[PATCH 5/6] shell: Move rtems_shell_init_environment() call
Sebastian Huber
Wed Apr 6 07:17:31 UTC 2022
Move rtems_shell_init_environment() call to rtems_shell_set_shell_env()
since this function uses the POSIX key.
cpukit/libmisc/shell/shell.c | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/cpukit/libmisc/shell/shell.c b/cpukit/libmisc/shell/shell.c
index 9bb143dd29..01336f0a78 100644
--- a/cpukit/libmisc/shell/shell.c
+++ b/cpukit/libmisc/shell/shell.c
@@ -200,6 +200,8 @@ static bool rtems_shell_set_shell_env(
rtems_shell_env_key_handle *handle;
int eno;
+ rtems_shell_init_environment();
handle = malloc(sizeof(rtems_shell_env_key_handle));
if (handle == NULL) {
rtems_error(0, "no memory for shell env key handle)");
@@ -1020,8 +1022,6 @@ bool rtems_shell_main_loop(
FILE *stdoutToClose = NULL;
FILE *line_editor_output;
- rtems_shell_init_environment();
if (shell_env->magic != SHELL_MAGIC) {
rtems_error(0, "invalid shell environment passed to the main loop)");
return false;
2.34.1
