric01/init.c
index e553f36ce0..28c52bf12d 100644
--- a/testsuites/fstests/fsimfsgeneric01/init.c
+++ b/testsuites/fstests/fsimfsgeneric01/init.c
@@ -1,9 +1,28 @@
  * Copyright (C) 2012, 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
diff --git a/testsuites/fstests/fsjffs2gc01/init.c b/testsuites/fstests/fsjffs2gc01/init.c
index 81f09d018d..a72636927d 100644
--- a/testsuites/fstests/fsjffs2gc01/init.c
+++ b/testsuites/fstests/fsjffs2gc01/init.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2016 embedded brains GmbH.  All rights reserved.
+ * are met:
diff --git a/testsuites/fstests/fslink/test.c b/testsuites/fstests/fslink/test.c
index f92160bbcc..3eb09e8e08 100644
--- a/testsuites/fstests/fslink/test.c
+++ b/testsuites/fstests/fslink/test.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/fstests/fsnofs01/init.c b/testsuites/fstests/fsnofs01/init.c
index db8f1820d2..0d11fea284 100644
--- a/testsuites/fstests/fsnofs01/init.c
+++ b/testsuites/fstests/fsnofs01/init.c
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/testsuites/fstests/fspatheval/test.c b/testsuites/fstests/fspatheval/test.c
index 7938946abd..855af33cf1 100644
--- a/testsuites/fstests/fspatheval/test.c
+++ b/testsuites/fstests/fspatheval/test.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/fstests/fspermission/test.c b/testsuites/fstests/fspermission/test.c
index 53a83ed0fa..451389376b 100644
--- a/testsuites/fstests/fspermission/test.c
+++ b/testsuites/fstests/fspermission/test.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/fstests/fsrdwr/init.c b/testsuites/fstests/fsrdwr/init.c
index 02b88c9a76..aa7ccdb97f 100644
--- a/testsuites/fstests/fsrdwr/init.c
+++ b/testsuites/fstests/fsrdwr/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/fstests/fsrfsbitmap01/test.c b/testsuites/fstests/fsrfsbitmap01/test.c
index 1365a970b6..d6dddae96f 100644
--- a/testsuites/fstests/fsrfsbitmap01/test.c
+++ b/testsuites/fstests/fsrfsbitmap01/test.c
@@ -1,3 +1,5 @@
  *  Copyright (c) 2012.
  *  Krzysztof Miesowicz <krzysztof.miesowicz at gmail.com>
@@ -7,9 +9,26 @@
  *  and pasted here. Rest of this test was written by Krzysztof Miesowicz to
  *  completely cover rtems_rfs_bitmap_* symbols.
+ * are met:
diff --git a/testsuites/fstests/fsrofs01/init.c b/testsuites/fstests/fsrofs01/init.c
index f0bda2febc..5c4dd7e8db 100644
--- a/testsuites/fstests/fsrofs01/init.c
+++ b/testsuites/fstests/fsrofs01/init.c
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/testsuites/fstests/fsscandir01/init.c b/testsuites/fstests/fsscandir01/init.c
index d7fb43c26b..ce9c100bdf 100644
--- a/testsuites/fstests/fsscandir01/init.c
+++ b/testsuites/fstests/fsscandir01/init.c
@@ -1,10 +1,29 @@
  *  COPYRIGHT (c) 2015.
+ * are met:
diff --git a/testsuites/fstests/fssymlink/test.c b/testsuites/fstests/fssymlink/test.c
index 7e90ebca82..d408dcc238 100644
--- a/testsuites/fstests/fssymlink/test.c
+++ b/testsuites/fstests/fssymlink/test.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/fstests/fstime/test.c b/testsuites/fstests/fstime/test.c
index 5fa4193ae8..ab2c5d568b 100644
--- a/testsuites/fstests/fstime/test.c
+++ b/testsuites/fstests/fstime/test.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/fstests/imfs_support/fs_config.h b/testsuites/fstests/imfs_support/fs_config.h
index a25c2fcdad..6d37373584 100644
--- a/testsuites/fstests/imfs_support/fs_config.h
+++ b/testsuites/fstests/imfs_support/fs_config.h
@@ -1,10 +1,29 @@
+ * are met:
 #ifndef __IMFS_SUPPORT_h
 #define __IMFS_SUPPORT_h
diff --git a/testsuites/fstests/imfs_support/fs_support.c b/testsuites/fstests/imfs_support/fs_support.c
index db64fbf830..551f4401ab 100644
--- a/testsuites/fstests/imfs_support/fs_support.c
+++ b/testsuites/fstests/imfs_support/fs_support.c
@@ -1,10 +1,29 @@
+ * are met:
 #include "config.h"
