[PATCH] bsp/stm32h7: update FMC configuration for SRAM and SDRAM usage
Karel Gardas
karel at functional.vision
Wed Apr 6 12:13:32 UTC 2022
The patch merges differences in FMC configuration between system_stm32h7xx.c
file generated by STM32CubeIDE for 743i-eval2 board and the current RTEMS
ext-mem-ctl.c file.
Sponsored-By: Precidata
bsps/arm/stm32h7/start/ext-mem-ctl.c | 23 ++++++++++++++---------
1 file changed, 14 insertions(+), 9 deletions(-)
diff --git a/bsps/arm/stm32h7/start/ext-mem-ctl.c b/bsps/arm/stm32h7/start/ext-mem-ctl.c
index 5b92244533..a2ab9d8f1f 100644
--- a/bsps/arm/stm32h7/start/ext-mem-ctl.c
+++ b/bsps/arm/stm32h7/start/ext-mem-ctl.c
@@ -66,8 +66,8 @@ void SystemInit_ExtMemCtl(void)
GPIOD->AFR[1] = 0xCCCCCCCC;
/* Configure PDx pins in Alternate function mode */
GPIOD->MODER = 0xAAAAFAFA;
- /* Configure PDx pins speed to VERY_HIGH */
- GPIOD->OSPEEDR = 0xFFFFFF0F;
+ /* Configure PDx pins speed to 100 MHz */
+ GPIOD->OSPEEDR = 0xFFFF0F0F;
/* Configure PDx pins Output type to push-pull */
GPIOD->OTYPER = 0x00000000;
/* Configure PDx pins in Pull-up */
@@ -78,8 +78,8 @@ void SystemInit_ExtMemCtl(void)
GPIOE->AFR[1] = 0xCCCCCCCC;
/* Configure PEx pins in Alternate function mode */
GPIOE->MODER = 0xAAAABEBA;
- /* Configure PEx pins speed to VERY_HIGH */
- GPIOE->OSPEEDR = 0xFFFFFFFF;
+ /* Configure PEx pins speed to 100 MHz */
+ GPIOE->OSPEEDR = 0xFFFFC3CF;
/* Configure PEx pins Output type to push-pull */
GPIOE->OTYPER = 0x00000000;
/* Configure PEx pins in Pull-up */
@@ -90,7 +90,7 @@ void SystemInit_ExtMemCtl(void)
GPIOF->AFR[1] = 0xCCCCC000;
/* Configure PFx pins in Alternate function mode */
GPIOF->MODER = 0xAABFFAAA;
- /* Configure PFx pins speed to VERY_HIGH */
+ /* Configure PFx pins speed to 100 MHz */
GPIOF->OSPEEDR = 0xFFC00FFF;
/* Configure PFx pins Output type to push-pull */
GPIOF->OTYPER = 0x00000000;
@@ -102,7 +102,7 @@ void SystemInit_ExtMemCtl(void)
GPIOG->AFR[1] = 0xC0000C0C;
/* Configure PGx pins in Alternate function mode */
GPIOG->MODER = 0xBFEEFAAA;
- /* Configure PGx pins speed to VERY_HIGH */
+ /* Configure PGx pins speed to 100 MHz */
GPIOG->OSPEEDR = 0xC0330FFF;
/* Configure PGx pins Output type to push-pull */
GPIOG->OTYPER = 0x00000000;
@@ -114,7 +114,7 @@ void SystemInit_ExtMemCtl(void)
GPIOH->AFR[1] = 0xCCCCCCCC;
/* Configure PHx pins in Alternate function mode */
GPIOH->MODER = 0xAAAAABFF;
- /* Configure PHx pins speed to VERY_HIGH */
+ /* Configure PHx pins speed to 100 MHz */
GPIOH->OSPEEDR = 0xFFFFFC00;
/* Configure PHx pins Output type to push-pull */
GPIOH->OTYPER = 0x00000000;
@@ -126,7 +126,7 @@ void SystemInit_ExtMemCtl(void)
GPIOI->AFR[1] = 0x00000CC0;
/* Configure PIx pins in Alternate function mode */
GPIOI->MODER = 0xFFEBAAAA;
- /* Configure PIx pins speed to VERY_HIGH */
+ /* Configure PIx pins speed to 100 MHz */
GPIOI->OSPEEDR = 0x003CFFFF;
/* Configure PIx pins Output type to push-pull */
GPIOI->OTYPER = 0x00000000;
@@ -164,7 +164,7 @@ void SystemInit_ExtMemCtl(void)
WriteRecoveryTime = 2 -> 1 WWWW TWR
RPDelay = 2 -> 1 PPPP TRP
RCDDelay = 2 -> 1 CCCC TRCD */
+ #if 0
FMC_Bank5_6_R->SDCR[0] = 0x00005965; // 0000 0000 0000 0000 0101 1001 0110 0101 Bank 1
// PPB KKWL LNMM RRCC
FMC_Bank5_6_R->SDCR[1] = 0x00005965; // 0000 0000 0000 0000 0101 1001 0110 0101 Bank 2 // CAS Latency = 2
@@ -174,6 +174,7 @@ void SystemInit_ExtMemCtl(void)
// CCCC PPPP WWWW RRRR SSSS EEEE LLLL // mit CAS Latency = 2 (s.o.)
FMC_Bank5_6_R->SDTR[1] = 0x01010351; // 0000 0001 0000 0001 0000 0011 0101 0001 Bank 2
// CCCC WWWW SSSS EEEE LLLL
+ #endif
#if 0
FMC_Bank5_6_R->SDTR[0] = 0x00206000; // 0000 0000 0010 0000 0110 0000 0000 0000 Bank 1 // Original + 1 bei allen Werten,
// CCCC PPPP WWWW RRRR SSSS EEEE LLLL // mit CAS Latency = 3 (s.o.)
@@ -187,6 +188,10 @@ void SystemInit_ExtMemCtl(void)
FMC_Bank5_6_R->SDTR[1] = 0x020306B1; // 0000 0010 0000 0011 0000 0110 1011 0001 Bank 2
#endif
+ FMC_Bank5_6_R->SDCR[0] = 0x00001800;
+ FMC_Bank5_6_R->SDCR[1] = 0x00000165;
+ FMC_Bank5_6_R->SDTR[0] = 0x00105000;
+ FMC_Bank5_6_R->SDTR[1] = 0x01010351;
/* SDRAM initialization sequence */
2.25.1
