AW: AW: [PATCH 05/12] kern_tc.c: Replace atomic functions required by PPS API
Sebastian Huber
Thu Apr 7 13:20:42 UTC 2022
On 07/04/2022 15:14, Gabriel.Moyano at dlr.de wrote:
>> In FreeBSD, it seems the sequence is sometimes incremented using a normal increment, for example:
>> *pcount = pps->capcount;
>> (*pseq)++;
>> *tsp = ts;
>> So, just add the atomic_load_int() as an relaxed atomic load to the other inline functions at the top of the file.
> atomic_load_acq_int() is defined also at the beginning of the file. Do you want to repeat the function but with other name (atomic_load_int()) ?
No, just add the atomic_load_int() as a RELAXED atomic load to the other
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