diff --git a/testsuites/fstests/jffs2_support/fs_config.h b/testsuites/fstests/jffs2_support/fs_config.h
index 2d91bc88bf..8740898294 100644
--- a/testsuites/fstests/jffs2_support/fs_config.h
+++ b/testsuites/fstests/jffs2_support/fs_config.h
@@ -1,9 +1,28 @@
+ * are met:
 #ifndef __JFFS2_SUPPORT_h
diff --git a/testsuites/fstests/jffs2_support/fs_support.c b/testsuites/fstests/jffs2_support/fs_support.c
index 228d784cca..2aa04a27c6 100644
--- a/testsuites/fstests/jffs2_support/fs_support.c
+++ b/testsuites/fstests/jffs2_support/fs_support.c
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/testsuites/fstests/mdosfs_support/fs_config.h b/testsuites/fstests/mdosfs_support/fs_config.h
index 0c30627cbe..50b190e1b8 100644
--- a/testsuites/fstests/mdosfs_support/fs_config.h
+++ b/testsuites/fstests/mdosfs_support/fs_config.h
@@ -1,10 +1,29 @@
+ * are met:
 #ifndef __DOSFS_SUPPORT_h
diff --git a/testsuites/fstests/mdosfs_support/fs_support.c b/testsuites/fstests/mdosfs_support/fs_support.c
index a0b233b8d7..9ee0d2c196 100644
--- a/testsuites/fstests/mdosfs_support/fs_support.c
+++ b/testsuites/fstests/mdosfs_support/fs_support.c
@@ -1,10 +1,29 @@
+ * are met:
 #include "config.h"
diff --git a/testsuites/fstests/mimfs_support/fs_config.h b/testsuites/fstests/mimfs_support/fs_config.h
index 5b354cf7d4..2c60891df2 100644
--- a/testsuites/fstests/mimfs_support/fs_config.h
+++ b/testsuites/fstests/mimfs_support/fs_config.h
@@ -1,10 +1,29 @@
+ * are met:
 #ifndef __MIMFS_SUPPORT_h
diff --git a/testsuites/fstests/mimfs_support/fs_support.c b/testsuites/fstests/mimfs_support/fs_support.c
index 8ac430c06a..1b9cc8944b 100644
--- a/testsuites/fstests/mimfs_support/fs_support.c
+++ b/testsuites/fstests/mimfs_support/fs_support.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/fstests/mrfs_support/fs_config.h b/testsuites/fstests/mrfs_support/fs_config.h
index 2cba0a05cd..75e48952a7 100644
--- a/testsuites/fstests/mrfs_support/fs_config.h
+++ b/testsuites/fstests/mrfs_support/fs_config.h
@@ -1,10 +1,29 @@
+ * are met:
 #ifndef __RFS_SUPPORT_h
diff --git a/testsuites/fstests/mrfs_support/fs_support.c b/testsuites/fstests/mrfs_support/fs_support.c
index 6e8ef9fa29..3d4fa5b9ee 100644
--- a/testsuites/fstests/mrfs_support/fs_support.c
+++ b/testsuites/fstests/mrfs_support/fs_support.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/fstests/support/fstest.h b/testsuites/fstests/support/fstest.h
index 2cea2108b4..0f805359b3 100644
--- a/testsuites/fstests/support/fstest.h
+++ b/testsuites/fstests/support/fstest.h
@@ -1,10 +1,29 @@
+ * are met:
 #ifndef __FSTEST_H
diff --git a/testsuites/fstests/support/fstest_support.c b/testsuites/fstests/support/fstest_support.c
index fcf1ef86a8..f56a77b4b1 100644
--- a/testsuites/fstests/support/fstest_support.c
+++ b/testsuites/fstests/support/fstest_support.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/fstests/support/fstest_support.h b/testsuites/fstests/support/fstest_support.h
index 20cc633355..4562cbe7f7 100644
--- a/testsuites/fstests/support/fstest_support.h
+++ b/testsuites/fstests/support/fstest_support.h
@@ -1,10 +1,29 @@
+ * are met:
 #ifndef __FSTEST_SUPPORT_H
 #define __FSTEST_SUPPORT_H
diff --git a/testsuites/fstests/support/ramdisk_support.c b/testsuites/fstests/support/ramdisk_support.c
index 0a07495c02..419e3e1627 100644
--- a/testsuites/fstests/support/ramdisk_support.c
+++ b/testsuites/fstests/support/ramdisk_support.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/fstests/support/ramdisk_support.h b/testsuites/fstests/support/ramdisk_support.h
index 3c92d62a04..03c68b3024 100644
--- a/testsuites/fstests/support/ramdisk_support.h
+++ b/testsuites/fstests/support/ramdisk_support.h
@@ -1,10 +1,29 @@
+ * are met:
 #ifndef __RAMDISK_SUPPORT_H
 #define __RAMDISK_SUPPORT_H
2.24.4
