[PATCH 06/12] kern_tc.c: Replace FREEBSD event mechanism by adding pointers to function
Gabriel Moyano
gabriel.moyano at dlr.de
Thu Apr 7 08:36:01 UTC 2022
cpukit/include/sys/timepps.h | 11 +++++++++++
cpukit/score/src/kern_tc.c | 20 +++++++++++++++++++-
2 files changed, 30 insertions(+), 1 deletion(-)
diff --git a/cpukit/include/sys/timepps.h b/cpukit/include/sys/timepps.h
index 5703381ffa..a72579d5d7 100644
--- a/cpukit/include/sys/timepps.h
+++ b/cpukit/include/sys/timepps.h
@@ -149,6 +149,12 @@ struct mtx;
#define PPSFLAG_MTX_SPIN 0x01 /* Driver mtx is MTX_SPIN type. */
+#ifdef __rtems__
+struct pps_state;
+typedef int (*wait_event_func)(struct pps_state *pps, struct timespec timeout);
+typedef void (*wakeup_func)(struct pps_state *pps);
+#endif /* __rtems__ */
struct pps_state {
/* Capture information. */
struct timehands *capth;
@@ -164,6 +170,11 @@ struct pps_state {
int ppscap;
struct timecounter *ppstc;
unsigned ppscount[3];
+#ifdef __rtems__
+ wait_event_func wait_event;
+ wakeup_func wakeup;
* The following fields are valid if the driver calls pps_init_abi().
diff --git a/cpukit/score/src/kern_tc.c b/cpukit/score/src/kern_tc.c
index 77f7a9212c..a5c7b4b841 100644
--- a/cpukit/score/src/kern_tc.c
+++ b/cpukit/score/src/kern_tc.c
@@ -1910,9 +1910,15 @@ abi_aware(struct pps_state *pps, int vers)
static int
pps_fetch(struct pps_fetch_args *fapi, struct pps_state *pps)
+#ifndef __rtems__
int err, timo;
+#else /* __rtems__ */
+ int err;
pps_seq_t aseq, cseq;
+#ifndef __rtems__
struct timeval tv;
if (fapi->tsformat && fapi->tsformat != PPS_TSFMT_TSPEC)
return (EINVAL);
@@ -1925,6 +1931,7 @@ pps_fetch(struct pps_fetch_args *fapi, struct pps_state *pps)
* sleep a long time.
if (fapi->timeout.tv_sec || fapi->timeout.tv_nsec) {
+#ifndef __rtems__
if (fapi->timeout.tv_sec == -1)
timo = 0x7fffffff;
else {
@@ -1932,7 +1939,6 @@ pps_fetch(struct pps_fetch_args *fapi, struct pps_state *pps)
tv.tv_usec = fapi->timeout.tv_nsec / 1000;
timo = tvtohz(&tv);
-#ifndef __rtems__
aseq = atomic_load_int(&pps->ppsinfo.assert_sequence);
cseq = atomic_load_int(&pps->ppsinfo.clear_sequence);
while (aseq == atomic_load_int(&pps->ppsinfo.assert_sequence) &&
@@ -1943,6 +1949,7 @@ pps_fetch(struct pps_fetch_args *fapi, struct pps_state *pps)
while (aseq == atomic_load_acq_int(&pps->ppsinfo.assert_sequence) &&
cseq == atomic_load_acq_int(&pps->ppsinfo.clear_sequence)) {
+#ifndef __rtems__
if (abi_aware(pps, 1) && pps->driver_mtx != NULL) {
if (pps->flags & PPSFLAG_MTX_SPIN) {
err = msleep_spin(pps, pps->driver_mtx,
@@ -1954,6 +1961,12 @@ pps_fetch(struct pps_fetch_args *fapi, struct pps_state *pps)
} else {
err = tsleep(pps, PCATCH, "ppsfch", timo);
+ if (pps->wait_event != NULL)
+ err = (*pps->wait_event)(pps, fapi->timeout);
+ else
+ err = EAGAIN;
if (err == EWOULDBLOCK) {
if (fapi->timeout.tv_sec == -1) {
continue;
@@ -2227,7 +2240,12 @@ pps_event(struct pps_state *pps, int event)
#endif
/* Wakeup anyone sleeping in pps_fetch(). */
+#ifndef __rtems__
wakeup(pps);
+ if (pps->wakeup != NULL)
+ (*pps->wakeup)(pps);
/* FIXME: https://devel.rtems.org/ticket/2349 */
2.25.1
